Question about C3RS603 2Channel Remote Start Module with Keyless Entry Trunk R
I have autopage remote to start my car on and It is not working. I have changed the battery but it seems the car itself not responding. What should I do?
On the back of my remote it is XT-72S FCC ID:H50T21
5 Suggested Answers
  • 103 Answers
SOURCE: i need wire diagram for RS665 autopage
http://www.autopageusa.com/resources/C3RS665installmanualfinal.pdf
Posted on Aug 13, 2010
  • 103 Answers
SOURCE: i need a replacement remote XT-43LCD FCC
you can contact autopage's authorized remote replacement services at www.autopageusa.com and clicking need a replacement transmitter.
Posted on Jan 12, 2011
  • 103 Answers
SOURCE: i have a autopage remote xt-915lcd , what is the
5v -------------- 0.8a
ITE power supply MODEL# HK-F104-A05
  • 139 Answers
SOURCE: i need the manual to
The Autopage XT-42LCD is used to operate two systems, the RF-420LCD and RS-622. Since you state that you need to activate a remote start that narrows it down to the RS-622. You can download the manual for this unit at the following link:
http://www.autopageusa.com/resources/RS622operationManual.pdf
Posted on Jan 22, 2011
How do I reserve battery life on my autopage alarm key pad model XT-73LCD
If you put remote in your pocket or your purse make sure it doesn't push on any buttons!
Mar 30, 2014 | C3RS915 SST Remote Car Start Vehicle...
RS855LCD 2-way remote and key fob dreain batteries
I see this is a old post but, I have this unit in a used van that came with no remotes. A local audio shop paired it up with a AUTOPAGE XT-33. I can lock,unlock,start with this remote. Just remember to keep the drivers open while doing these steps.
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the2ndpush, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
The Valet switch is a little Red Push Button that should be
mounted under the lower left side of you dash or in the lower
left kick panel near the E-brake pedal.
Jan 14, 2012 | RS855LCD AutoPage MultiChannel 2 Way...
Alarm is not responding ,alarm was also going off as i was driving ,loud horn followed by short churps ? how do i fix this i have , just brought this vehicle and i only have 1 alarm remote on the keys.
Hi there this once happened to me while driving along and all of a sudden the car alarm started to sound- I stopped at lights and tried finding wire to pull off battery but to no avail. I finally took to shop and found all that problem was the remote battery was flat and spent all of like $6 to replace it. Hope this is yr problem too.
Aug 04, 2011 | C3RS730 LCD (C3RS730LCD) 2way 4Channel...
Remote says OUT OF RANGE when i try to arm it.
Reprogram the remotes using this procedure:
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
2. Push the Valet switch 2 times and hold in on the 2nd
Program:
May 07, 2010 | Megatronix - TW71 - 5 Button 2 Way LCD...
Car will not start using the key fob all fuses are good, lock/unlock buttons work. i have had this remote starter in this car for nearly 3years
In some cases, if you hold down a button too long on the remote fob, the starter module goes into a setup "menu", which is possible. You didn't change the fob batteries lately, did you? It sounds like you will have to 'retrain' the fob with the starter unit so that it re-learns what to do when you push the start button. With the "Ultra" brand, you use the button on the windshield antenna to retrain your unit. I'm not sure about the Autopage brand. An installer should be able to reprogram it for you for $10, and that would be the easiest if you can't find the data by doing a Google search.
Oct 02, 2009 | Autopage Vehicle Parts & Accessories
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
C3RS603 2Channel Remote Start Module with Keyless Entry Trunk R Logo
89 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
baire
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
