Our samsung hl-t61878 will not turn back on after its warmed up, if you leave it on it is fine, if you turn it off , it will not turn back on
The tv will stay on all day and night, however if you turn it off after 1 hour or 48 hours the power and led lights come on with tv lamp but no picture?
  • 395 Answers
SOURCE: JVC TV lamp indicator light blinking new lamp
if you purcased a LTI lamp then the possibilty of a bad lamp may be the case. LTI lamps are cheap and are poorly manufactured. if it is a JVC lamp then you may have further problems such as lamp balast, or thermal sensor. clean the fans and filtersfor better air flow. keeping the lanp cool is important for the life of the lamp.
Posted on Apr 19, 2008
welcomejee
  • 10594 Answers
SOURCE: sony kv32dx30u led flashes 5 times no picture
5 times flashes is error of White Balance and its cause is defective part in Picture Tube (CRT) board or CRT itself.
Posted on Nov 06, 2008
asnowman
  • 788 Answers
SOURCE: installed new lamp/how to reset the lamp hour meter on samsung (HL-S4666W)
Here is the procedure for resetting the lamp timer.
This is a quick reference guide to show you how to reset your Samsung DLP TV’s lamp hour meter or hour counter. Resetting the counter is a very simple procedure.
Begin with the TV powered off.
Point your remote towards your TV.
Press:
Mute + 1 + 8 + 2 + Power.
Your TV set should now say “Loading Factory”.
Browse down to “Option” then press Enter (or the right cursor button).
NOTE: The Mute+1+8+2 buttons needs to be pressed down consecutively and fairly quickly. If your TV does not enter the service menu after using this combination, you can substitute MENU instead of MUTE. This seems to work for some sets. Also, the right cursor arrow also acts as the ENTER button, so try it if you’re having difficulty with the ENTER button.
To exit the service menu, hit press the EXIT button or just turn off your TV (remember not to turn on your TV immediately afterwards!).
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jun 01, 2009
ladywinn
  • 5138 Answers
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Posted on Sep 27, 2009
ladywinn
  • 5138 Answers
SOURCE: Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
Posted on May 01, 2010
Samsung hl-t61878
It sounds like the DLP Chip might need to be replaced. Its not the easiest thing to diagnose and a repair specialist might be best but this is a link to the part and its the best price I have seen.
http://www.buynesp.com/mitsubishi-samsung-toshiba-4719-001997-chip-p-16925.html
Mar 05, 2012 | Samsung DLP HL-P4663W 46" Rear Projection...
I HAVE A 50'dlp SAMSUNG TV-HL-S5087W THAT TURNS OFF
probably a bad (intermittent) control board.
Nov 14, 2009 | Samsung HL-S5087W DLP TV
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
Samsung lcd tv
if it was me i would turn off complety stand by just means theres still power going to tv but nothing is running
May 28, 2009 | Samsung HL-R4264W 42" DLP HDTV
HL-S5687 DLp tv
your keeping a part that is warming up and shuts down your shutdown that protects the tv from burning up... cooler... to find this you might need a hair dryer or a can of freeze mist.
I believe the left side is your high-voltage section.
you can also let it warm-up without the fan .. let it shut down and feel parts with set unplugged to see what is running hot.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-R5087W 50 in. green tint
usually that means you have external speakers to close to tv and magnets in the speakers do that
Apr 17, 2008 | Samsung HL-R5087W 50" HDTV-Ready...
HL-P5063W Green lines when the tv warms up
My Samsung DLP is having the same problem.  Not sure what to do, but I will contact my warranty place for the second time.  Hopefully they'll fix it.  Any other suggestions?
Mar 23, 2008 | Samsung DLP HL-P5663W 56" TV
T.V. TURNING OFF AFTER ABOUT 5 MINUTES.
Go to Samsung.com for solution. There is a switch that just needs to be repositioned behind access door on rear. Fixed my HL-S5086W ok.
Feb 13, 2008 | Samsung HL-S5086W 50" HDTV
Samsung SP43W6HPX\XEU Rear projection
HLP, HCN HL-S The Start-up Problem or/and
3 LEDs in the front blinking.
Unplug the set, pull out the lamp module (not all the way - leave it on the track) and push it back in.
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Oct 25, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HL-S5679W
i GOT TIRED OF FIGHTING IT, AND JUST LEAVE IT ON ALL THE TIME, SINCE MINE WILL TURN OFF CONTINUOUSLY FOR THE FIRST 3 HOURS OF TRYING TO TURN IT ON, SO BY THE TIME IT IS ABLE TO STAY ON FOR THE DURATION, YOU DON'T NEED IT ANYMORE, SO JUST LEAVING IT ALWAYS ON, IT IS READY WHEN I WANT IT. WHAT A PAIN.
Aug 10, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
