Question about Welding Tools
Welder feeding or arking
When you pull the triger on the gun the wire dose not feed the feed rollers do not move. the wire dose not ark
  • David Shaub May 11, 2010
    Check for a bad connection at the front of the welder where the trigger plugs in.
  • sullivanl70 May 11, 2010
    replace your lead or if possible just the trigger
  • 92 Answers
Release the wire feed rollers,turn the wire feed dial up to maximum ensure you are well away from the earth clamp, pull the triger, you should hear the relay click in, if it dosn't check the 5 mil anti serge fuse positioned on either the front of the set or on the control panel near the wire feed rollers inside the cabinet. usualy covered by a plastic screwed knob, make sure the unit is unpluged before any testing.
Posted on Jan 23, 2009
Welder turns on but won't ark
If won't arc, then the feed is not moving the wire because the trigger button is not making a connection. Bad trigger. If the wire does feed, then your cable connection is responsible and needs cleaned and tightened.
Nov 15, 2014 | Welding Tools
Mechpro 100amp mig welder
It won't arc without wire in it. If the motor runs then there may not be enough tension on the feeder wheel to push the wire thru. If you had a bad kink in the inner liner it will not feed. The trigger switch in the handle applies arc voltage to the copper nozzle. It may be bad or have a broken wire.
Dec 15, 2013 | Welding Tools
My wire feed quit feeding wire what do i need to replace to make it work
If your drive rollers are moving but can't push the wire all the way to the end of the gun, your problem could be the liner in your gun and/or the contact tip. Try to replace both. If your drive roller are not moving then check the trigger of the gun.
Oct 03, 2011 | Lincoln Electric LE 83180 Century...
How do you switch the polarity switch on the 115 farmhand versa-arc mig welder. trying to switch from mig to flux core wire.
Disconnect you ground clamp form the negative side pole and switch it to the positive pole, same for the gun disconnect the from the positive side and switch it to the negative pole.
Good luck.
Sep 07, 2011 | Campbell Hausfeld MIG / Flux Core Wire...
I have a 125 lincoln wire feed welder. wire will feed but will not arc to weld
check you ground cable, try to strike and ark on the ground cable, if no ark test the ground circuit if the circuit is ok you will need to have the transformer tested and for that you need some specal tools.
Aug 28, 2011 | Lincoln Welding Tools
No ark
no ark
prolly means no bible
Aug 15, 2010 | Lincoln Electric LE 83180 Century...
Will feed wire but will not start an ark to weld
Make sure that the ground clamp is securely fastened to the workpiece.
Ensure that the power pin is fully seated into the housing where it receives the current.
Ensure that voltage and amperage settings are correct.
May 04, 2010 | Hobart 500526 Handler 210 Professional...
if it is new make sure the trigger is connected inside area where the wire is.
Feb 26, 2010 | Welding Tools
Lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
Jan 18, 2009 | Welding Tools
Renegase 180
This fault is typical in most MIG/MAG Units. the feed roller/s need slackening off, pull the trigger so the rollers spin wire the wire not moving, turn the tensioning 1 turn check to see if the wire feeds, if not give a half turn on the tentioner repeat this half turn untill the wire feeds, bend the wire to the torch and pull the trigger, If the wire feeds then thats the correct setting. be awear of all safety rules. use gloves
Nov 01, 2008 | Miller RENEGADE 180 WELDER GENERATOR MIG...
Welding Tools Logo
421 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
