Question about Toshiba 500gb 2.5 Sata Mk5075gsx Hdd2l03 5400 Rpm Hdd Laptop Hard Drive
How do i wipe completly - Toshiba 500gb 2.5 Sata Mk5075gsx Hdd2l03 5400 Rpm Hdd Laptop Hard Drive
    Champion:
  • 221 Answers
Look up a program called HDDUtil. This will low-level format the disk.
Posted on Dec 16, 2013
How do i do a hard reset on cubot s208
Phone reset:
Power off the phone, hold the volume down key and press down the power button simultaneously for about 15 seconds. The phone will power up and shows an exclamatory mark. Then release the button. Press the volume down key, it will display the menu. Choose the menu by press the volume down key. Choose "wipe data/factory reset", press power key to enter in, then choose "delete all user data", press power key to confirm. Wait until it indicates "data wipe complete". Then choose "wipe cache partition", confirm with power key. Wait for a few seconds, the screen will shows "cache wipe complete". And at the last, choose "reboot system now", confirm with power key, then the phone will reboot.
Feb 16, 2015 | CUBOT Cell Phones
How can i reset my blackberry playbook
To perform a hard reset, complete the following steps.
  1. Remove the battery cover from the back of the BlackBerry smartphone
  2. Remove the battery, and then reinsert it after a few seconds
  3. Replace the battery cover.
To perform a soft reset, complete the following steps.
  1. Press and hold the Alt key (1)
  2. While holding down the Alt key, press and hold the Right Shift key (2)
  3. With both of those buttons still pressed, press the Backspace/Delete key (3)
  4. When the screen turns off to indicate that the BlackBerry smartphone is restarting, you can then release the keys you have been holding.
To fully remove data from a BlackBerry smartphone, you will need to perform a security wipe
To initiate a security wipe, complete the following steps:
  1. On the BlackBerry smartphone, select Options from the home screen.
  2. Select Security Settings, then Security Wipe.
  3. Specify what items will be wiped during this process by checking off the boxes.
  4. Enter "blackberry" (field is not case-sensitive) and select Wipe.
  5. The BlackBerry smartphone will reset a few times, and after this process is complete, it will no longer contain any of your personal data.
Aug 25, 2014 | RIM Blackberry Playbook with 64GB Internal...
How do I wipe the hard drive of konica minolta bz-c353
Take it out and use your PC or Laptop to wipe out/reformatted. If the hard drive contains sensitive data then you will need to find a program that will wipe out those completely.
Try this method
Nov 21, 2013 | Konica Minolta BZ-C353
What do you do if your Tracfone gets wet
If it's only on the outside, I'd just wipe it clean.
If it's worse I'd immediately remove the battery, wipe everything down with a towel, and let it dry completely. I'm in a dry location so letting it sit overnight would do it; if you're in a humid environment you might want to put it in a bowl of uncooked rice to absorb the water.
Only after it's completely dry would I put the battery back in and see if it works. If it does, great. If not, then it's time to consider getting a new phone. It's all a matter of how much water got into it and for how long.
The above is for fresh water. If the phone got immersed in salt water, I'd remove the battery, wipe the phone dry, quickly rinse it in fresh water, wipe it dry again, and let it dry completely.
Jan 14, 2013 | Cell Phones
How do i fix uncaught exception on 5 5 on blackberry 8520 curve
first do a complete back up of your blackberry using blackberry desktop manager. then wipe your handset. beware wiping will delete all your contacts,messages and settings.
next go to option from menu,select security options,and press menu key, you will get hidden option wipe handheld. select it it will ask you to type blackberry.
wait till wipe is finished. then just connect to desktop manager and restore .
regards
please comment
Dec 29, 2010 | Lands Phones
What would cause a electric stove oven to smoke out the oven vent after you cleaned the oven inside completly
There may still be some crumbs left behind that you didn't get completely wiped out; assuming you did wipe it out. It could also be the broiler pan if it was in the oven.
Jim
Oct 06, 2010 | Microwave Ovens
My blackberry when calling it go call is not allowed,please I want the factory reset password,since I don't have the catalog
For BlackBerries, all you can do is either soft reset it or to completely wipe the phone. Here's what you need to do:
1. Remove the battery from the back of it while the phone is turned ON.
2. Leave the battery out for 5 minutes and put it back it.
This is how to soft reset the phone. But if you would like to completely wipe it, you need to back up the files first using the BlackBerry Desktop Manager before wiping it. Because wiping the phone will completely erase everything.
Here's how:
1. Go to Options > Security > General Settings...
2. press the BlackBerry button and there's an option to wipe it.
Good luck and have a great day!
Jan 05, 2010 | RIM BlackBerry Bold 9000 Smartphone
Wiping WD hard drive
I suggest that you use Darik's Boot and Nuke ("DBAN")application to completely Esare the Hard Drive. It is a freeware application.
Darik's Boot and Nuke ("DBAN") is a self-contained boot disk that securely wipes the hard disks of most computers. DBAN will automatically and completely delete the contents of any hard disk that it can detect, which makes it an appropriate utility for bulk or emergency data destruction.
For detail visit:
http://www.dban.org/
Good Luck!!!!!!!!!!!!!!!!
Sep 08, 2009 | Western Digital My Book Essential 500GB...
Emachine d6417 will not fully recover
sounds like a harddrive malfunction,wipe it again.
Jun 15, 2009 | E-Machines eMachines Desktop PC
Toshiba 500gb 2.5 Sata Mk5075gsx Hdd2l03 5400 Rpm Hdd Laptop Hard Drive Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
