Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Mr coffee model skx23 won't start
The clock is pulsing 12:00 very dimly. The green start light won't come on. It is 2 weeks old and worked until now. This is the 2nd machine. I returned the 1st one, which did the same thing after a couple of weeks.
  • 1214 Answers
SOURCE: Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Posted on Jan 30, 2009
  • 112 Answers
SOURCE: maker clicks on, but doesn't perk or heat the plate.
Unlike older coffee makers, the new Mr. Coffee designs seem to have reliability issues in regard to their circuit boards/controllers. You are right in your thoughts. If the unit is under warranty, I would suggest returning it for a replacement. E-mail your concerns directly to the company.
BTW--there are no user serviceable items within your coffee maker.
Posted on Mar 26, 2009
  • 56 Answers
SOURCE: manual for Mr Coffee Bread Machine
http://www.foodsaver.com/manuals/MrCoffee/5810%20Breadmaker%20Recipe%20Book-color.pdf
there is a link for the mr coffee breadmaker
Posted on Apr 04, 2009
buffalonyman
  • 1865 Answers
SOURCE: Mr. Coffee FTX23 quit brewing
The heating element burned out, its a common problem. Mr. Coffee tend to leak, I've had several of them.
Posted on Jun 10, 2009
Coldcut
  • 1554 Answers
SOURCE: our Mr. coffee 12 cupper that we've only had for 5
What do you like or don't like about this Product?after using this pictured maker for a year or more , cleaning regularly it will still have wet gunk buildup above the tank on a ledge behind the dial. if you manage to get liquid clear up to that level you can short out the electronics as there are 2 screws there an unsealed electronics. only dissembling the coffee pot will allow you to see the offending gunk , mold , mildew an sludge you would never want to drink. and very much alive since you add water an let it set all night . this model should have come with the middle tank removable an needed to be totally redesigned. if you have one of these over a year old toss it as your endangering your health very very much....... Coldcut <<<my handle
Posted on Mar 03, 2010
Mr. Coffee SKX23 will not brew. Worked fine yesterday and buttons/light works just fine. I noticed there were comments recommending running vinegar & water to clean the pump, but if it doesn't pump how...
There is a fusible link in the wires going into and out of the circuit board. If you have a continuity checker it's an easy fix with a new fusible link at Radio Shack for about $2.00. Soldering gun and some wire and you're good to go, if that's the problem.
Jan 22, 2015 | Mr. Coffee Coffee Makers & Espresso...
My Mr Coffee model #CJX21CP 12 cup started by being hard to turn on and now wont turn on at all but the clock is working any ideas?
I don't have a solution, I have a question. Both of the high Temp.
tubing's are cracked and leak and need to be replaced, where do I get 2 new ones for Model CJX21CP Mr. coffee does not offer any of these parts. Help!!!!
Aug 06, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. coffee died
got the same problem, im going to take it apart and look at the electronics. im sure its due to water getting in there
Jul 01, 2010 | Coffee Makers & Espresso Machines
Set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Dec 30, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Mr.Coffee maker (quite new) won't make coffee
This is still under warranty, I would return for a new one. You could also call number in manual, they will probably replace it.
Jun 09, 2009 | Mr. Coffee TFTX85 Coffee Maker
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
We have a Sunbeam coffee maker almost 3 months old and has been a problem after 1 month use. We bought a Mr. coffee and it,s around 6 weeks old and both are a big problem while trying to brew coffee,they...
my suggestion is spend some good money on a coffee pot or get a french press and a hot pot. those mr. coffee and sunbeams are nothing but trouble from my experience.
Sep 20, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
