MY MAYTAG LAV3600AWW TOP LOAD WASHER WONT START OR DRAIN THE WATER THAT IS IN IT
  • 15,935 Answers
It appears your pump or timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Maytag Centennial Top Load Washer drains as it fills.
The water is probably siphoning out of the tub. Your drain pipe is either too low or the drain hose is down too far into the pipe. Take the drain hose out of the pipe and lift it high. I'll bet your problem goes away
Feb 06, 2014 | Maytag Centennial Top Load Washer
Can't find where to put drain hose in maytag lav3600aww
standing at the rear of the machine, it is on the right, it pulls out, pull it till it stops, ~~4 feet, put into house drain and secure, good luck
Jan 12, 2013 | Maytag PAV2300 Top Load Washer
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
I have a lav3600aww maytag top load washer that just over-filled. Can you tell me where to start looking?
the water level control switch is probably faulty but firs you should check to see if the hose coming up to it is not plugged you can just blow back through it air should flow through this may even blow the blockage out temporarily
Feb 21, 2011 | Maytag Washing Machines
My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Nov 20, 2009 | Maytag SAV5710 Top Load Washer
Wont drain,spin,or agitate
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
Dec 27, 2008 | Maytag PAV2300 Top Load Washer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
My maytag top washer want spin out
Check the drain pump. It could be blocked or jammed. Remove the front panel and the pump is easy to access. There will be a hose from the bottom of the outer drum to the drain pump. Remove plug from wall socket before attempting to remove any cover.
Oct 31, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
231 people viewed this question
Top Washing Machines Experts
