Question about Fuji FinePix F700 Digital Camera
LCD will not display images/pictures
I took a number of pictures with my FinePix F700 on Christmas Day. That evening I followed the usual procedure to upload the pictures to my
computer, but the images would NOT display on the LCD screen. When I turn the camera on and go to the playback mode, I get a green box
on the screen with the letters APPAREIL inside the green box.
I called the Fujifilm help line and was told the problem was with the
camera and it would have to be returned to be repaired.
Have you or anyone you know been unable to get the pictures to load
on the LCD because of this particular problem? Do you have any idea what the problem is? I would appreciate any helpful suggestions. I have
never had a problem with the camera before.
Sincerely,
Jim Abbott
    President:
  • 2,559 Answers
Appareil photo numérique means digital camera.
follow the instructions below to change the language to english.
Press the “MENU/OK” button to display the
menu screen.
Press “a”, “b”, “d” or “c” to select “SET–UP”
from the “F” OPTION menu.
Press the “MENU/OK” button.
The “SET–UP” screen appears. Use “a” or “b
to select “LANGUAGE”.
Press “c” to select “ENGLISH”, “FRANCAIS”,
“DEUTSCH”, “ESPANOL”, “ ” or “ ”.
You can cycle through the language settings by
pressing “c”.
Posted on Jan 18, 2009
    Master:
  • 416 Answers
Try to connect camera to PC and see if you can get pictures
If you can see them you have problem with LCD. If not there is problem this CCD sensor (either R or S) or logical board
Good Luck
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
I believe the first priority would be to download/copy the picture files. Have you considered using a memory card reader?
Initially, as to the camera itself, try to remove the battery for an extended period of time. This is to reset the camera and revert to factory defaults. It is also possible that the camera has an internal memory battery that looks like a coin. Should your particular version/model has one, this has likewise to be removed.
Pls post back result(s). Good luck and Thank you for using FixYa.
  • 116 Answers
Try the memory card in another camera that uses that type of memory card
F700 digital camera
CHECK MY POSTED SOLUTION
FUJIFILM WILL REPLACE YOUR IMAGE SENSOR AT NO COST
YES, FOR FREE!!!
Sep 29, 2008 | Fuji FinePix F700 Digital Camera
Fuji FinePix F700
when downloading the pictures,good?.
then lcdconnecties are broken.
Aug 17, 2008 | Fuji FinePix F700 Digital Camera
White Vignette ('Artistic' white edge) around all photos
I sent my camera back to Fuji and they replaced the CCD free of charge. I had the same problem plus sometimes the pics just came out completely white
Jul 24, 2008 | Fuji FinePix F700 Digital Camera
Fuji F700
If you mean while you're trying to take a picture, one configuration option for the F700 is to turn off the LCD when taking pictures and use the view finder-- this saves battery power. If you press the DISP button to the right of the LCD should turn on.
To turn the LCD back on-- Press MENU/OK (you should see the SELF TIMER screen). Press RIGHT ARROW to select the SET option. Press UP ARROW to select the SETUP option. Press MENU/OK. You should see the SET-UP screen. Use the UP/DOWN Arrows to navigate the options; use the LEFT/RIGHT Arrows to cycle through the options. The IMAGE DISP and the LCD options control when the LCD is powered on.
Jul 01, 2008 | Fuji FinePix F700 Digital Camera
S5000 ccd replacement
You need ot send it back to the address in this articale and they will fix for free. It is the same problem with mine. You can also call and they will tell you this, Hope this helps you.
Service Advisory to Owners of
the FinePix A303, F410, and
F700 Digital Cameras
spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif spacer.gif Thank you for your patronage of Fujifilm FinePix digital cameras.
FUJI PHOTO FILM U.S.A., INC. announces that some of the FinePix A303, F410, and F700 digital camera models may develop a problem with the CCD imaging sensor. However, the problem affects a limited number of units and may not occur in all cameras.
