Question about Dremel Stylus Rotary Tool
Burned circuit board on Dremel stylus
I need part information for the large semiconductor (I think diode) or voltage regulator on the circuit board. It is burned beyond recognition! I can't read several of the numbers.
  • mkvyper Apr 05, 2009
    Same problem. Dremel Stylus starts turning, and stalls sometimes even before touching a working surface.
    Component indicated as Q1 looks really overheated, but only "F4", a diode symbol and "UM" below it are recognizable on it. If anyone has an opened stylus (it's as easy as removing three screws and one label...) I'd be grateful
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Dremel Stylus model 1100
I would contact Dremel.com and talk to their tech department about a warranty repair for this tool.
Posted on May 08, 2010
  • 28 Answers
SOURCE: Replace the docking station-charger of dremel stylus
ebay.com or www.craigslist.com
Try to find a used one maybe?
Posted on Sep 01, 2010
jo83286
  • 4 Answers
Change the capacitor 220uF and it will most certainly work again. I got the idea from FixYa and it solved my problem!
Easy to change just 2 soldering points and a component costing around 0,2 Euros. If you do not know how to operate a soldering tool ask someone for a quick assistance. The switch takes around 2 min (1,5 min to open the charger and 0,5 min to change the component!).
/Johan
Posted on Apr 02, 2013
How can I locate capcisator for Dremel Stylus Lithium-ion model 1100 ? It has got charging problem.The Stylus is a cordless tool.
Do you mean a capacitor? Is it the charger or is it the battery? The capacitor are plain types can be found at any electronic parts store. I think the main one is 220uf. Be sure an check each for problems.
Jan 18, 2015 | Dremel Tools & Hardware - Others
My relatively new stylus runs for a short while and then turns itself off! Any small restence on the tip while in use also seems to turn it off. Please tell me what the possible cause is.
Battery is flat or has a problem, the dremel does monitor voltage/current and shutdown to prevent battery damage, failure or fire. First step is to ensure the charge is working properly.
Dec 11, 2010 | Dremel Stylus Rotary Tool
Only runs for 3-5 seconds before turning off dremel stylus, with very little use
THIS SEEMS TO BE A MAJOR PROBLEM FOR DREMEL AND I AM SORRY BUT I HAVENT A SOLUTION (NEITHER HAS DREMEL). I AM A DOMICILLARY CHIROPODIST AND FOUND THIS ITEM ABSOLUTELY FANTASTIC FOR MY WORK...ORIGINALLY I RETURNED MY FIRST ONE WITH A COMPLAINT AND IT WAS REPLACED WITHOUT QUASTION ..HOWEVER IT HAS HAPPENED AGAIN AND MY ONLY SOLUTION IS TO ALWAYS CARRY TWO FOR BACKUP..WHEN I RECHARGE AT NIGHT THOUGH IT ONLY PARTIALLY RECHARGES BEFORE CUTTING OFF LOOKS LIKE I SHALL HAVE TO CARRY THREE......
Sep 02, 2010 | Dremel Stylus Rotary Tool
/Johan
May 05, 2010 | Dremel & Stylus Lithium Ion Cordless...
No operation
Hello their, thanks for trying fixya, the issue with these type of tools is normally the ac motor, their are many diffident types used but yours in particular 120V, 50-60 Hz, AC, 1.15 amp double insulated motor. Operates from 5,000 to 30,000 RP, their is a electric motor that may have failed on you or the switch could burned out. this is possible when the contacts are shorted for to long become to hot and overload the small circuit used to control potential voltages to the motor, consider it like a variable pot switch.
a simple test here would be you can take the unit apart easily enough and unplug from wall, make sure you have no voltage from mains going in. when the unit is not plugged in get your trusty voltage ohm meter or vom
Nov 27, 2009 | Dremel Tools & Hardware - Others
Sep 13, 2009 | Dremel Stylus Rotary Tool
Battery on my cordless dremel will not charge.
Dremel Stylus AC/DC Adapter 230/240V Transformer primary is open circuit any idea what the AC output of the transformer is. I should be the same for 110V input transformer. If I can find the output voltage from the transformer I can probably get a replacement
Apr 01, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
Useing a dremel stylus
I would call Dremel tech service at 1-800-437-3635 and ask them and also get a copy of an instruction manual for future use.
Jan 28, 2009 | Dremel Stylus Rotary Tool
Dremel Stylus Rotary Tool Logo
172 people viewed this question
Top Dremel Tools & Hardware - Others Experts
xboa721
Level 1 Expert
Mike
Kirk Augustin
Kirk Augustin
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
