Question about AOpen Computers & Internet
What video card can i put into an emachine with a wmcp61m motherboard
I'm trying to pep up a computer for a friend. it has 3 gb and I'm bumping it to 4. I can't seem to find info on the on board slots.
djnick989
  • 1067 Answers
SOURCE: motherboard manual ?
is jumpers on 1 and 2 good power test ram front conecter on pw
Posted on Jan 25, 2008
HeXx13505
  • 65 Answers
SOURCE: PCI Express slot not working
go into the bios and change the video settings from onboard video to pcie video
Posted on Mar 27, 2009
byteguy
  • 2229 Answers
SOURCE: No video on new Gigabyte GA-MA770-DS3 motherboard
There are a couple things that you need to look at. The first is your power supply. I've had computers seeming to run fine with no video. Turned out to be bad power supplies.
Does your video card require a power connection? Many high-end video cards need an external power connection. If the card has a power connection, use it.
Have you gone in and checked the cmos settings? What does it say (if anything) for the default video?
Now remove all connections to drives (hard drive and CD and try for video. Try it.
Next, if possible, swap out memory.
After you've tried everything (including maybe burning incense), time to try a new motherboard.
Posted on May 27, 2009
  • 117 Answers
SOURCE: Which graphics cards are compatible
You can not use a PCI-E card. This mobo has one AGP slot and TWo PCI(not PCI-E) slots. I am assuming you have a Dell Optiplex GX260? It has the D845 series board. Goto Newegg.com and search for: AGP. They have a nice x1650pro agp card for cheap. I have the same board in one of my PC's
Posted on Jun 10, 2009
Mr_Wizardtex
  • 205 Answers
SOURCE: Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Posted on Jun 29, 2009
Have emachines monitor which is not coming on power button fast flicker
Which power button is flickering (your computer, or your monitor).
Here's some tricks I would try...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | eMachines Computers & Internet
What type of graphic card are compatable with emachines T3624 Pc's
Hello here are the homepage:
http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1581
This mainboard has the PCI-e graphic card socket, and a AGP graphic card will not fit and run on it.
A PCI-E graphic card, can be bought in a computer store or online.
Does the pc boot at all ???
If not try to renew the power supply.
Good luck
Mar 31, 2013 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Plugged in my emachine LE1938 to my dell without the DVI cable, screen displays 'no signal'. Shouldn't the monitor work without the DVI cable?
The DVI cable transports the display signal from the video card to the monitor.
I think what Ron is asking is if you used a different cable to connect the monitor to the computer. (I'm assuming you used an old 15 pin monitor cable or whatever those old cables were?)
Without getting into your BIOS:
So on your computer, you probably have an onboard video card (a video card built into the motherboard itself), and a dedicated video card (probably where you're seeing the DVI out).
It may be possible that you have the on board video card (with the traditional connection) disabled, when the dedicated video card is plugged in.
This isn't rocket science, so don't worry. Phillips head screwdriver is all you need.
Pull the side panel off your computer (assuming it's a tower... if not, it's the top panel). Once you have it off, you'll see that video card plugged into a slot on the motherboard, with 1 phillips head screw holding it in place (inside, near the back, where the DVI port is).
Pull the screw, and the video card should come out. From there, the BIOS should recognize your card is missing, and thus revert to using the onboard video card.
Sep 02, 2012 | eMachines E-machines flat screen CRT 17"...
Acer desktp internal ram installation needed
I'm a bit confused....did you have all four of these in the ACER and are trying to put the 2x1GB into the Emachine? And that the 2x1 GB wouldn't work in the Emachine but they did in the ACER and that the 2x512 Acer cards worked in the emachine?
If that is what happened here is my best guess. The ACER MOBO will support 533/667/800 MHZ DDR2 RAM. The Emachine will only support 533 RAM. Iys possible the 2x1GB are either 667 or 800 MHZ and are not compatible with the Emachine but will work in the ACER.
Jan 23, 2012 | E-Machines T5082 PC Desktop
1st question== my friend gave me a p4vmm2 v8.1 mobo but when i turned it on it making a long one beep sound simultaneously inside ! there is no ram inserted! Is that the problem?????????? 2nd...
that's a functional motherboard you got there. The beep that you hear is an error beep for not reading a ram. Yes, you will insert a ram that is compatible with your motherboard. No you can't use that without a video card. If you've got a spare video card put it on your motherboard
Aug 02, 2011 | EliteGroup P4VMM2 V8.1 Motherboard
ET1161-07 onboard Video gone bad. I tried a Gforce 8800GS 384mb card, that works, and I have no video, 1 long beep that never stops. Ican't get into the bios with the onboard video or the new video and...
Hi.
One continuous beep means that you probably have not put the graphics card in the PCI express slot or there is a short somewhere in the system.
Follow these steps to try and resolve the problem:
Remove the power cord and the video lead from the back of the machine and then remove the side panel to reveal the motherboard.
Remove the graphics card and take a look at the PCI Express slot for dust. If you see any dust get a clean, dry paintbrush and clean the dust from the slot and then blow on the slot to remove the rest of it.
Next look at the brass contacts on the graphics card and clean then. Re-seat the card making sure that it is fully pushed down in the slot.
Check that any other cards you have installed in the machine are seated properly.
Without putting the side panel back on, connect both the video lead and the power cord and turn it on. DON'T TOUCH ANYTHING INSIDE THE COMPUTER!!!
If the computer boots up turn it back off and put the side panel back on. If not then please post back telling me what the computer is doing.
Good luck.
Jun 07, 2011 | eMachines ET1161-07 Desktop PC
Here's my issue. Ok i have 2 ram slots. When I have 2 1GB ram cards in the slots the computer registers 2GB ram. When I put in 2GB card and 1GB card, it only registers 2GB RAM. No idea why. I bought...
the issue may be the ram is not the same like a PC100 will not work with a PC300 ram card but if you have the same like a 2GB DDR2 and a 1GB DDR2 it will work unless your computer can only see 2GB of ram then i cannot help you
Jan 02, 2011 | Computers & Internet
Have emachines W2060. Can't get screen to show
Hi Joe,
Could be one of several things:
1) Monitor cable connection loose.
2) Video card (if you have one) not seated, or bad.
3) RAM module not seated, bad, or wrong kind. (If you have not messed with the RAM, probably not one of these.)
4) If your video is integrated into the motherboard (no video card) your motherboard may be bad. Installing a separate card could correct this.
5) Bad monitor.
Have you made any changes to your system when this happened?
Try to connect another monitor/cable to your computer and try your monitor on a friend's computer to see if it works.
Comment back with any updates.
Thanks for using Fixya.
Jun 14, 2009 | E-Machines (308714) Motherboard
I have assemble a new PC with VGA Card (PCI-E) but doesn't work
Yes , you need the extra power adaptor to your video card.
I would contact the seller or go to your local computer store taking the video card to make sure you get the correct adaptor.
Apr 17, 2009 | MSI N9600GT-T2D512, PCI Express Video...
EMachines T3830 PC Desktop - HOW TO INSTALL A VEDIO CARD
There are a couple of things it could be. From simply checking the cable on both ends (computer to monitor) to see if they are loose. It could also be the card is damaged. I would check it with a second monitor to be sure.
Oct 13, 2008 | E-Machines eMachines T3830 PC Desktop
Computers & Internet Logo
179 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
