Question about Dell Inspiron 6400 Notebook
In need of replacement screen not sure if getting correct one
I need to replace a screen on my dell inspiron 6400 laptop. computer was dropped and have a "broken glass" look. I want to make sure that I purchase the correct screen, but cannot find the info on my computer to tell me that it is a "match"
  • 32 Answers
You'll have to take the screen out of it's housing (involves taking the screen entirely off the laptop, and then removing the bezel around the glassy area by removing the screws under the little circles of plastic) and remove it from the hinges and then finally, you'll be able to see a sticker on the back that has the actual model number of the screen. be sure that it's an exact match to the exact model number. Even if the connector fits, the controller might be different and it won't work at all. Compare pictures, compare model numbers, try to see if they'll guarantee it working on your exact model of laptop (unlikely, but it's worth trying).
See this document by Dell about how to take the screen out. Be sure to follow the instructions carefully.
Posted on Jan 18, 2009
My dell inspiron 6400 has small horz line on screen
If you have tried this with an external monitor (and the line is not there)
then the problem is either the connection on your display cable or (more likely) a fault on your LCD panel. If it's still under warranty I would let Dell take care of it.
If you want to do it yourself, you need to get a replacement LCD panel, take the screen apart (the top half of the laptop) and switch out the LCD panel. Some small Phillips head screwdrivers are required, the screw heads on hinges etc. are tiny.
While this is not an overly difficult process, it may prove daunting to some people. Most computer repair shops like mine would charge $30-45 for labor on this plus the part, which according to ebay will run about $75. Make certain you get the correct size, as there was a 14.1" and a 15.5" model (They are not interchangeable). Screen size is measured diagonally across the actual screen and does not include the trim.
Nov 21, 2011 | Dell Inspiron 6400 Notebook
Power jack replacement Dell Inspiron 6400
When you press the power button, no lights, fans, beeps, anything?
Is the power jack moving around? If not, I would check the charger and cord to make sure power is getting through to the plug that goes into the jack.
Jan 14, 2010 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 faulty spacebar?
You need to have the keyboard replaced. If you can't get it fixed locally, contact me for shipping information, I fix these kinds of problems a lot.
Jan 05, 2010 | Dell Inspiron 6400 Notebook
Memory stick pro not recognized any more by dell inspiron 6400
I suggest going into the control panel/device manager and removing all the usb devices.
Restart the computer and let it find the devices again. That might help.
Also--have you tried the stick in another computer just to make sure it works?
Sep 25, 2009 | Dell Inspiron 6400 Notebook
Replaced inspiron 6000 screen with 6400 screen
the screen is bad just look for something to do about it.
Jul 06, 2009 | Dell Inspiron 6000 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 screen is fading
Sounds like the backlight is going out. Youĺl need to replace the LCD screen. You can find them on ebay. Just make sure you purchase the correct one for your laptop. You will need to take out the screen to see who makes it and the number. Go to dell.com/support to find your manual, if you feel like you can do it yourself.
Good Luck!
Apr 04, 2009 | Dell Inspiron 6400 Notebook
My dell inspiron 6400 right click dosent work
Go to control panel and Mouse settings. Make sure settings are set up correctly. Same place for the Touchpad.
Mar 07, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
44 people viewed this question
Alun Cox
