Question about Cameras
I need to load photos onto my Thomson DP700 photo frame
Photo frame
SOURCE: 7 digital photo frame problems
Yeah, I just got one too and I have no USB thingy, and I kinda need my memory card.... hmmm.... maybe it should come with one. That's a bright idea huh! And how on Earth do you get music on it?!
Posted on Dec 26, 2007
SOURCE: Digital photo frame
hi, got the same problem, tried pics at different res, compressions, from different cameras and programs...still no luck
Posted on Dec 27, 2007
pauman
  • 248 Answers
SOURCE: Philips digital photo frame 7FFI series
Here`s a tip i found for you...
1. Connect the frame to your PC using the supplied USB connector. Navigate to the \DCIM\100Frame directory and delete all the Phillips advertising pictures there.
2. Create a directory on your PC and put copies of all the pictures you want to display there.
3. Download the free picture resizer utility from Microsoft at:
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
(Look for Image Resizer in the right column). After installing it, "Select All" pictures in the directory you created, then right click and select "Resize Pictures" from the context menu. Choose the 640x400 radio button. Sort by size and copy all the small ones into the "\DCIM\100Frame" directory on the frame drive (Called Removable Disk on my PC).
Posted on Jun 20, 2008
  • 148 Answers
SOURCE: I've got a LOGIK PF-A850WD
Please make sure that the photo files are in the root directory of the memory photoframe (ie, not within a folder).  That they are in a readable file format (.jpg) Check to see that the frame is reading from the internal memory and not the card slot.
Posted on Dec 12, 2008
SOURCE: just bought a sunpak 7"
I have found that when you have the source of the photo files connected to the picture frame and are viewing from the menu it says "USB" Select the photos you what to paste by following the instructions and then change the "Device" to "favorites" and the paste by pressing the "enter" button.You can only paste about 10 files or photos at a time...so if you have allot it take a while. hope this helps
Posted on Dec 21, 2008
How to change from thumbnail pics in coby dp700 photo frame
I turned my device off, and it switched to full screen mode.
I know - reboot - that's pretty bad, but it worked and it works fine now.
Dec 24, 2012 | Coby Cameras
My Grandma was given a Coby dp700 with pictures already on it for a gift. She would like more pictures. I can get different pictures from a usb flash drive to play as long as the flash drive is plugged...
Most digital frames come with a USB cable to hook the frame directly up to a computer. When you plug in the frame, a drive should show up in your "My Computer" section (for Windows) or on your desktop (for Mac). In most cases, you just need to drag and drop the photos onto the drive.
Mar 05, 2011 | Coby DP-772 Digital Picture Frame
Hi, I have been loading pics onto my new Digital Photo Frame. I've loaded the pics just fine, however, the pics will slide by just fine, then the next slide says "No Support", then I have pics,...
Hi bon_kahlua_r,
It means that your Digital Photo Frame might not have support for the file formats of some pictures that you saved. Most Digital Photo Frame supports *.jpg formats. Please check the manual of your Digital Photo Frame as well as the files that your saved. Right-click on the pictures that are not supported then Click Properties. You should be able to see the file format of the picture then compare it to the Frame's manual if it's supported.
Thanks
Feb 22, 2011 | Computers & Internet
How to send photos from laptop to digital photo frame
The photo frame will either have a card slot or a USB connection on it. If it has a card slot you will need to connect the card to your compuer first (through a card reader) and download the pictures onto it. Then put the card into the photo frame.
If it has a USB connection, you can use a usb flash drive - first plugged into your computer to download the pictures then plugged into the photo frame.
It is also possible that the photo frame has internal memory - in which case you would connect the frame to your computer directly using a USB cable. It would them show as a "Removable Disk" and you can download directly to it.
Nov 04, 2009 | Office Equipment & Supplies
I can't load photos onto my digital photo frame
The  A701 is  a bit cranky.  I've found that it prefers  USB  flash sticks of upto  2GB. It likes the flash stick formatting  before use.  And it prefers  jpg files  added  to the root directory of the flash stick -  so  no images in folders. Finally but probably least important, it's not much point uploading  2MB  jpgs as  the screen  is pretty much  72DPI  smaller size JPGS  lead to a faster loading. ( try  around 900x 600 dpi )
Nov 17, 2008 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Can I get pics from computer put on memory card for digital camera?
Put your SD card into a card reader / slot in your computer. Go to "My Computer" Identify the drive letter allocated to the card slot and drag and drop or copy and paste.
May 05, 2008 | Cameras
How do I load pictures from my computer to the memory card in my camera?
You have to first download the images to your computer and Save them in a folder. Then connect the USB cable from the digital photo frame to the computer and transfer the photos you want onto the frame. Some time you have to change the photos name to alphabetic order so you photoframe will display the pictures in the correct order.
Feb 20, 2008 | HP Photosmart 635 Digital Camera
Digital photo frame
Some digital frames comes with built-in internal memory so you can load that with your PC via a usb connection without having any kind of removable media. If yours doesn't come with internal memory though I don't think you have any choice other than to purchase a memory card of whatever type is supported by the frame.
Jan 09, 2008 | Audio Players & Recorders
Cameras Logo
136 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
