Question about Kenmore 30169 Electric Single Oven
Oven door locked
We programmed the oven to self clean. The oven door remained locked and we are still unable to open it. It is making noise as if it is still cleaning but it is not.
  • 1 more comment
  • loyd timm Nov 17, 2007
    oven was set for self clean, after about 2.5 hrs started beeping and f1 code appeared. I pushed cancel and the beeping stopped but the door wont unlock and the code still appears. ive tried to reset by unplugging unit, that did not work, beeping starts again until i push cancel, back to square one with locked door and unable to get to screws to replace ecr/touchpad/clock. can you help
  • KIMBERLY1979 Apr 30, 2008
    I SET TO SELF CLEAN.STARTED SMOKING SO I UNPLUGGED NOW THE OVEN DOOR IS LOCKED AND I CANT UNLOCK
  • Anonymous May 29, 2008
    My oven self cleaned, and now the "door lock is displayed and wont shut off casuin us not to be able to use the oven
  • 35 Answers
You would have to remove oven.remove top panel and disengage latch assembly if you are a tech.
Posted on Jun 25, 2007
H E L P !!! My oven made some noises this morning when my husband was wiping down the front of the oven door. Noise sounded like the "oven was going into clean mode"....but then only lasted...
Hello.
Please apply the solution this way!
To close an oven door when it's in the locked position and the door is open, press and hold the oven door light switch while following these simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven cools down. When it is sufficiently cool, the door will automatically unlock.
Thanks for using fixya.
Sep 07, 2011 | Dacor Ovens
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Wait 20 seconds.
  • Wait 20 seconds.
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
The oven door must be closed and all controls set correctly for the cycle to work properly.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
If your model has a latch, latch the door.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
On models without a door latch, the door
locks automatically. The display will show
the clean time remaining. It will not be
possible to open the oven door until the
temperature drops below the lock
temperature and the LOCKED DOOR
light goes off.
The oven shuts off automatically when the
clean cycle is complete.
When the LOCKED DOOR light is off,
slide the latch handle to the left as far
as it will go and open the door. If your
range does not have a latch, the door
will unlock automatically.
The words LOCK DOOR will flash and
the oven control will signal if you set
the clean cycle and forget to close the
oven door or forget to latch the door
on models with a latch.
To stop a clean cycle, touch the Clear/Off
pad. When the LOCKED DOOR light goes
off, indicating the oven has cooled below
the locking temperature, unlatch the door
(on models with a latch) and open the door
How to Delay the Start of Cleaning
Make sure the clock shows the correct time
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
start time you can set will appear in the
display.
Using the number pads, enter the time
of day you want the clean cycle
to start.
locks automatically. The display will show the
start time. It will not be possible to open the
oven door until the temperature drops below
the lock temperature and the LOCKED DOOR
light goes off.
The words LOCK DOOR will flash and the
oven control will signal if you set the clean
cycle and forget to close the oven door or
forget to latch the door on models with
a latch.
pad
(on models with a latch) and open the door.
After a Clean Cycle
You may notice some white ash in the oven.
Wipe it up with a damp cloth after the
oven cools.
If white spots remain, remove them with a
soap-filled scouring pad and rinse thoroughly
with a vinegar and water mixture.
These deposits are usually a salt residue
that cannot be removed by the clean cycle.
If the oven is not clean after one clean cycle,
repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to
unlock.
While the oven is self-cleaning, you can
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
small amount of vegetable oil or cooking oil
to a paper towel and wipe the edges of the
oven shelves with the paper towel.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
Door locked after shutting down cleaning cycle earlier than
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning oven door won't open
May 15, 2009 | Ovens
Door locked after cancelling self clean option
Open the door. In the upper left corner, press and hold the door switch (the one that controls the inside light). Start a self clean cycle and wait for lock motor to engage. When the lock stops moving it should be in the unlocked position. Press cancel to stop the self clean.
If you need more assistance let me know.
Mar 29, 2009 | Ovens
Oven door remains locked after completion of self clean cycle
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Sep 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore 30169 Electric Single Oven Logo
117 people viewed this question
Top Kenmore Ovens Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
