10 yrs ago replaced heat exchanger and burners, changed filter at least every 90 days, more in the winter months in the last week motor ( I'm assuming the blower motor) has gotten louder. Sounds similar to looping diesel motor. I'm thinking the motor is going bad, I've tried to find diagrams of my furnace but have not been successful. 1st question, Does this sound like blower motor starting to fail? 2nd, How hard is this to swap out? 3rd, Where do I get motor? Thanks for your help, George Toledo Oh
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem...
(More)
Aprilaire Humidifier Mod 450-high whine from recirculating pump. Oiled motor per spec-same problem exists- Thanks, Richard
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on...
(More)
I have my Honeywell Chrontherm III set on adaptive intelligent recovery. It is set on "Leave" at 58 degrees at 7am and "Return" at 66 degrees at 4pm. The unit starts heating the house at 12noon to move it 8 degrees. According to the directions it should only kick on a max of 24 minutes per degree not 4 hours - any suggestions?
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and...
(More)
MY TruIAQ will read outside settings, and other times there are no readings for outside temps and humidity. what could be wrong?
i just replaced solenoid and humidistat onn my furnace himidifier but when i turn on humidistat to...
(More)
i just replaced solenoid and humidistat onn my furnace himidifier but when i turn on humidistat to outside temp,and the blower turns off ,the humidifier water still comes into humidifier and wont shut offf unless i turn humidistat to off position
