Question about Watches
Hi I've got a bench watch BC0385WHA but I have no instructions and need to set the alarm on it
SOURCE: Watch instructions needed for ProSpirit® Open Mouth Sports Watch
try these:
http://www.nsftools.com/misc/TargetDigitalWatchInstructions.jpg
Posted on Feb 27, 2008
SOURCE: Bench Watch BC0088 set up manual
Hold down the bottom left button for 5 seconds. It goes to set mode.
Posted on Oct 21, 2008
SOURCE: Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Posted on Nov 04, 2008
Vicko5000
SOURCE: Sector 250 Chronograph Alarm
the middle dial on the right side of the watch is used to switch from watch settings to alarm settings..
pull the middle dial out to put it in alarm mode.
To set alarm:
-pull the center knob out.
-with it out you can now use the bottom (right) knob to set the alarm.
-pull the bottom right knob out one notch
-turn the knob clockwise or counter clockwise to set the alarm time
-push the knob back in (all the way)
the alarm is now set
if the center (right) knob is pulled out the alarm is ON
if the center (right) knob is pushed in the alarm is OFF
I have owned this watch for about 10 years now and love it.
the past few years the chronograph buttons (on the left side of the watch) were not working well rendering the chronograph and count down timer functions unusable.
repairing a chronographs is expensive and watch makers usually charge several hundred dollars which is not a feasible fee for a watch of this value so i decided to open it up my self and clean it up and that did the trick.. its working like new!
enjoy the watch!
Posted on Jan 09, 2009
SOURCE: How To Set/Shut Off Alarm On Tommy Bahama Watch RLX1003
On RLX1003 Hold S1 ( bottom right ) and then press S2 ( Top Right ) to toggle through the options ( Alarm and Chine )
Posted on Feb 18, 2009
Need instructions for setting Sharp watch
http://www.manualsonline.com/support/sharp/watch/
Jul 16, 2012 | Watches
I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
Jul 22, 2011 | Armitron All Sport Digital watch
How to turn off alarm on g-shock casio watch
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 18, 2010 | Casio G-Shock GW500A-1V Wrist Watch
Turn alarm off on bench GBC0013
I can't find the instructions for your watch but try the following:-
The "mode" button is used to cycle the watch through the settings and you should use this to find the alarm settings position .
Use the buttons " start" and "set" buttons to turn the alarm off. (some experimenting may be required).
When you have set the watch press the mode button to return to normal operation.
Mar 27, 2010 | Bulova Watch
Setting the time on a bench watch
hi i had the same problem but i have just found the answer. hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
Oct 16, 2008 | Watches
Alarm goes off at midnight & repeats for half hour, and not set
what you have to do is
1. press the mode button until you get to the setting that has "AL" at the bottom right.
2. then you press the "receive" button to switch between the four alarms.
3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
4. repeat step fout for all of the alarms, and the problem should be fixed.
Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Setting Bench Watch
Reset Instructions Bench. (BC0013BR)
Time and Location
If you hold in the light, start and the reset button for a few seconds a screen will appear with the 12h or 24 h clock setting and also the date and country.
Once you have that screen if you press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time.
Once you have changed the date and time to the correct date press the light button, start button and reset button and it will save the settings.
Alarm
Hold in the light, start and the reset button for a few seconds a screen will appear
press the mode button it will move over the date and clock etc then you just press the reset button and start button to choose the date and time. Use the light button to set the screen.
Feb 27, 2008 | Watches
Raymond weil tango watch 4795/1
i'm not sure the references of your watch are correct, but if it is a Quarz movement such as the RAYMOND WEIL Tango Ladies Watch or RAYMOND WEIL Tango Mens Watch you will find the instruction manual about setting and operating the alarm on the Instructions for use page of the official website : Watch Instructions page ( direct link to Watch instructions in pdf ).
Hope this helps :) david
Jan 14, 2008 | Raymond Weil W1
Watches Logo
48 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
