Question about Tools & Hardware - Others
Engine will not switch off nor will start from ignition.
I have an John Deere 214 tractor. The original engine on that tractor was an Kohler 12 hp engine. That 12 hp engine lasted for 30 years. I cannot complain. While searching for another 12 hp Kohler I was informed that Kohler dropped these 12 hp engines. I wasn't about to shell out 1500 bucks for a rebuilt. These were quotes provided from several John Deere dealers. What a scam. Six years ago I upgraded to an Briggs and Stratton Vanguard 16 hp twin. The cost was reasonable and I could't pass it up. Personally I still do not care for Briggs products. I never had much luck with Briggs. When I purchased this engine I inquired about changing the ignition system in accordance to the Briggs. The original systems is John Deere. The person who sold me the Briggs thought that there would be no problems. Basically most of the ignition systems are compatible. I never had any problems since i had installed this engine. I haven't had the tractor running for almost a year. The reason was that I was waiting for parts for the trans axle. It was 2 weeks ago I finally got it together. Then this problem occurred with the electrical. Three days ago I replaced the battery. After replacing the battery one of the wires had touched the throttle cable. That cable become red hot and it penetrated directly to the carb. I didn't realize there was another hot wire. I do not know where that one was suppose to go. Was it for the P.T.O.? I am lost. I started the engine. The engine worked great. The problem was that the engine would not switch off. The engine kept running. To switch the engine off I had to shut the gas valve from the gas tank. I have a hunch that an electronic component was possibly fried that wire. Yet the engine starts and runs without any problems. The engine starts directly from the battery not from the ignition switch. The other problem is to change the current ignition systems from the John Deere to Briggs. I should have done. I use this tractor for snow plowing only. I do not have any attachments for this tractor I can recall speaking to a counter person from couple John Deere Dealers regarding the changes. I do know one thing that the counter guys do not want to speak to you. I had a couple of them telling me they will not help. I do know one thing I try to avoid these dealerships especially John Deere. I have this hunch that I probably have to replace an electronic component. That is a definite. I do know I have to replace the ignition switch, solenoid, relay or regulator and wiring harness. Question is if the electronic components are fried can the engine be operational? This engine is operational. What else should I check for? Any advise will be much appreciated.
  • 13 Answers
SOURCE: 23 hp engine will start great when cold, but after it run a short it will not start Brfiggs&Stratton vanguard V-Twin Vertical Ohv Engine start.
it sounds like a fuel starvation problem it is very possible theres a blocked vent in the carb. the carb will probably will need rebuilding not very difficult
Posted on Apr 09, 2012
  • 3 Answers
SOURCE: Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
Posted on Dec 31, 2008
  • 636 Answers
SOURCE: Briggs & Stratton 22 HP V-Twin won't start
Take it back , it is still under warranty if you just bought it.
Posted on Jul 25, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
miket756
  • 2702 Answers
SOURCE: I am considering purchasing a used Exmark with a
yep its a briggs and normaly there very good ploders
if your john deere spluters and back fires it needs a good looking at check the valves first,,,a hand full of bolts and the heads off and if your carfull you can still use the same head gasket again,,,also check the carb there very finiky and need to be kept clean the air filter is a joke,,,but clean it anyhow and they like new plugs,,,every ten years or so? iv worked on 100s of brigss and stratons/vanguard. there good engines but there ploders not sprinters there ok in a tractor but no good in a tank there to darn slow
Posted on Mar 28, 2010
John Deere 214 with Kohler K321
Check carby is not to rich,"mixture screw" check for fuel blockage on fuel tap.
Sep 27, 2016 | John Deere Garden
I have JD 214 that I've replace coil, points spark plug,wire yet still getting no spark the mower just quit run inspection I found that the points was burnt and plastic where power attached was melted
Wow, a tractor with points. That's rare these days. I believe your tractor was made between 1975 and 1987. It's a 200 series. Does it have the 14 hp Kohler?
Not sure about your problem. On a modern day tractor with electronic ignition, I would check the safety switch system. In your case, I would check the fuse, key switch, and look at the kill wire running off the coils to see if there is worn insulation. If you have seat safety or PTO switches check them too.
You can get parts here:
John Deere 214 Lawn and Garden Tractor Parts
Apr 16, 2015 | Garden
What point wires goes to hot and the ground on a john deere lawn tractor 214 kohler engine
The HOT wire goes to the contacts and the ground normally goes at the mounting screw
Apr 21, 2014 | John Deere Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
No spark to the plug Kohler 8hp lawnmower engine
Check ingition switch, check battery voltage 12-12 1/2 volts,check in run position same voltage, check in start position same voltage
We've check switch first. If not problem we've check the points for proper voltage and opening and closing.
Jan 17, 2012 | John Deere Garden
Tools & Hardware - Others Logo
91 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
