Sony Vaio laptop vgn-fs640-w problems
Very unusual problem....laptop will not boot up
when you power it on the dvd drives powers up, hard drive powers up and the lights all light up but the fan does not turn on and the screen does not turn on..........i took the laptop apart and looked for anything that looked bad..didnt see anything i then powered it up and the computer turned on and started to boot up fine and then the screen just went black and the hard drive was still on and dvd drive still on...fan was still on...i kept messing with it and now all i can get is the screen to come on somethimes but not to boot it just shows the sony splash screen and thats it...
could this be a bad processor??? prior to this the laptop would work ok and then freeze and shut down........it got more frequent and now i can only get it to boot up maybe 1 time out of 50 times.if i tap hard on the bottom of the motherboard i can get the screen to come on but it does not boot just goes to the sony splash screen and freezes there...and the fan does not power on.......
does the cpu tell the fan to power on..or should the fan come on as soon as laptop is turned on....when i can get it to boot it seems like the fan comes on once the pc starts botting up past the splash screen...
it uses a pentium centrino 1.6 ghz
  • dcxguy48080 Jan 18, 2009
    yeah it does seem that way.......but would a processor cause that also or not really........from my experince a bad processor will be totally non functional i have never heard of a semi bad processor......
    this sucks because its a beautiful laptop........if it was not micro electroinics i could prob troubleshoot it.....but the compnents are so small you really can troubleshoot them.........oh well........i got it for 60.00 today im sure i can part it out for way more..the screen works great and the 80gb hd is good...the 512 ram is good...the dvd burner is good.......i think it is a bad solder or connection on the board....like you said......thanks ill part it out on ebay
    well i took it apart and its on ebay now in pieces lol
    thanks
That happenedto me one time but i pressed the either the S1 or S2 button right bellow the speakers and the screen came back on.
Reply if this works for you, if not... Im sorry.
Posted on Aug 06, 2010
  • 32 Answers
The motherboard controls the fan speed - and laptops often turn it off entirely when it is not needed. This sounds like a motherboard issue where an internal trace is broken and sometimes it makes contact, other times not. There's probably nothing you can do except replace the motherboard.
Posted on Jan 18, 2009
  • fehknt Jan 18, 2009
    Yeah, a processor CAN be partly bad but I've only seen it once, and it was repeatable and got worse with heat. It's so much more likely that it's the motherboard that I wouldn't consider it worth trying.
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
How to Boot Sony Vaio VGN-S460 Laptop without CD/DVD ROM and With bootable USB
If the BIOS does not have the USB as one of the boot options then you cannot boot up with an USB memory stick.
In this case you need to replace the CD/DVD drive with a new one.
Jan 17, 2013 | Sony VAIO CS VGN-CS220J/T Notebook
How to install new windows in sony vaio laptop vgn-ux280p it has not having dvd writer i have tried from the usb but it is nor booting pls suggest
If you have enough room on your drives, copy the Windows disc complete to the hard drive and run setup from the hard drive.
Jan 18, 2011 | Sony VAIO VGN-UX280P Notebook
My vgn-fs810/w laptop is not powering up. Battery,
Motherboard is faulty. You can try removing the hard drive and dvd drive to make sure those aren't shorting out the motherboard. You can also try each memory stick to make sure neither one is shorting out the motherboard.
Apr 28, 2010 | Sony VAIO VGN-FS810/W Notebook
Laptop will not boot, Sony Vaio VGN CR220E, lights come on, don't hear the Hard drive start up, however. I get the clunks from the CD drive, but that's all.
Such problems happen when you have either faulty RAM or faulty Mother Board. Repairing MotherBoard Chip is a costly affair but replacing RAM is convenient and most probable solution.
With Regards,
Ankit
Oct 08, 2009 | Sony VAIO VGN-CR220E/P Notebook
Sony VAIO VGN-NS10E - Booting Problem
Hi!
Yepp, its easy to solve that problem. Get in the bios and change the boot up seqvence, ist probly set to look for all kinds of bootble divices, change that to only boot from the hdd in your laptop, disable all other boot devices, when you done that, hit F10 to save the settings and restart your laptop.
Good luck
Nic
Mar 31, 2009 | Sony VAIO GRX550 Notebook
Sony VAIO VGN-FJ3M/W does not boot.
Possible hard disk failure or hard disk controller failure.
if you feel confident remove the hard disk and replace - obviosuly make sure that there is not power running and remove the battery - replace hard disk then battery then power and try again.
Do you get any beeps? is the hard disk clicking? listen carefully to it and post your findings.
Jan 10, 2009 | Sony VAIO VGN-FJ270/B Notebook
Vaio VGN-S460 won't boot
Maybe simply buy another SATA HDD to replaced faulty one, which you said it came with "clicking noises".
you also can try hold tee 'C" or "F12" when you power on the laptop to get from DVD booting.
Nov 27, 2008 | Sony VAIO VGN-S460 Notebook
CMOS Battery
you want to be looking for the rtc(real time clock) which is a little unit not much bigger than ur thumb nail.next to it youll find the battery(sometimes heat sealed with plastic.)if you remove this battery for about 5 mins then replace it or in ur case maybe renew it this will reset bios to factory(also method for bypass passwords as every thing is reset)
you might also wanna check ur video card.(connections and dust)
Mar 04, 2008 | Sony VAIO VGN-FS640W Notebook
Computers & Internet Logo
1,331 people viewed this question
David Payne
David Payne
