Question about Roomba iRobot Scooba 230
Scooba 230 troubleshooting
I press clean button. After. Few seconds it uh-oh's and the red warning light comes on. Scooba will not start
2 Suggested Answers
  • 66 Answers
SOURCE: roomba stops uh oh beep and run light flashes with
please count the beeps and let us know of it
this tells you the kind of fault it has
look in your Roomba's user manual, this is all explained there ;-)
Avi
Posted on Apr 12, 2010
My iRobot Roomba 780 just won't start moving to do the cleaning. When I press the CLEAN button it moves back from the dock, turns 180?, and then moves forward about an inch and makes the uh-oh sound...
make sure all virtual wall lighthouses are turned off. Your Roomba may be getting a signal to not proceed if the lighthouses are turned ON and facing the Roomba
Feb 22, 2014 | Roomba 780 Robotic Vacuum
Scooba beeps 4 times
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle..
  • Dec 22, 2012 | iRobot 5800 Scooba Vacuum
    It starts and for a few seconds and then stops The battery is fine
    Is the charging ase turned on and is the dust container emptied? Any obstructions?
    Apr 11, 2010 | Roomba Robotic Floor Bagless Vacuum
    My iRobot scooba won't turn on after a full charge
    Do you have the charger terminal, or do you have the charger that you have to take out the battery and charge. Because I have found that my base terminal charger works better than the battery charger that needs the battery to be removed to charge.If you have the terminal charger and the power light is green when it is in the charger I would start from the terminal
    Jul 26, 2009 | iRobot 5800 Scooba Vacuum
    Can not charge thr battery
    bbaker58,
    When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
    If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
    Roomba Says
    What It Means
    What You Should Do
    Plays 4-note song as Power button blinks RED
    Play sound The battery is low and needs recharging
    • Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
    Play sound The Cliff Sensors are dirty or malfunctioning
    • Pick up your robot and turn it over.*
    • Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
    • Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
    "Uh-oh"
    A wheel is stuck or is not touching the ground
    • Lift the robot and place it down again.
    • Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
    The robot's main brushes are stalled
    • Pick up your robot, turn it over* and remove the wire guard.
    • Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
    The robot's Side Brush is stalled
    • Pick up your robot and turn it over*
    • Check to see if something is wrapped around the Side Brush.
    • Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
    • Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
    The robot's vacuum is stalled
    • Remove and empty the Dirt Bin.
    • Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
    • Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
    • Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
    Play sound
    The robot's Drive Wheels are stalled
    • Your robot may be stuck, or something may be caught in a wheel.
    • If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
    • If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
    If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
    “Uh-oh” plus 5 beeps
    The robot's Cliff Sensors are obstructed
    • Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
    The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
    • Pick up your robot, place it in the center of the room, then power it off and then on again.
    • Select the cleaning cycle you prefer and let it go to work.
    “Uh-oh” plus 9 beeps
    The robot's Wheel Drop Sensors have failed at startup
    • This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
    The robot's bumper is not registering obstacles
    • If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
    Jun 02, 2009 | Roomba Robotic Floor Bagless Vacuum
    Irobot scooba 5800 spins quickly then sets off backwards
    Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
    May 10, 2009 | iRobot 5800 Scooba Vacuum
    Roomba red 4100 cleans in small circle stops starts agains cleans small circle stops then status light comes on and clean button blinks.
    When the status light comes on, the Roomba is going to sing "uh-oh," and then beep a number of times. Count the beeps. They're a code that tells you what's wrong with the Roomba. You can check iRobot's website for a chart of beep codes. Search "What is Roomba saying to me?" on the troubleshooting page.
    Apr 06, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
    Stuck on check tank indicator
    If your Scooba's Green Check Tank light is coming on immediately on startup, please try the following steps:
    1. Remove and reseat Scooba's battery, ensuring that you hear it click into place.
    2. Remove and reseat the brush head
    3. Remove and reseat the vacuum port and filter. When replacing the filter, be sure to press firmly into the hole. There is a magnet on the filter that must connect with the magnet on the Scooba.
    4. Fill Scooba’s Clean Tank with approximately 1 cup of cold water, shake vigorously, and empty it to remove any debris in the tank.
    5. Empty the Dirty Tank, refill with water, and slosh it around to pick up any sediment. Empty the Dirty Tank again.
    6. Refill Scooba’s Clean Tank with water, adding a pinch or two of table salt. Run the Scooba. If the issue persists, please follow the steps below:
    With the tank removed, press the Power button and then the Clean button.
    If the robot tries to start a cleaning cycle, power off the robot and repeat, pressing the Power button first and then the Clean button. If the pump makes a “whirring” or squirting sound and the robot does not start a cleaning cycle (Check Tank indicator will light), this indicates that the pump is working. Replace the tank and try starting a new cleaning cycle with the tank on.
    If Scooba does begin a cleaning cycle the second time you press the Power and then the Clean button with the tank removed, the pump valve could be blocked with debris. Using a turkey baster, straw or sports bottle, force water through Scooba’s solution valve. Confirm that the baster, straw or sports bottle fits snugly over Scooba’s solution valve, push water through the system at least three times, and then try re-starting Scooba.
    Below is a link to a diagram of these steps for visual reference:
    Title: Scooba is not putting down cleaning solution
    http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=322&p_created=1167154849
    Nov 01, 2007 | iRobot 5800 Scooba Vacuum
    Scooba 5800 Power button Red Blinking
    You probably have the manual, but here's the link to the Scooba 5800 manual anyway - just in case this would be useful to you: --> http://www.irobot.com/images/homesupport/5800_Scooba_Manual.pdf You could use a voltmeter to check the battery, but only a few months use shouldn't be enough to wear it out. If you don't have a load-tester to verify the battery's load-capacity, then you can check the voltage drop. (Assuming you can get it to contact the Scooba's circuits.) To do this, just check the battery voltage, apply a load by inserting it in the machine and turning it on, then check the battery voltage again. An excessive drop in voltage may indicate the battery needs replacing. However, the red blinking light is Scooba's indicator that it doesn't detect the battery at all. The first thing to do in this case is to clean the electrical contacts on the battery and in the Scooba. Use a damp cloth and a bit of toothpaste to rub the contacts clean on the battery and in the machine. (Toothpaste has mild abrasives in it and will clean the electric contacts without damaging them.) Make sure that both the battery and the Scooba are clean and dry before re-inserting the battery. Also, if the electric contacts in the machine are flexible matal tabs then verify that the tabs are standing up high enough to make good contact with the battery contacts. Hopefully the battery just needs it's contacts cleaned for your unit to work, but test the battery if you are sure that they are clean and seated properly to the contacts in the machine. If the battery appears to be failing, then contact www.irobot.com to cheack and see if they are still covered under your machine's warranty. Hope this helps! :)
    Aug 06, 2007 | iRobot 5800 Scooba Vacuum
    Roomba iRobot Scooba 230 Logo
    Top Roomba Vacuums Experts
    Lonnie Arks
    D. E. Hev
    Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
