Question about Altec Lansing inMotion iM7 (021986950806) Docking Station
How do I disassemble my Altec Lansing iM7 to make repairs?
I have taken out all of the screws, under the rubber handle, sides but cannot get the rear panel off. I got the front panel with the ipod doc loose but that is it. Does the casing come apart in 1/2 or what. I would appreciate any tips on this. Thank you anyone who knows.
  • George Hagelis Jan 02, 2013
    Addiing to the above questions on my Altec Lansing iM7, how do I open the case up to gain access to the intermal works (Switch, ipod doc door latch etc)?
SOURCE: lost cord!
I have them for sale AC Adapter For Altec Lansing speakers inMotion iM600.Price is $15.95 Plus $6.95 shipping . send me your email and address to this email address.princemonac0@yahoo.com and I will invoice you through paypal. Thanks
Posted on Mar 29, 2009
SOURCE: 5th generation iPods hose up while using Altec Lansing IM600
Yes, the docking station is damaging the iPod. The vibration when used load is causing damage to the iPod. If you notice, the iPod will only freeze when it is playing load in the docking station. To avoid the problem, you'll need to play the music at a lower sound with less vibration. Once I began to play my music at more reasonable sound levels, I discontinued the problem. Very disappointing solution...but it is the answer. I too called Altec Lansing. They are not aware of this issue...I told them to search the internet - it's all out there.
Posted on Apr 28, 2009
SOURCE: Altec Lansing IMT702
http://www.youtube.com/watch?v=ztxvAAKhwU8
Posted on May 23, 2010
SOURCE: Sparepart For Im7! LOOK HERE!
I have one that just quit all of a sudden as I was listening to it. Don't know what happened, but it "clicked" and that was it. Sounded great while it was playing, I have the remote if you are interested.
Posted on Nov 07, 2010
  • 6 Answers
SOURCE: how do I open the altec lansing inMotion im600? I
There is a button on the front of the unit that is just below the LCD readout that shows FM / iPod status. Press the button. If it does not open the unit, you may need to tap the back of the unit when doing this or else get something to gently pry open the unfolding section WHILE THE BUTTON IS PRESSED (otherwise you'll break the mechanism and won't be able to lock it again. It sounds like whatever you put in to create the connection may be jamming up your opening.
The unit comes with several adapters for different iPod models, you may want to try a different adapter; you shouldn't need to put anything else in it to maintain a connection. If you don't have those adapters anymore, you can probably get them off the altec lansing web site.
Posted on Jan 23, 2011
I have a blown speaker can you tell me if they have replacement speakers for the altec lansing IM7 inmotion
Try getting an old speaker. Alternatively remove the old one by twisting the side of the speaker anticlockwise then unscrew it.
Take it to one of the speaker shops where you could either get something closer to what you have or get a coil rewind and a diaphram change.
Oct 02, 2010 | Altec Lansing inMotion iM7 (021986950806)...
Blown bass speaker, hoping I can buy a replacement.
  1. Contact Altec Lansing.
  2. twist the Speaker frame anticlockwise to open then unscrew the speaker then look for a similar/something close to it(size and amps) one in the local audio shop.
  3. Get it to some audio shop for a recoil and or diaphram change.
May 16, 2010 | Altec Lansing inMotion iM7 (021986950806)...
Disassembly of IM7
have you unscrewed the speakers on the sides? then the loosen the screww under the rubber on the handles? the screws are hidden under the arm carrying groove.
The whole mesh has to come out too.
Sep 05, 2009 | Altec Lansing inMotion iM7 (021986950806)...
My altec lansing im7 stopped working during class
I am having the same problem. Did you ever figure it out??
Jul 28, 2009 | Altec Lansing inMotion iM7 (021986950806)...
Jun 27, 2009 | Altec Lansing inMotion iM7 (021986950806)...
Altec lansing inmotion IM7 how to fix dock door?
I've found a solution. Most likely you have broken the catch inside this part so it needs replacing but don't worry, it's relatively easy to do. The latch is the black piece of plastic behind the door with a claw sticking out.
1. First, email the manufacturer and and ask for a sample latch to be sent out to you. After a bit of research I finally found them. In the UK they make them in white so I ordered one of those as I think it looks better (part #DL1WH): http://www.richco-inc.com/component/jumi/search-parts.html?searchinit=true&searchtype=rohs&interest=DL-1&Submit3=Submit
2. Get a pair of thin pliers and carefully pull out the old latch. To do this pull on on any part of the outer rim. I used the lower edge. Don't worry of you damage it. You'll be throwing it away anyway. Just don't damage any of your speakers.
3. Slide the new latch into position and push into place.
4. That's it. All fixed!
May 14, 2009 | Altec Lansing inMotion iM7 (021986950806)...
IM7 No power. Found out that the plug in switch
re your IM7 'plug in switch' which changes it from battery to 110-----where is that switch located, and how much of the unit did you have to disassemble to get to it? Thanks
Apr 21, 2009 | Altec Lansing inMotion iM7 (021986950806)...
Speaker going out
I had the same problem. Eventually the other speaker quit also. The problem was a broken wire under the door. This required complete disassembly of the unit just to get at these two wires. Sorry the news isn't better.
Aug 05, 2008 | Altec Lansing IM7 (WMM137039)
Were can i get parts for a altec lansing iM7 ipod player
You won't be able to by conventional means - probably not at all.
Unconventional means:
1) Find someone selling a broken or very cheap altec lansing im7
2) Send an e-mail to the Altec product development team, and ask very nicely.
I know this is not what you want to hear, but most manufacturers either don't have parts available in the U.S., or they are not willing to sell them to customers.
Mar 19, 2008 | Audio Players & Recorders
Altec Lansing inMotion iM7 (021986950806) Docking Station Logo
109 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
