Question about Mr Steam MrSteam MS150E Steam Generator
No wtr or htr lights on mr steam unit - Mr Steam MrSteam MS150E Steam Generator
4 Suggested Answers
SOURCE: error code Prr
I had this problem, and checked the connections, emptied the resivour, and refilled it, and it had no effect.
To fix the problem, I ran the regular shower on hot for 10 minutes to warm up the shower chamber. Then, when I pressed the power button on the steam shower, it displayed "110" as normal.
The problem with "Prr" appears to be that the temp sensor is reporting a value out of range. Heating the shower chamber (and therefore sensor) provides a good value to the sensor, which then allows the shower to operate.
Try warming up your sensor by running the shower.
Posted on Mar 06, 2010
SOURCE: Mr. Steam steamer is inppoerable
I just got this problem too, any solutions or a link to the manual?
Posted on Aug 12, 2010
SOURCE: Mr. Steam Prr erro
my mr steam goes on by itself sometimes in the middle of the night...or in the day....why does this happen
Posted on Apr 14, 2011
I've replaced the thermocouple in my gas heater, but as soon as I release the button to activate gas it goes out.
if wtr htr is equipped with fan motor..at exhaust or damper..check the motor..or call rheem tech support at # located on wtr htr
Oct 29, 2013 | Water RHEEM 40 Gallon FVR PROP PWR Heater...
The steam shower reads no wtr
the water valve is stuck closed i.e. "no wtr" = no water
Sep 30, 2013 | Thermasol Steam Bath Generators - Ambiance...
I have a Mr. Steam unit installed in my shower room. When i turn the steamer on it sounds like it is working and the lights are on but no steam coming through!!
Hi I am with Mr. Steam Tech Support please call 1-800-767-8326 and ask for tech support we will also need you model and SN that are located on your steam unit
Nov 27, 2010 | Mr Steam Hardware & Accessories
Water heater does not seem to be cycling right continues to light then go off and light and go off
might have to change regulator..where control is if water htr lights heats water n then goes off..that the problem should check wtr heatr front for 800 number to see if warranty is still good..because it is expensive to buy
Nov 22, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
The unit turn on but does not always produce steam. is it the unit or the temperature gauge?
Hi I am with Mr. Steam tech Support, please call 800-767-8326 for help we will need your model number and serial number you can ask for ext 1288 or 1275
Thank You
Nov 02, 2010 | Mr Steam Hardware & Accessories
We just moved into a house with a MS150 Mr steam. I turn it on and the display reads 110 for 10 mins then comes up with H2O on the display. What do I have to do? Nothing seems to happen.
Hi my name is Mike with Mr. Steam please give me a call at 1-800-767-8326 and ask for tech support. We will need you model # and SN # that is listed on your unit if you can be by your unit when you call and we will help troubleshoot your unit. In the mean time check the following 1) water is on 2) drain valve closed even if you have a auto flush close manuel valve for testing
Thanks
Mike Nail
Mr. Steam
Sep 18, 2010 | Mr Steam MrSteam MS150E Steam Generator
Pilot light won't stay lit on whirlpool wtr htr model #FG1H4040T3
it sounds like you may need a thermo coupler the old one isn't telling the pilot to stay lit.
Dec 23, 2009 | Home Fencing
Mr. Steam Prr erro
Hi, kindly check the connection of your temperature probe down to the main board maybe its loose.
Oct 03, 2009 | Mr Steam Mr. Steam MS 81500E AutoFlush
When I turn on my steam unit it powers up takes
go to the following link
http://www.manatron.net/Pdf's/Sussman/residential.pdf
the manual may help you with yur problem.
it is hard to say what is wrong without looking the actual unit.
Apr 06, 2009 | Mr Steam Mr. Steam Allegro Sauna Model...
Mr Steam MrSteam MS150E Steam Generator Logo
Top Mr Steam Electrical Supplies Experts
BJ Russell
Hippy_dd
Are you a Mr Steam Electrical Supply Expert? Answer questions, earn points and help others
