Where do I plug my ac adapter in on a sl710 nordictrack
Where is the ac plug to be plugged in on the machine
  • Anonymous Sep 20, 2016
    I have this bike and I cannot find any reference to an AC adapter in the manual or plugging anything in except audio.
    Top Expert:
  • Computers & ... Master
  • 79,865 Answers
Here is a link to the user manual, look it up. http://www.sportsmith.net/images/product_support%5CNordicTrack%5CNTC07942%20-%20NORDICTRACK%20SL710%5CNTC0794.2-209534.pdf
Posted on Sep 07, 2016
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: My Dell Vostro 1500 has a problem. AC adapter
Check the power adapter with a multi-meter, the voltage of the power plug that plugs into the power socket on the laptop should be slight higher than the voltage that is printed on the label on the adapter.
If it is faulty, there are replacement power supplies available on the Internet or at your friendly computer shop.
If the adapter is OK then the power socket on the laptop is faulty or this socket has a dry solder joint connection on the motherboard.
You can test this by wriggling the power plug when it is connected to the laptop, if the charge LED flickers and if you hold this plug in a certain position the charge LED stays on without flickering, then the power socket is faulty.
This can be repaired, but requires the laptop to be completely
disassembled. I suggest you get a quote first.
Posted on Sep 10, 2009
Nordictrack elliptical CX1055 stopped beeping. The unit used to make a feedback sound when a button was pressed. This was in the form of a beep. The unit has not been jarred or mistreated, it just stopped...
follow this troubleshooting steps and fix it.
God bless you
Check power problems if the console on the elliptical machine does not light up. Make sure that the plug for the machine is secure in the outlet. If it is plugged in, ensure that the outlet is receiving power. Check the breaker to make sure it has not tripped off.
Be sure that you are using the correct adapter that came with the elliptical machine. Because different adapters are able to handle differing amounts of energy, the wrong adapter will not transfer electricity like it should. If the adapter is pinched or damaged, this could also alter its effectiveness.
  • 2 Make sure the correct adapter is being used if the resistance settings seem to be too hard or too easy. If the correct adapter is being used, reset the machine. To reset the machine, either switch the "On/Off" button or unplug the machine from the wall. Doing this will allow the device to reset itself to the default resistance. Turn on or plug the device back into the wall and retry all of the levels of resistance.
  • Sponsored Links
  • 3
    Do not be concerned if you see small particles left on the guide rails. Over time, the roller wheels gradually wear down. When this occurs, they leave residue on the rails. Because this is considered to be normal wear, all you need to do to fix the problem is wipe the rails off with a damp cloth.
  • 4
    Minimize the risk of receiving erratic readouts on the monitors by avoiding outside interference. For example, gripping the heart rate handlebars too tightly can affect the monitor. Similarly, the heart rate grips can be rendered less effective when there is too much vibration. Consider not holding these monitors throughout the workout to minimize vibration. The readouts also can be affected by jewelry. To minimize errors, take off rings and other jewelry before working out on an elliptical machine.
  • Read more: http://www.ehow.com/how_6149016_troubleshoot-elliptical-machine.html#ixzz2gTKOfuoB
    Oct 01, 2013 | Nordic Track Nordictrack Cx1055 Elliptical...
    Laptop is turning on and off
    Remove the AC adapter (Charger)
    PROPER method is to disconnect the power cord of the AC adapter, from power; THEN unplug the AC adapter from the laptop.
    Same thing in reverse to plug the AC adapter back in.
    AC adapter is plugged into laptop, THEN AC adapter is plugged into power.
    Unplugging the AC adapter from the laptop, while being plugged into power; can cause a Voltage Spike.
    You may get away with it for years, and several laptops; and have no problems.
    However it only takes ONCE, to fry out the SMD fuses, Multi-Layer Ceramic Capacitors, and Power MOSFET's, on the laptop motherboard's DC to DC circuit.
    Jus sayin'.
    Moving on........
    AC adapter removed, remove the Battery.
    Press the Power On button in, and hold in for a count of 10 seconds.
    Let go.
    Do this procedure 2 more times.
    (Draining residual power)
    Reinstall the Battery. Attach the AC adapter, plug AC adapter into power. Let the Battery charge 24 hours.
    Then turn the laptop on, and tell me what happened.
    Regards,
    joecoolvette
    Mar 15, 2013 | HP Pavilion Computers & Internet
    Nc6000 multibay battery does not recharge
    Perhaps remove the multi-bay battery, and let main battery charge all the way. Then reattach multi-bay battery, and see if it's recognized.
    (Will charge)
    That is AC adapter (Charger) removed, then remove multi-bay battery.
    Plug AC adapter back into laptop, THEN plug AC adapter into power.
    [You do Not want to unplug an AC adapter from a laptop, with the AC adapter plugged into power. Could be a power surge/voltage spike. Unplug AC adapter from power, when plugging into laptop, or unplugging from laptop ]
    Main battery charged, unplug power to AC adapter, unplug AC adapter from laptop. Plug multi-bay battery in, then AC adapter.
    (Then plug AC adapter into power)
    Post back in a Comment.
    Regards,
    joecoolvette
    Feb 28, 2013 | HP Computers & Internet
    NordicTrack SL710 pedals slip and make a clicking noise?
    Kneelnext to the left side of the elliptical's base. Use the Phillips screwdriver totighten the two screws located in the center of the left pedal.2
    Use theAllen wrench to remove the bolt securing the left pedal arm to the pedal legand body arm. Use the Phillips screwdriver to remove the screw securing therear end of the pedal leg to the crank arm.3
    Pull theend of the pedal leg free of the crank arm. Wipe the crank arm clean, thenapply a fresh coating of machine grease or silicone lubricant. Replace the endof the pedal leg back onto the crank arm and use the previously removed screwto secure it back into place.4
    Join thefront end of the left pedal arm to the ends of the pedal leg and body arm. Usethe previously removed bolt to connect the pieces together.5
    Move to the right side of the elliptical and repeatthe above steps on the right pedal arm
    Oct 31, 2011 | Nordic Track NordicTrack Treadmill, A2550
    How to charge my new battery for laptopLG K1 Express
    connect the ac adapter to ac input..then plug the adapter to your electric outlet..
    make sure you plug in to the right voltage ,read manuals of your machine for proper care and maintenance
    goodluck..
    Feb 20, 2011 | Computers & Internet
    Owners manual for a nordictrack sl710 exercise bike
    I have NordicTrack SL 710 exercise cycle the seat hurts my tail bone, is there any solution for it, or different seat - similar like on the real bikes with groove?
    Sep 12, 2010 | Sport & Outdoor - Others
    Exercise bike is not displaying correct feedback
    What do you mean it s not displying correctly?
    May 03, 2010 | Exercise & Fitness
    Bad motherboard for M1730
    take out the battery of your machine and plug in the power. if it works well, suspected faulty battery. you need to replace it.
    May 19, 2009 | Dell Inspiron 6000 Notebook
    Computers & Internet Logo
    369 people viewed this question
    David Payne
    David Payne
