Question about Dishwashers
Maytag dishwasher MDB6100AWW making grinding noise at the end of drain cycle. Any suggestions
5 Suggested Answers
SOURCE: Loud noise at end of Draining
If your dishwasher seems noisy, check these:
1. Water-inlet valve
2. Motor
3 Heater fan
4. Pump
Water-inlet valve
An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor
If it's the motor that's noisy, either of these may be the "culprit:"
As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan
If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump
Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
good luck
thanks for using FixYa
Posted on Feb 11, 2009
  • 423 Answers
SOURCE: LG Dishwasher LDF7811 Making Growling Noise
Recommendations:
-Switch to a brand name detergent powder - like Electrosol or Cascade and do not fill the dispenser cup full. You will notice the difference immediately.
-Remove the filter assembly one more time and inspect underneath with a flashlight. Look closely for debris and also inspect the impeller to look for damage and that it is spinning freely.
Reassemble and listen for the growling sound. It should not happen. If it continues, you may have a a failing wash motor / motor bearing.
Please report back what you find. OK?
Posted on Apr 11, 2009
VtToolMan
  • 704 Answers
SOURCE: maytag dishwasher doesn't completely drain!
First check to see if anything has gotten into the sump drain inside the bottom of the dishwasher tub. Sometimes a piece of plastic wrap, or other small item can become lodged there, causing the DW to drain slowly.
If nothing there, check the air-gap device at the sink, as these can become clogged over time and that would also prevent proper draining. The air-gap is the round (usually silver chrome colored) cap mounted on the corner of the sink). Pull off the cap, it comes straight up with a little twist and polling motion. Clean out the screen filter and also look down the hose to see if there are any obstructions in the drain hose.
If that is OK, check the drain hose from the air-gap down to the connection at the sink drain, or if you have a disposal, where it is connected to the disposal. Sometimes small bits of stuff can get stuck in the hose at these various points and any build up over time, will make proper draining difficult.
You can also flush the drain lines with hot water to make sure the lines are clear. If none of this works, you could have something in the DW sump pump and that will require removing the DW from under the counter and checking the pump area for obstructions. Sometimes you can easily remove the flexible pump body and get at the drain valves. Just be sure to disconnect the power and turn off the water supply before removing the DW to attempt any repairs.
Hope you find this Very Helpful and best regards!
Posted on Aug 29, 2009
redneckrabbi
  • 35 Answers
SOURCE: I have a maytag quiet series 100 dishwasher and it makes a grinding noise as it washes the dishes. Any suggestions as to why?
Pump motor gear possibly
Posted on May 15, 2012
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Maytag Dishwasher MDB6100AWW - control panel short??
If you can take the panel out dry it with a blower.You can use the hair dryer to remove the moisture. Do not point the hot air on the components for more than 20 seconds. Repeat it. If you notice any white/green fungus remove it. Check the connectors also.
May 17, 2010 | Dishwashers
Grinding noise
grinding noise normally comes from drain pump or a circulation pump, a tech has to see which one it is .or if you want when it goes in drain mode see if you hear it then,if not then it the other. let me know if i have been of some help.
Feb 24, 2010 | Dishwashers
Dishwasher is making a loud grinding noise when it's started. Doesn't matter the cycle choice; the cycle starts as normal then once started up starts making a sort of grinding noise as the water is...
the only thing that can make that kind of noise is a broken/damaged pump/motor.
below is a manual for part discription & a vid' showing how to carry out a repair.
however if you are not "handy", you're gonna have to pay for a repair service.
https://www.manualslib.com/manual/837834/Maytag-Jdb4000aw.html?page=3#manual
https://www.youtube.com/watch?v=yUpR_WRpBWU
Apr 23, 2017 | Maytag 24 in. MDBH970AW Built-in...
Maytag dishwasher legacy 300 quiet series
Check for foreign objects like glass or plastic at the grinder blades. Some dis assembly will be required. See appliancepartspros.com for diagram.
Mar 22, 2009 | Maytag 24 in. MDBH955AW Built-in...
Diswasher motor making noise during wash cycle
It could be the impeller on the motor. The impeller fits over the shaft of the motor and might have split/broken up. That funny noise is probably the shaft spinning inside the damage impeller. Fortunately the impeler is fairly inexpensive and easy to replace. I believe there are one or two parts/covers to remove that are held in by a roughly half dozen torx screws.
Jan 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher loud in beginning cycle and drains early
sounds like you have 2 problems however generally speaking (most makes) of dishwashers go into drain mode when there is a fault elsewhere, however is this set up properly, is the waste pipe end high enough to allow the water to actually fill up (only about 30cms of water aprox)so it doesn't flow straight though to the waste. the noise could just be an empty pump, it runs dry after a while, and makes a screeching noise eventually? check installation pictures to see if its set up right, you may have also a leak somewhere check all other connections and pipes
Sep 21, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
Owen Barnes
