Question about Coffee Makers & Espresso Machines
Have a Saeco Via Venezia I think it overheated and tripped its overheat switch, as it the light no longer comes on. I have taken the cover off however cannot find the switch, can you help me
    Problem Solver:
  • 11 Answers
I believe you have a digital system, there is a thermal control setting in the system that may have been improperly set at the factory. We sent a new system back with the same problem and they made the fix.
Best Wishes,
Posted on Jan 18, 2009
Is it worth it to get the machine fixed if the heating element no longer works?
Saeco Via Venezia - YouTube
? 3:10
Nov 24, 2011 - Uploaded by TheSTiGUi
I dusted off my old Saeco Via Venezia, and wanted t. ... Quick run down of my incomplete modified Saeco Via Venezia Espresso Machine ... a start temperature of ~95deg C (obviously depends on boiler water temperature etc.) ...
Jul 28, 2015 | Saeco VIA Venezia
We have broken the handle on pressurized portafilter for Saeco Via Venezia espresso machine. where can we get replacement?
I don't think the handle is sold separately. Seattlecoffeegear does sells both a bottomless and an unpressurised portafilter for the Via Venezia. Both would be considered upgraded gear vs the pressurized one.
Jan 30, 2013 | Saeco VIA Venezia
Dear Expert, My Saeco VIA Venezia Problem is : Machine never comes up to Temperature (no Green Indicator Light), ie. doesn't heat and no pump. Like a fuse is blown. I have been told that there is a 'RESET'...
There is a fuse on top of the boiler. Its under a clip on the outside edge of the boiler. It is covered in a redish brown cover that you have tpo slide off to see the fuse. It is just better to replace the hole thing. If you don't have a pump also it could also be the switch. If you have any power its probably the fuse.
Nov 03, 2010 | Saeco VIA Venezia
After months of perfect performance, my via
HI I think you have a blown element in the boiler. You might have a leak that is shorting inside also.
Jan 26, 2010 | Saeco VIA Venezia
Saeco VIA Venezia i have just tried to steam milk but i think i may have overheated the steamer. Machine will not work at all now. is it dead or can it be repaired.
I checked on your site for any similar fault and came up with a response from Guru. Just had take the casing off and reset the the machine and now it works perfectly.
Many thanks
Jan 24, 2010 | Saeco VIA Venezia
Saeco classico is overheating
Yes. Check the thermostats on the boiler.
Apr 17, 2009 | Saeco VIA Venezia
Saeco Via Venezia Cappacino Machine The black plastic sleave for the frothing arm has melted and no longer fits on - where can i get a new one? I am based in Canberra - its a Via Venizia Espresso
Contact Saeco Australia to see if they can help you.
Saeco Australia Pty Ltd
6/87 Newlands Road Reservoir
Victoria 3073
Tel.: +61 3 94624949
Fax: +61 3 94624955
Aug 31, 2008 | Saeco VIA Venezia
Overheat cutout switch
The coffe maker has a heat fuse attached to the side of the pump so when over heats that melts and does not damage the coffee maker
They charge $100 to replace which is a bit tough, you could bypass easily but could damage the machine if not careful
as we have two and one has just stopped pumping, not picking up water so maybe worn valves and I just have it all to bits and noted the heat fuse on the side of the pump
Feb 10, 2008 | Saeco VIA Venezia
Saeco via venezia overheat cut out
Disconnect from the power and remove the 5 or 6 grub screws retaining the main steel cover and take the cover off. You will see a plastic re-set button on top of the boiler amongst the electrical terminals - just click it on again.
To stop overheating always open the steam valve immediately you switch the machine on until water squirts out - this tells you the boiler is full & not dry! Also remember (unlike me!) to switch the machine off as soon as you have finished brewing...
Feb 10, 2008 | Elektra (SX) Espresso Machine & Coffee...
Coffee Makers & Espresso Machines Logo
121 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
