Question about Welding Tools
Lincoln mig welder
Welder dose not feed or ark
  • brophats Feb 20, 2009
    i have mac version of this welder and i have the same problem and i'm not sure where the fuses are but the circuit breaker isn't blown and fan runs constantly like the thermostat is tripped, where is the thermostat?
  • 92 Answers
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
Posted on Jan 23, 2009
  • Ron Jones
    Ron Jones Jan 23, 2009
Porblem with lincoln mig welder 135
Use a voltage tester to make certain you have current at the steel roller assembly that the wire feeds through. Check the diameter of the wire also, to assure contact at the feed rollers.
Mar 18, 2012 | Lincoln Electric Welding Tools
How do you switch the polarity switch on the 115 farmhand versa-arc mig welder. trying to switch from mig to flux core wire.
Hi:
Disconnect you ground clamp form the negative side pole and switch it to the positive pole, same for the gun disconnect the from the positive side and switch it to the negative pole.
Good luck.
Sep 07, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
I have a 125 lincoln wire feed welder. wire will feed but will not arc to weld
check you ground cable, try to strike and ark on the ground cable, if no ark test the ground circuit if the circuit is ok you will need to have the transformer tested and for that you need some specal tools.
Aug 28, 2011 | Lincoln Welding Tools
Im looking into getting a mig and have come across the century (by lincoln) welders for 299. is this a quality welder and of same quality as a Lincoln brand.
No, it's not going to be equal to the Lincoln in all ways- but if Lincoln built it it'll be a decent machine.
In all honesty, if you can only have one welder it should be a stick welder. Mig welders are full of problems and, while ideally suited to 8 hour a day 7 days a week use, can be finicky as heck when used infrequently.
The stick welder allows you to work in all positions and all conditions, it's generally cheaper than Mig welding and it's usually faster.
lp
Jan 01, 2011 | Lincoln Electric LE 83180 Century...
No ark
no ark
prolly means no bible
Aug 15, 2010 | Lincoln Electric LE 83180 Century...
Will feed wire but will not start an ark to weld
Make sure that the ground clamp is securely fastened to the workpiece.
Ensure that the power pin is fully seated into the housing where it receives the current.
Ensure that voltage and amperage settings are correct.
May 04, 2010 | Hobart 500526 Handler 210 Professional...
Where can i buy a new switch for a Lincoln MIG welder CV-305
From your local Lincoln welding supplier or lincoln direct.
Nov 28, 2009 | Lincoln Electric LE 83180 Century...
What is required to switch from steel to gas on light duty mig welders
if you mean from flux core wire to gas shielded wire you will need a tank and regulators,and feed hose from the welder to the tank
Sep 06, 2009 | Lincoln Electric LE 83180 Century...
Owners manual for a century wire feed 83160 mig welder
I believe century was bought by lincoln. call 1-866-236-0044 ext 3. Ask for century parts.
Paul
Apr 19, 2009 | Lincoln Electric LE 83180 Century...
Welder feeding or arking
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
Jan 18, 2009 | Welding Tools
Welding Tools Logo
433 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
