Question about Audio Technica Audio Players & Recorders
Atw-r03 mic making interference noises and cutting out... any advice?
3 Suggested Answers
kol_easley
  • 20 Answers
SOURCE: HELP
u can go to guitar center and but a new one
Posted on Jul 29, 2008
SOURCE: wireless noise
this is a very cheap unit but yes squelch is a factor.keep, fiddling with it.Very seldom do bass/guitar players like wireless.
Posted on Mar 21, 2010
Microphone cutting out during use
reduce distance between receiver and transceiver (microphone)
Adjust antennas not parallel.
Apr 09, 2014 | Audio Technica Audio-Technica ATW-T701...
Audiotechnica atw 3110 with lavalier mic at 898 on wire instrument usualy works fine but on stage wery often sound form instrument with it start to transmit dirty sound some distorsion, like two untuned...
try changing frequencies, also make sure that the mic and the reciever are on the same frequency, what it sounds like to me is that it is set to the adjacent frequency, also be sure the batteries are fully charged.
Mar 14, 2011 | Audio Technica ATW-RC1 3000 Series...
Mic receives a lot of static and then cuts out. After a few seconds it seems to repeat.
This could be due to interference from other devices.
You could try changing to a different frequency (there are 20 to choose from).
Also move the receiver away from any strong electro magnetic fields (hearing loop amplifiers, CD/DVD players, TVs) or large pieces of metal and in clear line of sight of the transmitter pack.
Set up the aerials so that they are at a similar angle as the aerial on the transmitter.
Only use xlr balanced cables with good quality screening to connect the receiver to the mixer / amplifier. Keep signal cables well away form mains electricity cables as far as possible.
Wherever possible use balanced xlr cables on all other equipment.
Feb 13, 2011 | Audio Technica ATW-R11 Microphone
I have a atw-t52 audio techina wireless mic. And when i turn it on thr crackling begins to come through the speakers and i have to play with the input and output cable and move the base unit around and...
I have the same problem in my ATW T52, in st by its ok (the rf leds show perfect signal) but when i set in on the af level start punch and i hear in the monitor a noise like a heartbeat (pum-pum-pum....) Please any answer for this problem
German
Radio del Sol 96.3 Mhz
Villa de Merlo - San Luis
Argentina
May 20, 2010 | Audio Technica ATW-T52 Professional...
ATW-T52, hissing/crackling.
A common problem that SOME have is due to the foam windscreen inside the metal screen rubbing the diaphram of the mic.
Unscfew the dome screen and make sure the foam is out agaist the scree everywhere.
If the dome has become dented, this is my cure: Temporarily remove the foam sheet inside the dome. Put the dome over the handle of a Crescent wrench (has about the right contour). Pound on the screen with a RUBBER mallet, rotating the screen as it reforms! Good as new! Replace the foam sheet and reassemble!
Dec 20, 2009 | Audio Technica ATW-T52 Professional...
I have a audio-technica ATW-T51 and need to replace the cable as it makes a lot of noise. Where can I go?
to a web site called parts express.com you will find anything in audio related items there..
Nov 23, 2009 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
Wireless noise
the unit I'm using is old and is on a 200mhz frequency and it uses Vhf, so I have to buy a new unit.....nothing can be done to fix the problem....
Jan 21, 2009 | Audio Technica Audio-Technica 200 Series...
Disasimbel freeway atw-t202 for repair
might just be the mic wires came loose...I have oner and the mic is held in by a small rubber O-Ring and as people drop it it falls out and can short out
Jan 11, 2009 | Audio Technica Audio-Technica 200 Series...
HELP
Audio Technica Part number 235401550, call 330-686-2600. The cost is $21.93, plus shipping
Jul 29, 2008 | Audio Technica ATW-T52 Professional...
Nikon d100 error code r03
If you have a "r03" display, then you need to go into your CSM Menu, and scroll down to CSM #4, and turn LONG EXP. NR to "OFF". When you are in Noise Reduction Mode, your D100 buffer is literally cut in half.
Jan 01, 2008 | Nikon D100 Digital Camera
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Paul Bade
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
