Question about Troy-Bilt Garden
Troy bilt 521 snow thrower elec start not working
SOURCE: Electric starter won't engage with the engine.
I have just taken apart my Troy-Bilt Model 5521 so now I can see how all the bits fit together.
The electric starter is a separate device that engages with the cogs on the outside of the engine flywheel.
The cord pull engages the flywheel at the centre.
The fact that the cord pull starts the engine is a good thing.
If you dismantle the blower and take of the top cover (very annoying with many bolts all over the unit, take a look at the spare parts guide to see the exploded view) the starter it comes away with the power cord.
You can plug this in to the main supply and press the start button and you should see the small cogged teeth turning about 200 rpm. Keep your fingers clear.
I am guessing that this is not working at all. Either that or the cog wheel has shaved the teeth off or it is jammed.
This is a good do it yourself project for someone who doesn't mind getting their hands dirty.
It should take about 3 hours to take the unit apar and another 2 to put it back together.
Troy Bilt doesn't sell the starter motor or the engines (mine had an engine seize with a broken main bearing and a broken piston).
I suspect that the resellers don't have these parts either. But someone does.
Good luck
Posted on Dec 22, 2008
  • 666 Answers
SOURCE: snapper electric start snow thrower won't start
If the engine has a float type carburetor, remove the float cover and see if the float is hung in the down position. If so free it up and make sure it will now operate freely up and down. If not and the bowl is full of crud, you will have to remove and clean the carb.
Posted on Mar 13, 2009
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
#1 Taper
  • 1041 Answers
SOURCE: Can't find the oil drain plug on Troy Bilt with 5.5 Honda engine
You may want to look under the deck. They sometimes put them there. And if it is a self propelled, you will probably need to remove or loosen the plastic cover that protects the self propelled belt.
You are looking for a nickel sized plug that has a square peg. Use an extension piece for a socket set if you don't have the proper plug removal tool.
Jim
Posted on Jun 21, 2009
  • 41 Answers
SOURCE: My Troy Bilt Self Prop. Z-start won't keep running...
There may be a cracked fuel line, cracked primer bulb, loose carburator, dirt/trash in the carb....it sounds like a fuel supply problem. Hard to tell with out hands on.
Posted on Aug 02, 2009
How do I replace Blower Bearing?
Strip down, remove shaft, push out seals and then bearings. Take bearing and seals to a bearing supplier and they will replace by the part number on the bearing. Refit will plenty of lubricant.
Mar 04, 2016 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
Where is spark plug located on Squall 2100, 4 cycle,208cc ohv?
You will have to drop the back panel. See picture also add a link to your manual.
Troy Bilt Snow Thrower 31AS2T5F711
Feb 15, 2016 | Troy-Bilt Squall 2100 208 cc 21-in...
Chute on Troy Bilt single stage snow thrower won't turn
CHECK TO SEE IF THE ICE FROZE I THE CHUTE YOU MAY HAVE TO PULL THE COVER OFF THE TOP THIS SOUNDS LIKE THERE MIGHT BE ICE BUILD UP ALSO AFTER THE COVER IS PULLED OFF CHECK THE GEAR THAT TURNS THE CHUTE BY TURNING THE HANDLE
Feb 26, 2015 | Troy-Bilt Squall 2100 208 cc 21-in...
How do you adjust steering on a storm 3090 xp ?
howdie the Pins in the front adjust the holes According to your Height or lower them Thks For your Time
Sep 04, 2014 | Troy-Bilt Troy Bilt Storm 3090XP Snow...
Troy bilt repair manual
Check with the engine manufacturer if you have trouble with Troy built.
Aug 03, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Snow thrower starts then shuts down after a few minutes
Hmmm... THAT sounds like you have an obstruction (ice???) in the fuel line or in the bottom of the tank.
Feb 15, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Garden Logo
154 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
