SAMSUNG LCD TV LN32C350D1D NO POWER NO LIGHTS
FUSE IS GOOD HAS VOLTAGE AT FUSE
3 Suggested Answers
SOURCE: No power on Samsung TV after storm
Hello Zkarim,
I'm very sorry to hear about your unfortunate new's. I had the same problem in my own home maybe a week ago.
Basically if your power flickered on and off at anytime during this storm then there was a power surge that probably fried your TV.
* First check the power where the tv was plugged in. Is it a power strip or a surge protector ? Surge protectors typically have an on/off switch and a separate reset push button.
If it is a power strip then the tv fried because there was nothing to stop it from happening (not even the fuse). If it was plugged into a surge protector then it could be quiet a few years old and not as reliable or the surge was to powerful for the limit on the surge protector.
The only thing you can do personally is send it in for repair if it's under warranty, if it is not then you can have it looked at by an authorized repair technician in your area. Troubleshooting should be fairly low, and you will at least be able to find out your options once they find the defected part.
Thank you for choosing Fixya!
Posted on Jul 15, 2009
bshldn
  • 736 Answers
SOURCE: Looking for a free Samsung
Try this link
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=02010100&prd_mdl_cd=LN32C350D1DXZA&prd_mdl_name=LN32C350D1D
Posted on Aug 17, 2010
Samsung LCD TV 22inc Model No LA22A450C1, no picture ( white screen) only sound....
This type of failure is related to a defective Tcon board. I would suggest if you are DIY to check for proper connections from the main board to the Tcon board, if all the connections are good.. check for proper voltage from the power supply to the Tcon board. If all the previous checks are good, check for an open fuse on Tcon board.
Let me know if you require further assistance.
Oct 03, 2015 | Samsung Televison & Video
Samsung lcd will not power on
check for blown fuse, if the fuse is good replace bulged capacitors. if still doesn't works tried to remove the connector going to the inverter board for screen back light might have shorted line that can cause of power failure.
Aug 03, 2012 | Samsung LN55B640 LCD TV
My samsung lcd tv model number LN32A330J1D won't turn on. the power light comes on but nothing else happens. what do I do?
The power supply for the lcd tv can have problems that don't put proper voltage to the control board. Some can be fixed others have to be replaced. a good multimeter can be used to probe for voltage . also if the backlight is burned out you can still see a very fait picture by shinning a light on the screen.
Apr 18, 2011 | Samsung LN32A330 32 in. LCD TV
Hi, Can anyone recognise or diagnose this problem we are having with our Samsung LA32A450 LCD TV? It wont power up, no power on lights. Switch on side of TV wont turn on. Remote wont power it...
hi g_coopster,
Samsung LA32A450 LCD TV wont power up or no power on lights that indicated that no power line.
First of all, check the power line, cable AC cord is it installed properly, change ac cord if necessary. If you experience with electrical tool such as Volt meter, try it to measure the ac voltage from power line.
Or open your rear cover of unit, there are 2 board with difference color brown PCB (IP Board) and Greend PCB (main board). Check fuse on power board, if broken that may cause your problem. Change with the same type as labeled on it. But becareful, if after you change and try plug the power line in than broken again, thats mean power board have sort circuit.
My suggestions, try steps above and if it file, change power PCB block. You can buy it on Samsung cervice center.
Good luck.
Mar 22, 2011 | Samsung LA32A450 32 in. HD-Ready LCD TV
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
Looking for a free Samsung 32" LN32C350D1D TV manual
Try this link
Aug 17, 2010 | Televison & Video
I have a samsung 52"HD tv. we had a problem with the electrical power in the house and when i plugged the tv it sparked and the tv wend dead. I heard several clicking sounds like if it wanted to turn on...
It will be if you have access to a TV technician, the inconsistent voltage has caused the power pack to blow, it will need to be replaced, also I recommend you buy a very good multi plug with a power modulator to stop power spikes in the future.
Apr 19, 2010 | Samsung LN52A850 52 in. LCD HDTV
TV quit working
I just fixed a friend's set that had the same symptoms.
Multimeter check: all the expensive parts are still good!
Physical check: Hmmm this pair of 10V 1000uF caps are bulging on their tops. ( they are located by the output connectors ).
I swapped out the two bad caps. and Bingo!
Jeffrey
Mar 12, 2010 | Samsung LN40A500 LCD TV
I have a 46 lcd samsung tv that has no power we changed the capatiors still no power any ideas 14 month old.
You need to check for standby 5vdc, it should be there the minute you plug the TV into the outlet. This a must have voltage. Replacement power supply is only $53 here: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN32A330+
Please post back what kind of voltage reading you are getting at the DC output connectors.
Dec 24, 2009 | Samsung LN32A330 32 in. LCD TV
Voltage Stabilizer for LCD TV
Samsung 32 inch LCD TV needs a stabilizer support or not? Can any expert answer?
Feb 19, 2009 | Samsung LN-S4092D 40 in. LCD HDTV
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
