Question about GE Profile 30" Built-In Single Electric Wall Oven - Black-on-Black
Cooling fan on ge profile oven not working
Have replaced the mother board and now the oven heats but the cooling fan is not turning on to keep the mother board from over heating
aborcass
  • 2651 Answers
SOURCE: GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Posted on Mar 30, 2008
aborcass
  • 2651 Answers
SOURCE: F3 Error Code - GE Electric Oven JTP18
all ge codes f3 are saying ot replace thermal sensor, you can check the harness connecting them for a pinched or burnt wire i guess, as far as getting a part number , you can enter complete modle number her e and look for the sensor, i checked just the partial number you gave and a few different ones showed up
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 23, 2008
SOURCE: Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Posted on Jan 04, 2009
SOURCE: GE True Temp Oven not heating. Broiler works
we bought a new oven
Posted on Dec 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: Keep getting F1 error code (constant beep) on my GE profile oven.
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%#$TEF
Posted on Oct 01, 2010
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    I used the oven in the house we just purchased (a GE wall oven JTP18 and after I turned it off a fan kept running. Is that normal?
    Yes, the program and thermostat calls for the fan to cool the electronics, without that you can loose the electronic boards. Normally the fans will shut off once temps drop to 200 degrees Fahrenheit. Enjoy your new home.
    Jul 08, 2011 | GE Profile JTP18 Electric Single Oven
    Ge oven turns off by itself, and sometimes gives
    F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
    Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
    · Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
    · Control senses oven temperature above 935 degrees F with the door in the locked mode.
    · Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
    · Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
    · Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
    · Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
    Nov 11, 2009 | GE Profile JTP18 Electric Single Oven
    GE profile lower oven does not turn off...maintains low heat with the convection fan on for several hours.. When i turn oven back on and then off it stops...but the problem continues to happen periodically
    Stove will not turn off CHECK
    Temperature Control Thermostat
    If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
    Oven Control Board
    The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
    Relay board:
    Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
    Sep 12, 2009 | GE Ovens
    COOLING FAN DOES NOT STOP AFTER HOURS
    Hi I am Vortash the cooling fan must be controlled by a thermostat , it appears that it has a problem on it and is not shutting off .
    They are usually normally open contact switches that are on the top or the side of the oven ,they heat up close the connection and turn the fan on . yours sounds as if it is sticking . Other ovens are controlled by a rheostat a long tubed thermostat that goes to a main control consul on the oven , it controls the fan and responds to what the stat tells it .
    It may be this controller is not turning the fan off afterwards , my suggestion is that unless you are electrically trained you get the help of a service engineer to check your oven out .... regards Vortash
    Jun 15, 2009 | GE Profile JT912 Electric Single Oven
    When oven heats up the fan gets really loud and doesn't turn off for a long time
    if your oven is fairly old, dust might be the enemy. FIRTS Turn off the breaker on your house electrical panel that feeds power to the oven before doing anything. Do not electrocute yourself!!
    Remove the control console bezel where the control panel for your oven is..it's probably held on by a few screws. You'll see the fan is there somewhere inside the enclosre, it's purpose is to keep the circuit board cool but the fan grill is probably clogged with dust...remove the fan from the enclosure...try using a vacuum to get the dust out...you might need to use a small brush to loosen the dust film, clean the fan blades while you're at it. Reassemble and turn on the power ...you'll probably find the fan runs much quiter...good luck
    Jun 08, 2009 | GE JTP15 Electric Single Oven
    Cooling and/or convection fan
    I had the same problem. The screen protecting the fan bends into the fan from the heat. Take off the top front control panel (3 screws), reach in to the back where the fan is and push the screen back away from the fan. As always, turn the power off first to avoid shock. This should solve your noise problem.
    Apr 08, 2008 | GE Profile JTP18 Electric Single Oven
    Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
    Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
    GE: JTP56 F2 Door Locked displayed
    I have the the same problem as discribed above. Does you oven fan go on for a long time after you use your oven during regular baking. Mine seems to stay on for 45 minutes after I bake anything. Can this be all tied together with the f2 problem? I am wondering if it is not just a fan circulation problem?
    Dec 15, 2007 | GE Profile JTP56 Electric Double Oven
    GE Profile 30" Built-In Single Electric Wall Oven - Black-on-Black Logo
    138 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
    Are you a GE Oven Expert? Answer questions, earn points and help others
