Question about iRiver PMP-120 Digital Media Player
Boot failure Message says "System file has an error. to solve the problem, connect the device to your computer. (Refer to 'trouble shooting on the manual." As I am typing this, the device is connected and the manual says nothing about boot failure. Please help if you can, I am trying to get this working for a friend who is going to Mexico over the 4th of July. Thanks.
  • 64 Answers
Dead Hard Drive. Thats all i can tell you. Did you hit a huge pothole or drop it today? With the way firmware is today you'll juest need to send him in. Sorry to say it, but that's the solution! thanks! Let me know of any followup needed
Posted on Jul 27, 2007
  • Leo Bas
    Leo Bas Aug 07, 2007
    This is a bad or corrupted HDD, or a drive head being damaged. The only solution is replacing the hard drive unfortunately.
    This hurts my status, I'd appreciate you ranking this as solved or something since this honestly is the only solution to your problem! Thanks!
I have an error message in my iRiver and unable to use it anymore. The error message I'm getting is: Boot Failure System file has an error. To solve the problem, connect the device to compute
If it is an older model like H10, it used a a micro hard drive which may have failed mechanically. Those old hard drive devices were susceptible to shock failure due to drops. In some cases you may be able to replace the failed hard drive with a compact flash card - I believe they used the same connectors and pin outs. If it is not a hard drive model, can you get it recognized by windows drive manager to try to reformat it. There's a linux based program G-Part Ed. It's an ISO file, burn to cd or put on USB and boot pc to the cd or usb to launch linux and the software then see if it will recognize and format it as an external drive. Gibson research used to make spin rite that was able to fix some hard drive problems, might work on flash memory too.
Jan 02, 2015 | iRiver Audio Players & Recorders
I have a w3622 and put in a new hard drive and tried to use the OS disk that came with the computer. what I get is PXE-E61: media test failure. check cable. Disk boot failure.insert system disk.
Sorry to hear about the trouble you are having. Try the following tips and lets see if we can get it up and running.
-Set the boot order in BIOS to boot from the disk drive first. In order to get to the BIOS, you will need to select BIOS option or Settings when the machine is booting up.
Most often, the above error is caused due to incorrect BIOS settings or a faulty hardware, such as hard disk. Sometimes, the error may also occur if the computer tries to boot from a device, on which it cannot find the required boot files. An improperly connected hard disk is also known to cause the same type of issue.
You should follow the below steps sequentially in order to isolate the cause and solve the issue:
  • Verify all the cable connections of the hard disk. An improper or loose connection is likely to be the reason, in case the hard disk has been recently installed or moved.
  • Check if no other storage device is connected to the computer. If it is, remove it.
  • Enter the BIOS setup when trying to start the computer and see if hard disk has been correctly setup and detected in BIOS. If the hard disk cannot be detected due to any reason, you should consider the next suggestion as it might be physical failure.
Regards,
G33k
May 09, 2011 | E-Machines eMachines Desktop PC
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Dec 28, 2010 | Toshiba Satellite P205D-S8804 Laptop
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Cartridge error, refer to device documentation for troubleshoot
show me a massage Cartridge error, refer to device documentation for troubleshoot printer model hp officejet 5610 all -in- one what is the problem and how do i solve thnk you
May 22, 2009 | HP Officejet 4315 All-in-One Printer
Disc read error
This appears due to some range of possibile problems. Try following these steps: 1 ) Boot the system > goto BIOS setting (press DEL or F2 as soon as u switch on the power switch) > check the boot sequence somewhere in that settings and choose to "boot from the harddisk"     This has got some 50% probabily of solving the problem.
2) If not, you have to reinstall the OS using a operating System CD. Put the CD in, boot up and follow the on-screen instructions to reinstall the OS.  DONT FORMAT IT - you will loose all ur data. Just reinstall it. SOme boot sector files might hav been corrupted. Reinstalling the OS will surely solve ur problem. Thankyou!
Mar 27, 2009 | Envision EN 9110 19" Flat Panel LCD...
Ink System Failure on HP Photosmart c5180
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 08, 2008 | HP Photosmart C5180 All-In-One InkJet...
Boot failure
1st go to Ihttp://www.shamrockman.net/ and dload the version you want to run. My PMP shows 1.23 but I couldn't find that version so I now run 1.24.. Save the dloads in a new folder on your computer.. There should be (7) items that dload to your computer.
*** I have found that just copying the files to your PMP Player will NOT work.***
I had to delete ALL (7) of the system files and folders.
1.) BMP folder
2.) etc folder
3.) system file
4.) (4) "Version-[0x..... " files..
So there were (7) items I had to delete. Once deleted go to the folder you saved the dloads to. I had to click and drag each item to the drive your PMP player is connected to. Once all (7) items have been placed on your PMP player disconnect it, turn off the power, wait a minute and turn it back on. These steps worked PERFECTLY for me. Please let me know in this forum if this helps..
Thanks..
Jan 08, 2008 | iRiver PMP-120 Digital Media Player
Iriver PMP-140 boot failure message
when i turn on my Iriver PMP-140 it comes up with a message reading
Boot Failure
To solve the problem, connect the device to computor.
(refer to 'trouble shooting' on the manuel)
Filmware Ver. 1.24
I dont have a manual though.
May 13, 2007 | iRiver PMP-140 Digital Media Player
iRiver PMP-120 Digital Media Player Logo
252 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
