Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
I have a Atwood Protechtor Series 2000 detector in my rv. I want to replace with a dual co/lp model, will 36681 or 36636 work ok?
3 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: The LP gas detector alarm is going off and I can't stop it.
Unfortunately, it may have to be replaced. Not uncommon for those to be affected by humidity, condensation etc, hair spray, aerosols, moth balls too close, etc. and begin to malfunction. Just be sure propane is off. They can be bench tested,(out of the unit) with a battery, just to be sure it's time to replace it.
Posted on May 13, 2010
motor1258
  • 6674 Answers
SOURCE: I turned ON my LP
First I'd remove screws and pull detector out to see if perhaps any loose wires that may have touched each other or a ground. Second, check for any bad connections as well at solenoid on propane line feeding system. Being how it says it's a Motorhome, the propane detector usually has to be on to activate solenoid to open gas flow to appliances etc. If all connections appear good, you may have a bared (+) wire (short) that you need to look for. Area around wires coming from propane solenoid is a good place to start, seeing how they are usually exposed to the elements, more than interior wiring. You may end up having to disconnect one or the other or both to start with, and then re-attach one at a time to determine which way to go, As in a wire running to fuse box, or wire running from solenoid below at propane tank. Can't rule out shorted solenoid as well.
Posted on Oct 04, 2010
How do i wire 4 6 volt batteries in my 2000 monaco knight motor home
Quick drawing but I think you'll get it. If not let me know. Your building 2 separate banks of 12 volts with jumper.
Oct 06, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
We had been in our RV for many hours running the air conditioner and then we strated to smell something for about an hour and then LP Arlarm strart going off. It did not smell of LP. When we got out side...
Yes, those detectors will trip on many gases, and if your battery or Batteries are boiling that bad, you should have them and charging circuit (converter etc.) checked.
Jul 25, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
2006 Sandpiper travel trailer - The LP gas detector keeps going off and we didn't even have the gas turned on.
May be faulty and need to be replaced but check for proper voltage to it first. Some of those detectors can go off from hairspray, deodorant spray, perfume, high humidity, etc (aerosols)
Even a dog laying close to it with a little gas can do it sometimes. (lol) seriously. Do you have a battery hooked up to your trailer as well, may help.
Jun 01, 2010 | Rv Motorhome Dual Co & Lp Gas Alarm...
Jan 01, 2010 | Rv Motorhome Dual Co & Lp Gas Alarm...
MH LP tank gauge says 3/4 but suspect it is empty. How do I verify gauge inop?
Poured boiling water over lp tank and then felt the tank. It was noticeably cold at the LP line.
Dec 13, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Propane refrigerator?
Yes , when the refer needs to cool it will fire up only with the LP. In the electric selection it will work the same way. Do not fret , it is working ok.
Aug 31, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Atwood series 2001 fault alarm
Posible dirty sensor affecting sampling of air. Gas sensors have little filters that need periodic replacement.
May 06, 2009 | RTO Atwood Water Heater - 6 Gal LP
I need a service manual for Atwood 2001 series RV LP gas detect
Call one of the motor home supplier and you will be able to get it.
Mar 30, 2009 | RTO Atwood Water Heater - 6 Gal LP
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
168 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Mike
Ken Strite
Ken Strite
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
