Question about Campbell Hausfeld Air Tools & Compressors
Campbell Hausfeld "ironforce" 1/2" impact Tool IFT602 Impact
  • 256 Answers
SOURCE: air impact tool does not engage but will eventually engage after switching directions.
Although I do not have a Craftsman, I have taken severl othe brands apart. They all seem to be much the same. You do not need specialized tool. You just have to be mechanically savey. I think the grease has thickened up too much so taking it apart and cleaning it should do the trick. Start at the working end end and separate the front end. Work on a clean bench where little items (screws, ball bearings etc) won't roll off and get lost. When the two parts are separated, you should see the hammer mechanizm and a lot of grease. remove and clean everything that you can. Re-lube the mechanizm with a light lube grease and re-assemble. Turn the socket drive by hand to make sure everything is free, then apply a liberal application of air tool oil to the air port of the gun and attach an air line and give it a try . Put a load on the socket to check for impact functioning properly. I hope this helps
Posted on Jun 02, 2009
  • 11 Answers
SOURCE: Craftsman 1/2 inch impact air driver leaks air
put a bunch of hydraulic oil in it and this will lubricate the seals inside to form a more uniformed seal it will stop leaking air.
Posted on Sep 04, 2009
SOURCE: want to re assmbly it
I took it all apart and cleaned it all, reassembled,oiled it and now it is as good as new.
\Thanks for your interest
Posted on Nov 10, 2009
  • 12 Answers
SOURCE: Campbell Hausfeld 3 1/2 framing nailer bends the nails
It is not the best brand but, it should work for a few projects. Increase the air flow and make sure it is lubercated. It is designed to shoot nails into soft wood, like pine. It could be a o-ring blown or damaged, which is easy and inexpensive to repair. Good luck. Phil.
Posted on Dec 03, 2009
SOURCE: Dont know where to put oil in Craftsman 1/2 " Impact wrench
I just bought one of these also. Manual says oil goes into "the air inlet" which I'm thinking is where you attach the hose. That way the oil is sprayed throughout the interior of the gun once you run air through it.
Question for you: I can't get an impact socket onto this gun, almost seems like the square hole is too small. (yes, both are 1/2" drive). How do you get a socket on this stupid thing?
(man that sounds like I'm an idiot, but I've spent a half hour leaning all my body wight, wiggling, etc. and can't get a damn socket on)
Posted on Jun 20, 2010
Product - Campbell Hausfeld TL1017 Butterfly Impact wrench I need a set of plastic valves. Where can these be purchased?
1-800-444-3353. This number is in the manual should you need some technical advice. I'd give them a call and see if they will mail you what you need. Can't find you a rebuild kit out on the net.
Sep 18, 2011 | Campbell Hausfeld TL1017 3/8" Butterfly...
I have a Campbell Hausfeld PL1502. Air flow from the compressor is good, it won't go forward or backwards, won't even try. Air just whistles through it. I took it apart and didn't find anything obvious,...
oiling thing? thats the easy part,,its oiled every time you use it,
now it wont start then,,,ok its jamed up or the air flow and presher is to low for it,,,look under the handle were the hose fits to the gun there should be a big screw there on this screw there should be 1-2-3-4? turn it to 4,,now try it???
Aug 18, 2010 | Campbell Manufacturing Campbell Hausfeld...
Need info & Manuals please.
here are the sites where you can get schematics for both and manuals I'm sure you'll find what you need right there.
if it works for you, don't forget to rate me
thx
May 26, 2010 | Campbell Hausfeld 1/2" Impact Wrench -...
1/2' Impact wrench does not work.
Yes,Just look up a seal kit for your brand on google
Jun 01, 2009 | Campbell Hausfeld Air Tools & Compressors
Parts Diagram for TL1017
I haven't tried this yet but will when they open., depending on part price. I am going to get part numbers 31 and 32. http://manuals.harborfreight.com/manuals/93000-93999/93100.pdf
May 22, 2009 | Campbell Hausfeld TL1017 3/8" Butterfly...
I NEED A DRAWING THAT WILL ENABLE ME TOREASSEMBLE
Go to chpower.com and search for your model there. Campbell Hausfeld makes the Husky line for Home Depot. Sometimes they are limited runs on certain products and you will not find any information about those tools. Its worth a shot to contact Campbell Hausfeld to see if you can get a breakdown for your tool. They do have an email and phone contact on their website. The power tools phone number is 1-800-424-8936. Good luck.
Apr 20, 2009 | Air Tools & Compressors
Feb 21, 2009 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
Campbell hausfeld fram. nailer sn: 289000
there is a brad nailer on ebay for $19.95 or best offer the id is 400005899316.
Or you can try this seller he has quite a few rebuild repir kits for this type of tool
130154093399 that is a link to one of his auctions check out the others as well.
Nov 17, 2008 | Campbell Hausfeld 3 1/2" Rh Fram Nailer
Impact wrench problems
Six routines must be followed in order to minimize the chances of your hydraulic equipment suffering costly, premature component failures and unscheduled downtime: * Maintain fluid cleanliness; * Maintain fluid temperature and viscosity within optimum limits; * Maintain hydraulic system settings to manufacturers' specifications; * Schedule component change-outs before they fail; * Follow correct commissioning procedures; and * Conduct failure analysis.
Aug 27, 2008 | Campbell Hausfeld SNUBNOSE 1" IMPACT...
Air Tools & Compressors Logo
144 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
