Question about LG DLE2512W Electric Dryer
Humming noise on an LG DLE 2101W shuts off after a few minutes and filter warning indicator is on
Filter indicator light is on but filter is clean
3 Suggested Answers
stradeteox
  • 88 Answers
SOURCE: Your LG Did you get this problem fixed?
This is normal. This is just a reminder to check the filter at the beginning of each load. The LED is not connected to any sensors and is just there as a reminder only.
Posted on Jan 07, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Posted on Dec 23, 2009
I have LG dryer model DLE 7177 RM my dryer has power indicated by the drum light but nothing else has power except the drum light, what might cause this
Unplug it and wait a minute, then plug back in. This is my first line of defense, then all I know, is I won't buy another LG for my home. No one wants to work on them or they don't know how. I own 4 LGs in my home, 2 have had issues....grrrr.
Dec 21, 2010 | Dryers
Loud humming noise near fuel tank and loss of
Yes, this is indicative of fuel pump failure. It will need to be replaced.
Feb 24, 2018 | 1989 Honda Prelude
Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
Jan 07, 2010 | LG DLE5977 Stainless Steel Electric Dryer
Sanyo plv z2000 warning led it shutdown
Check all the fans if its working or avoid anything that cover the exhaust fan, or the temperature of your room.
Oct 23, 2009 | Sanyo PLV-Z2000 Projector
Candy CIV60 Tumbledryer - Reverse Action not working?
this could be something caught in the blower housing fan blade but what it sounds like is the motor is going into thermal overload (overheating)
Sep 01, 2009 | Candy CDC266 Dryer
LG DLE5977W dryer has stopped and developed a motor hum. How can I fix it?
I am assuming that the hum indicates the motor is running but the drum is not turning.  Possibly a broken drum belt however the check filter warning is indicating low air flow so the blower wheel could be broken at the connection to the motor shaft.
Jun 01, 2009 | LG DLE5977 Electric Dryer
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Oct 20, 2008 | LG DLE5977 Electric Dryer
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
LG DLE2512W Electric Dryer Logo
26 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
