Question about Oster 0.7 Cu. Ft. Compact Microwave
Set up Oster Microwave
I got a new oster microwave as a gift. When I set it up, do I remove the foil covered type cardboard right side panel inside the microwave? It covers a hole. I am not sure if I need to remove it or not.
Model # OM1101NOE I just bought an oster micro and was wondering if the cardboard/foil looking piece on right side should be removed before use?
  • 3 more comments
  • tishanaellis
    tishanaellis Jan 11, 2013
    What happens if you rip it taking it out? Can it be taped back together of does a new one need to be purchased?
  • Anonymous Mar 22, 2014
    Is it save to use it without a screw or bracket? How can I get the missing part?
    can we still use the microwave with out the clip in the wave guide?
  • Anonymous Mar 29, 2014
    the cover that circulates the microwave within the cavity of unit.
  • Anonymous Apr 01, 2014
    I have an oster 1.4 cu ft countertop Microwave, Model OGG61403. The piece of cardboard "thingee" that covers the waveboard is broken. How do I replace it. Also, the microwave is only 8 months old. The machine stop working a week ago. The power blinks in and out whenever I open and close the door. What is the problem.?
  • Oster Master
  • 9,098 Answers
No, that is the "waveguide cover".
It provides very important protection for the magnetron.
And always keep it clean according to your manual's instructions.
Posted on Jan 18, 2009
Oster microwave turntable will not turn, food on one side is hard as a rock
hi suzanne.
If the glass tray in your microwave doesn't turn, it may be due to a broken drive motor. Most units have a round glass turntable which has a motor driven coupler and roller guide turning the tray. To access the motor, first unplug the microwave and remove the bottom panel.
How to Repair a Microwave Tray That Will Not Turn - PartSelect
microwave turntable will not turn Google Search
Nov 07, 2017 | Oster Microwave Ovens
The fan on the one day old Oster Microwave runs after finished cooking. All cardboard has been removed.
It is supposed to run on and will stop on its own as long as the door is closed. The purpose is to remove steam and condensation, plus smells from the cooking cavity and cool down the magnetron (the part that emits the microwaves).
Nov 23, 2016 | Oster Microwave Ovens
Torn wave guide
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
You didn't mention your brand or model number, but since you posted under Oster, I'll assume that's it.
You can contact Oster via the information in your owner's manual or get their contact information from the dealer where you purchased the oven.
Nov 27, 2012 | Oster 0.7 Cu. Ft. Compact Microwave
How to change a fuse in oster microwave oven
Unplug microwave, remove top," several screws" look to the right where the keypad control board is, now look down where the printed circuit board is, fuse should be near by clipped in, pop fuse and replace with same current rating, assemble before testing, "lethal voltages present"
Apr 21, 2012 | Oster OGB61101 Microwave Oven
Microwave starts randomly
No! manufacture defect, take it back asp for replacement, your warranty should have no issues covering this.
Mar 23, 2012 | Oster Microwave Ovens
I accidentaly torn the waveguard cover for my new oster microwave. Its torn about half way across but still can remain in place. Is it safe to use the microwave?
The waveguide cover will need to be replaced.
You can contact Oster at the number in your owner's manual to see where you can order a new one.
If for some reason you do not have your manual, try 1-866-866-6283.
Jan 31, 2010 | Westpoint TV-201 Microwave Oven
Microwave keeps shutting off
The magnetron is overheating, tripping the thermostat, which shuts off all power until it cools down.
This is usually caused by a blocked air vent, failed internal cooling fan, or failing magnetron.
If it's out of warranty, I'm sure you'll find it's uneconomical to repair, even if you could get parts for this brand.
Good luck.
Dec 26, 2009 | Oster Microwave Ovens
Oster 1.1 cu. ft. Stainless Steel Combination Microwave Grill - OMW1199
After six months I just figured it out. Push the cook by weight button in and hold it until the clock function comes on. Turn left for hour and right for minute. Figured this out by holding the cancel button in and a child lock came on, I didn't know how to release it so I reversed the process by holding it in and it cleared. I tried it with the cook by weight, which has a small clock icon next to it and voilla.
Oct 26, 2008 | Microwave Ovens
Changing light blub of oster microve oven
The lamp is located under the stainless top cover of the microwave which unscrews from the back and sides, the bottom corners in the back have special torx screws which are meant to thwart you from removing them but a pair of locking pliers does the trick. Then under the cover on the top of the microwave there's a black elliptical shaped base with only 1 screw holding it down, that is the lamp. Pull the female spade connectors from the lamp, unscrew it and take it out. Oster has about the worst customer service around so i have not verified that they will sell a replacement lamp but if you can find a 20W 120V replacement with spade connectors that will do.
Jan 15, 2008 | Microwave Ovens
Oster 0.7 Cu. Ft. Compact Microwave Logo
1,309 people viewed this question
Top Oster Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
ray gallant
Are you an Oster Microwave Oven Expert? Answer questions, earn points and help others
