Question about Samsung SyncMaster 712N 17" Flat Panel LCD Monitor
Popup on monitor screen
I have a popup on my Samsung 712n screen almost all the time. Is is a small box with BRIGHTNESS 100 on it. The box is white with a light blue inner band and black outer bank with an orange line showing it is 100. I can't get rid of it. Sometimes it will blink off for a couple of seconds, then back it comes. Sometime it will stay in the middle of my screen. Any suggestions? Thanks Anna
  • 3 more comments
  • nldeshazo Dec 16, 2007
    The popup that has been coming up several times an hour is the auto adjustment window. I have the SyncMaster 731N and I have had the monitor for 8 months. In order to get rid of the popup, I have to reboot my computer.
    HELP!
    nldeshazo
  • Anonymous Feb 10, 2008
    Hy
    I have the same problem as you are wit a SyncMaster 720N
    I am very disappointed
    about Samsung products.
    I tried everything to solve this
    problem but nothing.
    Probably it is the source of this device, because I can't turne it off.
  • deepbevel Oct 29, 2008
    The problem will come and go. I lived with it for a few months, sometimes the box would be gone for two weeks and then come back again. I decided to take a chance and sprayed the buttons with optical lense cleaner, which is mostly alcohol. It fixes it every time, but only temporarily. It could be a static issue that causes the buttons to think they are being pressed. The alcohol may work to knock the static charge off the contacts.
    Try it, the monitor sucks, so what have you got to loose?
  • samsung743 Dec 01, 2008
    Botsh solutions is big ********!
    Its nto helps and removes solution.
    I have sama problem SyncMaster 720N. I searched from internet and foudned thousand Samsung clients who have same problem. But no solutions. There have see lots suggestions. Nothing. peoples still ahve problem. DONT BUY SAMSUNG! It will be my last samsung monitor!
    I going to find now for me permanent solution - turn off samsung monitor settings screen. Or buyng new monitor! But first i transfer monitor to Samsung and want money back!
  • monicajames Mar 21, 2009
    ive been having the same problem and trust me none of the suggestions here kind of helps.i wish someone professional looks into the problem asap so that the qualinty of samsung products remain a standard......i seriously wish someone could help.the brightness window on my screen is making me furious.it blocks almost everything being right at the center of the screen.it it was somewhere at the corner i could hav ignored it but its contantly pestering me!!!
I had the same problem.i called up the service senter of samsung and they were like, press the menu button and hold it for some time.immediately press the auto button.this would do auto lock.i mean auto adjustment lock.that solved the problem somewhat in my monitor.its not a permanent solution but it can help...
Posted on Apr 02, 2009
Here is a link to get the user manual it is something to do with the auto adjust button I think my friend had the same problem.
http://www.samsung.com/uk/support/download/supportDown.do?group=&type=&subtype=&model_nm=720N&dType=D&mType=UM&vType=R&prd_ia_cd=&acc_ia_fl=&disp_nm=SM720N&menu=download
Posted on Mar 30, 2009
The problem for both of you (and I have the same problem with a 720n) is that a button thinks it is being pressed. For me the problem came after carrying the monitor in my car trunk, which may have damaged the button. I would conclude that Samsung SyncMasters have poorly made buttons.
Posted on Dec 20, 2007
  • hkori Jan 27, 2011
    SOLUTION! Samsung SyncMaster 720N problems with: Menu -1st button, MagicBright -2nd button, Brightness -3rd button, Auto Adjustment -5th. Remove the front panel. To solve the problem, you must replace the micro-switch relevant to your problem. For example, I had trouble with the brightness switch. The Brightness OSD menu, (switch nr.3) appeared on my screen and it wouldn't disappear no matter what. So I replaced the 3rd switch and thus solved my problem.
  • 432 Answers
You can download the manual from this website: http://computinghardware.web.cern.ch/ComputingHardware/doc/Samsung/SyncMaster710T-910T-E.pdf The popup screen is waiting for you to set it. I can't remember which button it is.
Posted on Jun 23, 2007
SOURCE:
How do I disable/turn off popup box upper left of display
right click on the popup to get the settings
chose remove
please give a good details for a direct direction
Nov 10, 2014 | Computers & Internet
There is a pop uop sayaing Brightness still in the middle of the monitor
solution of this problem main board replacment r bios updation of moniter
Jan 27, 2011 | Samsung SyncMaster 712N 17" Flat Panel LCD...
18 inch monitor; Brightness popup
I have the same problem with my Samsung SyncMaster 720n, the brightness window pops up without me touching it, and never dies down.
This delicate panel is affected by any decibel or temprature change (like humidity in my case), it can drive us all mad.
Here is a picture while I'm writing to you all:
I was thinking about using some WD-40 (penetrating oil) with the panel, but I'm not so sure it is the best solution.
Does anyone have a better solution?
Sep 09, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung SyncMaster 712n monitor will have small blue & white tiny checkers on the screen. will go away if i click the mouse. sometimes the entire screen has those tiny blue & white checkers.
Surely the monitor lets you change it's 'standby' settings so that it doesn't show that; or change your computer's power savings modes not to include standby?
May 29, 2008 | Computers & Internet
Samsung 731N Auto Adjustment
I'm having the same problem. Started three days ago. Really annoying. First I downloaded a driver because that was reccommended over plug and play. But that did not fix the problem. I ended up pressing the menu key (1st on left) and while holding it down I wedged a little piece of paper to hold the key down and the popup menu's have stopped. The box can be the brightness/contrast or auto/image reset/color reset ...
it doesn't matter, they all popup after pressing buttons left and right. Have no answer to correct the problem but at least I can now compute without these stupid menus.
Dec 27, 2007 | Computers & Internet
Birghtness 100 Popup
sounds like your "brightness" button may be stuck. try pushing it and see if it feels the same as the other buttons (should feel it "click" a bit). Also see if any of the other buttons work, because if it IS stuck, they probably won't work...
Nov 29, 2007 | Samsung 710N V2 17" LCD Monitor
first try unplug set from AC plug for about 10 seconds for full system reset.If not see if firmware (software) on set could be updated to newer version software...could be a software issue..
Nov 28, 2007 | Samsung 710N V2 17" LCD Monitor
Samsung SyncMaster 712N 17" Flat Panel LCD Monitor Logo
954 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