The symptoms are captured images that appear completely black, have a purplish cast or multi- colored distortions. These symptoms would be seen on the camera LCD monitor when the camera is in the shooting mode or during playback. A limited number of these models will have these problems. The following list of serial numbers and model names may be affected:
Model Serial Number Range FinePix A303 3JA4****∼3JA5**** FinePix F410 32A1**** 32A6****∼32A7**** 32A9**** FinePix F700 33A0**** 34A1****
Serial numbers are found on the bottom of the cameras
If your camera serial number is on the list and experiences the symptoms described above and have no other additional damage/malfunction, FUJI PHOTO FILM U.S.A., INC. will repair your camera at no charge, even if your standard one-year limited warranty has expired. If your camera is beyond the standard one year, limited warranty period, you will receive a written estimate for any additional damages or malfunctions not listed in this Service Advisory.
This announcement is issued by FUJI PHOTO FILM U.S.A., INC. and is limited to only those Fujifilm products imported to the U.S.A. by FUJI PHOTO FILM U.S.A., INC. and sold by FUJI PHOTO FILM U.S.A., INC. to authorized dealers.
IF SERVICE IS NEEDED:
Package the camera carefully using ample padded material to prevent damage in transit. Include your name, address and phone number with the shipment as well as a general description of the problem. Keep a record of the camera's serial number and shipment tracking number. Ship your camera to the Fuji Service Center noted below:
Fuji Photo Film U.S.A., Inc.
1100 King George Post Rd.
Edison, NJ 08837
Attn: Camera Repair Dept./CCD Advisory
Jun 01, 2008 | Fuji FinePix S5000 Digital Camera
Distorted picture ,all lines and colors.
Service Advisory to Owners of the FinePix A303, F410, and F700 Digital Cameras Thank you for your patronage of Fujifilm FinePix digital cameras.
Model Serial Number Range FinePix A303 3JA4****~3JA5**** FinePix F410 32A1****
32A6****~32A7****
34A1****
Edison, NJ 08837
May 31, 2008 | Fuji FinePix S5000 Digital Camera
Black screen no image otherwise all works so cant take photos Fuji finepix F700
CCD failed, contact fuji, they got product recall for some camera models with faulty CCD.
Fujifilm Service Advisory:
Fujifilm camera - CCD sensor
If your Fujifilm FinePix digital camera serial number is on the list and experiences the symptoms described above and have no other additional damage/malfunction, Fuji Photo Film, Inc. will repair your camera at no charge, even if your standard one-year limited warranty has expired. If your Fujifilm digital camera is beyond the standard one year, limited warranty period, you will receive a written estimate for any additional damages or malfunctions not listed in this Service Advisory.
Finepix A303, F410 & F700 - Serial numbers
- FinePix A303 - 3JA4**** - 3JA5****
- FinePix F410 - 32A1**** - 32A6**** - 32A7**** - 32A9****
- FinePix F700 - 33A0**** - 34A1****
Fuji Photo Film - Camera faulty
If your camera got the symptoms please package the camera carefully using ample padded material to prevent damage in transit. Include your name, address and phone number with the shipment as well as a general description of the problem. Keep a record of the camera's serial number and shipment tracking number. Ship your camera to the Fuji Service Center.
Mar 12, 2008 | Fuji FinePix F700 Digital Camera
LCD display image distored not in focus and colours are blured
This sounds like it might be a defective CCD imager. If so, Fuji should fix this for you for free. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/12/fuji-digital-cameras-showing-black.html
http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportProductContent.jsp?dbid=839010&prodcat=2147483647&sscucatid=664262&quicklink=true
Applicable cameras include:
F303, F410, and F700
Feb 11, 2008 | Fuji FinePix F700 Digital Camera
Fujifilm finepix a303
A bit more explanation please Stevie Is the Screen really blank[black] or can you see shadow images. Or Is it White blank? And can you still take pictures even when the screen is in this state. Tell us more
Jul 06, 2007 | Fuji FinePix A303 Digital Camera
Images all white
Is the image on the card? Can you see it if it is download to the computer[if you have one] or can the print processor get images off the card
May 25, 2007 | Fuji FinePix F700 Digital Camera
Fuji FinePix F700 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
