Question about GW Security Home Security
Where can Ifind help for installing a Ouku brand 4 channel cctv dvr?
I cannot see any images when I hook the cameras up using the VGA connection to the monitor. The cameras work when they are connected to the television using the BNC-RCA ports on the television. But not when I connect them using the monitor. Have tried everything possible.
    New Friend:
    Problem Solver:
  • 6 Answers
I had exact same problem and it took forever to fix but I did fix it. If I plugged the camera into the tv it worked but when I tried going through the dvr no picture at all. The problem was the power supply cord to the cameras. It was bad, I happen to have another one and that was it. All cameras working!
Posted on Sep 30, 2013
  • 3 Answers
SOURCE: cant access lorex DVR from the internet
i have the same trouble, and i did what u said and it doesn`t work yet:S something else????
Posted on Jul 31, 2009
robmcd27
  • 423 Answers
SOURCE: I GOT A SAMSUNG SOD14C , OKAY I WANT IT TO CONNECT
Well, your going to need RJ45.
RJ11 is telephony and has 2 pairs of wires. With that, you could use the Blue/Blue-White for power and the Orange/Orange-White for video. Then your stuck.
RJ45 has 4 twisted pairs.
To find out which has power, use a meter to measure your 24 volts.
Rob
Posted on Mar 09, 2009
SOURCE: samsung shr 1040 4 channel dvr
I hook my shr-1040k and get no pickure Larry
Posted on Jun 12, 2009
  • 11 Answers
SOURCE: samsung shr-1041k CCTV system with 4 cameras.
on most dvr 's the port is 80 for the web cam. you also need to set up the network settings and know the ip you are trying to hit and is it static or dynamic if dynamic it will change periodicly. for example if you set the network settings on the dvr to the rang of your local network it would be something like 192.168.1.10 so under your router you would open port 80 to ip 192.168.1.10. make sence. first thing i would do is make sure the network settings in the dvr are set to work within your network. unless you have an extra static ip you can put it right into the dvr. fi you need further help just ask.
Posted on Nov 04, 2009
SOURCE: can't view my cameras
The DVR will be programmed with an IP Address via the DVR main menu function (network settings) and a valid password. The network viewing software (web viewer) you will need to ensure that the IP address is entered correctly for your DVR along with your valid user password.
Trust the above info is of assistance if you require a manual in order to check your settings try this link http://tv.manualsonline.com/manuals/mfg/samsung/samsung_dvr_product_list.html
Posted on May 24, 2010
Can i connect to my laptop with that cctv view where i can see all camera on same screen?
you will need a multiplexer to connect all your cameras into and out to laptop on the front of the multiplexer you can use the buttons to see one or all the cameras you have installed.
May 24, 2014 | Astak Wireless 2.4ghz Night Vision Color...
Will not connect with my pc
I would recommend you to install the Software of the DVR System properly.
The System is provided with the installation CD. Only matter when such DVR'S are needed for the cctv camera with ir illuminators.
Follow the steps:
1) Insert the mini CD into a CD/DVD ROM drive on your computer.
2) If your CD/DVD ROM drive does not auto run the CD; click MY COMPUTER click on the drive the CD is in and double click on the "D9-VIEWER-DBG-ENG.EXE" file.
This will definitely help you.
Sep 26, 2013 | Swann Communications 2500 8 Channel DVR...
I have a sentient cctv dvr from Maplin I can view it on my phone at home which is fine I wanted to know if I can view camera footage when I'm not at home etc. at work
Yes you can definitely view your CCTV footage on your mobile phone at your work via internet. Sentient CCTV DVR basically is a night vision camera. You must know the IP of the camera and IP Video server. Connecting your phone to CCTV camera via the protocol you can view the CCTV footage's in your phone. Night vision cameras are used for surveillance purpose. I would prefer cctv camera with ir illuminator for good image quality in the night time that will clear footage quality in my phone.
Recently many new applications have also being launched by security cameras with a view to solve problem you mentioned.
Jul 05, 2013 | Home Security
Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Jan 27, 2012 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
Does it supports any brand of cctv cameras or will there be any incompatibility with same brand..
It support all brand of CCTV.
for PTZ CCTV, It has to have the Pelco protocol so the WJ-HD716 can control the camera.
in that case, the connection will use the RS485.
Oct 19, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
Just installed a sentient 250gb cctv dvr system, cannot get the dvr box to display on tv even with specific cable bought from maplins and hdd light is flashing...help
By default it goes to VGA port out of the DVR.
So you could hook up a pc monitor to it and use that. Once logged in you can change to tv out via the desktop menus.
It is also possible to hold down a button on the DVR (cannot remember which one sorry) at DVR power up to switch it to use tv out instead of vga.
Dec 30, 2010 | Cameras
No picture on my tv from cctv camera
it is neither clear what sort of output your cctv cameras produce, nor what sort of input your dvr accepts. but, for the most part, dvrs record digital tv signals, whereas cctv cameras output analogue signals. so, even though you may be able to plug a cctv camera "straight" into a tv via a scart connector, it is unlikely that any scart connectors on a dvr have the necessary circuitry to accept such signals.
May 24, 2009 | Sharp Cameras
No signal
how do i connect a usb stick for a ch usb dvr to a video player
Jan 29, 2009 | Cyberhome DVR 1600 DVD Recorder
Getting my samtron to work on my cctv
Not all DVRs have WORKING VGA output. I used to work for Nuvico, and we had 2 different versions for DVRs. Ones with VGA connection. The other with non-working VGA connection. VGA port itself does not guarantee. Some DVRs also have DIP switch in the back. You can simply toggle between composite or VGA output. Ones with DIP switches often require reboot, and from my experience these do not work well with VGA monitors. Also... Make sure VGA monitor support low resolution. Stand-alone DVRs' native resolution is either 600 or 800 horizontal lines.
It will help alot if I know the model of DVR/CCTV
Jan 17, 2009 | SAMTRON 95P 19" CRT Monitor
Home Security Logo
487 people viewed this question
Top GW Security Home Security Experts
Lawrence Oravetz
Are you a GW Security Home Security Expert? Answer questions, earn points and help others
