Question about Danby DIM1524W Ice N Easy Portable Ice Maker
On my Danby Ice N Easy portable ice maker there is fault sign on, my machine does not make more ice?
2 Suggested Answers
  • 61 Answers
SOURCE: i have a danby(simplicity) portable airconditioner,was working fine till i heard ice droping into the fan(crunching noise).after that,it does not blow cold air anymore.any ideas what the problem could
Is the fan no longer running, or is it now blowing room temperature air? If it iced up enough to drop ice into the fan it may have simply gone into defrost mode. Unplug it and make sure it has completely defrosted - if it ices up quickly when powered up again, you likely have a problem with the condenser lines.
Posted on Jul 14, 2012
How do you choose the best portable Ice maker?
The best portable ice makers are found in most local home appliances stores or in online stores. You can search for the least expensive by comparing prices, determine the average price and even discover available discounts. I think Sonic Ice maker is one of the best ice maker. But you must kept some points in mind before choosing the portable ice maker :
(1) The amount you can afford
(2) How much ice you need
(3) The amount of ice you want to store
(4) The sizes of ice cubes needed
(5) The kind of maintenance.
Sep 07, 2017 | Sewing Machines
Where can I buy a portable high capacity counter top ice maker?
There are many sites from where you can buy best portable-ice-maker.I would like to suggest one of the best ice makers which is suitable for everyone and easy to handle that is portable and counter top ice maker.This ice maker is very small in size and it can make larger quantities of ice in a very short period of time.
Apr 01, 2017 | Refrigerators
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Emerson icemaker gets hot checked it out it's the compressor can this be a reason why my machine want make ice
Heat cannot produce ice
How To Fix Refrigerator That's Not Making Ice ' Fridge Repair
www.partselect.com/Repair/Refrigerator/Not-Making-Ice/
Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common problems and parts like water inlet valves and water filters.
1 How to fix a portable ice machine part 1 of 3 - YouTube
? 8:44
https://www.youtube.com/watch?v=oyaO_Q6CBUM
Apr 18, 2009 - Uploaded by SteveJ619
Part 1 of 3 on how to fix your portable ice machine. ... Fanstopped working on mine, is it an easy repair? ... Dumping theice maker upside down can damage the refrigeration compressor ! .... Emerson Portable Ice Maker - Emerson Portable Ice MakerVideo Review -portable ice maker - Duration: 3:57.
Jan 07, 2016 | Emerson Refrigerators
LOST MANUAL - WHAT IS RED BLINKING LIGHT
What is the brand of your ice machine?
I usually get Scotsman doing this ,
Mostly it's because of the clogging of the air filter, and even after cleaning it needed to be reset.
To reset you need only to push the signal button for 5 sec.
And it's done .
Jun 08, 2015 | Danby DIM2500WDB Portable Maker White
Machine only makes ice cubes on a few coils
Without knowing the type of ice maker you have there could be several causes for this. Low charge, metering device problem, make up water constant fill or to warm. Need more info to help.
Jan 08, 2013 | Danby DIM1524W Ice N Easy Portable Ice...
Danby ice maker service manual
I took mine apart today and found the plastic armature that the motor connects to in order to turn the water tray right side up and up-side down was broken. Essentually the water tray has a plastic pivot arm on both sides. The one side has a slot that the motor fits into which allows the motor to turn the tray. When that little plastic arm breaks, the motor will be unable to move the tray thus causing the fault symbol. I have my tray out and trying to fabricate a part that will hopefully last a lot longer than the original. I hope this helps someone with their issue.
May 16, 2012 | Refrigerators
I HAVE DABY ICE MAKER DIM1524 AND THE FAN TO COOL
I REPLACED THE FAN AND THE ICE MAKER IS WORKING JUST FINE.
Jun 10, 2009 | Danby D9604 Refrigerator With Ice Box
Danby DIM1524W Ice N Easy Portable Ice Maker Logo
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
