Question about Grilling
Carlin gas burner won't ignite - Grilling
5 Suggested Answers
  • 4736 Answers
SOURCE: just got the bbq yesterday - the 2 burners on the
It may be a case, that the burner orifice for that burner is clogged with shipping debris or something similar. Remove the third burner and inspect the orifice for foreign debris. Also, check the venturi valve on the end of the burner for clogs. Onward Manufacturing, the company that makes Broil King grills is a good company and stands by their product. If you continue to have a problem with the grill contact their Customer Support Hot-line 800-265-2150.
Hope this helps you to troubleshoot and solve the problem. Please let me know and Happy Grilling
Posted on May 23, 2011
  • 4736 Answers
SOURCE: when i push igniter it
It sound s like the grill's regulator is locked up from "burping" the tank. Hopefully it's not a permanent lockup. To hopefully solve the problem, follow the steps below:
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it, as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
Posted on Jun 19, 2011
  • 4736 Answers
SOURCE: burner won't ignite it is
Linda, changing the battery in the electronic ignition will probably solve the problem. To change it, unscrew the ignitor button cap and remove it. The battery will be in the holder inside. Take note of which way the old, burned battery is facing, because that's the way you want the new battery facing, when you install it. While the old battery is out, check inside the battery holder for corrosion on the terminals. If you see any, use a Q-Tip & WD40 to clean the corrosion off.
Hope this helped you troubleshoot and solve the problem. Happy Grilling!!
Posted on Jul 02, 2011
  • 4736 Answers
SOURCE: brinkman grill 3 burner pro series 8300 won't
To restore gas to the burners, follow the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling.
Posted on Jul 05, 2011
Furnace burners won't ignite
Assuming this is a gas furnace, when the thermostat calls for heat the pilot heats an igniter to produce voltage that opens the burner gas valve. In your furnace, the igniter may have failed and the burner can't fire up
Mar 09, 2013 | Sport & Outdoor - Others
Stove burners won't light
sounds like the igniter is faulty try a local h/ware or plumbing shop for a new piezo ignition
Feb 02, 2013 | Hotpoint RGA524 Gas Kitchen Range
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
Nov 05, 2017 | Viking VGIC485-6G Gas Kitchen Range
I have a maytag gemini gas stove three igniters work but won't light the burners. One igniter won't spark
Replace the "igniter switch assembly". The igniter's are getting a weak spark and since you have one that will not spark at all, this is the usual problem. Here is the assembly to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Burners won't light
That clicking is the igniter trying to spark. Turn on the burner and attempt to light it with a match. If you know gas is comming out, you will most likely have to replace igniter.
Sep 26, 2012 | GE WB13T10045 Gas RanOven Igniter Glowbar...
My Electrolux Eog6330xn oven cuts out after about an hour and the ignighter then constantly sparks. the oven then has to be turned off to cool down before it will relight. Any advice.
Hello there Gary and welcome to FIXYA
Usually when an oven won't bake properly or stops baking , it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. I would disconnect the power to the oven then unplug the wiring assy and remove the part then clean all of the terminals really good then reassemble it then try the oven again if it still does not work properly i would go ahead and replace that part ok
Please keep me posted on how this is going i can give you more help but this is the most common problem ok?
Best regards Mike
Nov 07, 2011 | Electrolux EOG6330 Gas Single Oven
My model is KFGR361SSS. The right burner cllicks when i try to light it, but it won't ignite
You might want to check to make sure that the gas is reaching the burner. If you can light with a match, then your igniter circuit is not aligned properly. If there is no gas getting to the burner, follow the gas line back until you find where it is blocked. OR it could be the switch is bad and not allowing gas to that burner.
Jun 01, 2011 | KitchenAid KFGR361SSS Grill
Burner will not light
you need to tell me what the burner is doing when it starts up. Some basics to look for:
1- bleed pump of any air- is it a new install? 2- If you are getting fuel, are you getting spark on the electrodes? 3- if you are, you may need to adjust draw assembly air, and or air intake per Carlin specs.
Jan 02, 2009 | SySTOR Systems (400S52) Burner
Oil Burner Will not Ignite
my burner will not light mpdel 701-crd. carlin
Nov 07, 2008 | SySTOR Systems (400S52) Burner
Grilling Logo
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
