Question about Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher occasionally won't fill...what am i doing right/wrong?
The pipes in our apartment froze and burst when we were away for several weeks as our furnace broke and the place stopped getting heated. All the pipes are fixed now and we've got heat again, except now we are having trouble with our dishwasher. We're not sure if it's a result of the pipes freezing, but we're assuming the 2 are related since the problem first started the first time we tried running the dishwasher after getting everything else fixed and this has never happened before.
Anyways, when we try to run the dishes, we hear something whirring (the drain pump?), and the time on the display does not count down or if it does, it goes very slowly and stops at some lower number.
First, I pulled the dishwasher out and took off the bottom panel, but I didn't touch anything. I then poured water in the dishwasher trying to "trick it" as I've read about from other people, and, voila, it ran through a cycle. Again, I did nothing but add water inside and jiggle the dishwasher around.
After this fluke of getting it to run one time, it stopped working again, so after reading through various other peoples' problems, I think our problem is something to do with the float or float switch. I pulled out the dishwasher, took off the left side panel and when the dishwasher was trying to run a cycle, I held down the red plunger which caused the drain to stop and the dishwasher to fill, but as soon as I let go, it stops filling and the drain kicks on again.
I tried jostling around the dishwasher again and added water, and the plunger got "un-stuck" from the UP position and we have since been able to run the dishwasher through a 2nd "miracle cycle".
Any ideas on what I'm doing right/wrong? I'd rather not have to pull the dishwasher out, add water, and shake it every time I want to clean dishes. Could the frozen pipes have something to do with all of this or is it just coincidental?
    Problem Solver:
  • 7 Answers
Could be a clogged inlet screen. I changed my hot water tank once and disturbed some sediment and later had a clogged inlet. The problem went further - I cleaned the filter but then noticed on the weekend that we had water overflowing from the DW. This was caused by some of the seidment actually causing the inlet valve to leak when it was supposed to be shut off. Not a problem if we did a wash daily, but when we didn't it caused the DW to fill - very very slowly- and eventually overflow. I suggest taking the inlet solenoid out and cleaning it really well then monitor the inside of the DW for water buildup. (Replacement is much easier than repairing the water damage to the basement ceiling.)
Posted on Apr 05, 2010
  • 457 Answers
Make sure there is no water at allin the base os the unit so remove panel again and check with flashlight. then hit the drain and cancel button.that should do it.
Posted on Mar 03, 2010
My moms pipes froze to her washing machine. They thawed and the machine filled with water but they won't wash. She can hear a buzzing sound like the machine is trying to wash the clothes but nothi
Yes , I think the valves also must have jammed in the process and when the hot water filled up in due course it must have released.
It is best to switch off water supply to the machine in such times.
Jan 23, 2013 | Washing Machines
Inside of freezer door bubbled up
If the pipe that burst was spraying water onto the refrigerator, it is likely that some water got between the inner panels of the freezer door. This water then froze and expanded, pushing out the inner panel of the freezer.
Jan 21, 2013 | Refrigerators
My GE quiet power 1 dishwasher has flashing lights and won't stop cycling, what do i do?
I have had this problem with this dishwasher in my rented apartment occasionally since I moved in. It would usually reset itself if I let it sit a while, but not today. Today all it would do is flash and beep and I finally just unplugged it. I stumbled across this page and read the post by Dyons above and it worked. Close the door, let it grind away and within 2 minutes it will reset itself. Thanks, Dyons!!!
Sep 28, 2011 | GE Dishwashers
Hello my tricity bendix dishwasher won't take in water, it will pump it out and when I turned water off at the mains and disconnected the water pipe and put it in a bucket turned mains back on the...
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 11, 2011 | Tricity Bendix 24 in. DH102 Free-standing...
I have an Electrolux ESI 6104x. Regularly just after starting the dishwasher as it starts to fill for the first time the water inlet cuts out. If you turn the water off at the mains disconnect the inlet...
Disconnect the fill pipe from the back of the machine and you should see a small mesh strainer in side the dishwashers inlet valve. Check that this is not dirty - to clean it pull out the strainer and rinse under the tap.
Dec 29, 2010 | Dishwashers
Bosh dishwasher wont fill...also sink drains right intodiswasher.
sounds like your plumbing in your sink is going wrong way check pipes or your sink maybe have a clog in it
Nov 21, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Loud humming when the water enters the dishwasher. The copper pipe vibrates. The dishwasher is approximately 11 years old. Problem slowly getting worse over time. I tried to tie down the copper pipe in the...
the fill valve solenoid has gone bad.u need to chg the fill valve assly.it is very easy to chge ad it is mounted on lhs bottom corner of the unit behind the toe panel.
Aug 17, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
GE dishwasher will not fill with water
is the filling valve on the inlet water working unscrew the connecting pipe and see if the water is actually comeing out of the pipe. sometimes when the tap runs at the same time it takes a lot of the water rather than the dishwasher getting it. depending on the pressure. otherwise it might be the ****** pump. try wd 40 on it. it might be jamming.
Mar 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher wont fill
I fit won't fill then apparently you're not getting any water to it, which means it not's fixed. Did you turn the service valve back on since the repairs were made? Sometime when you turn a service valve off they fail to re-open. Crack the inlet water line and verify that you have incoming water.
Jan 18, 2009 | Whirlpool 24 in. DU1050SS Built-in...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
169 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
