Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I have a belkin N600 db wireless N+ ROUTER F9K1102V1 NEED TO DOWNLOAD CD DISK
SOURCE: Downloads locks up - Belkin N1 Wireless Router
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now. Hope this helps, and good luck!
Posted on Sep 03, 2008
KingDWS
  • 1606 Answers
SOURCE: Part # F5D8233-4 belkin wirless router need software cd
You don't need the cd. It has a connection wizard that helps set it up but you don't need to use that. You need to go to the belkin website and download the manual. That was also on the cd that's missing. Used to be a paper one in the box.
http://cache-www.belkin.com/support/dl/f5d8233-4_v1_manual.pdf
That will tell you how to get setup. For the most part routers run as is right out of the box. You will want to setup the wifi so you will need a SSID name to call it and then turn on the security. WEP or WPA are the usual suspects. Pick a 5 or 10 alphanumeric key. Turn on the wifi. Then you may need to enable dhcp so your computers will get ip numbers from the the router. Most of that is enabled by default on most routers. Wifi usually isn't as it requires more information.
Posted on Jul 21, 2009
BLAZZ81
  • 281 Answers
SOURCE: Belkin N Wireless Modem-Router F5D8633 drivers
Just hook it all up, and push and hold the reset button in the back of the router for 10 sec..
Then unplug your internet box, [cable/DSL box] and plug back in,
The internet box will send a IP to your router automaticly.
[If it dont work unplug power from both boxes, then back in but plug the internet box in first..]
done..
if your useing wireless this will not be setup with a password to join, and will be open to neighbors,,
If you want to go to the next step and setup a password to join, you can do this with out the cd also, but get it working first and hit me back
Posted on Sep 12, 2009
jaye_ellen
  • 591 Answers
SOURCE: I have los the installation CD for a Belkin N
Check out this site:
http://www.techspot.com/drivers/driver/file/information/12623/
Posted on Nov 03, 2009
govinda123
  • 2263 Answers
SOURCE: Belkin F5D9230-4 Wireless G Plus MIMO Router setup
To set up the router , you don't need the CD.
you can do it manually.
First make sure that your computer is able to go online through the modem.
If yes then connect the modem and the computer to the router and set up your router.
Click here for step by step solutions
Posted on Nov 27, 2009
How to get my Belkin N600 DB Model #F9K1102 V2,setup to my TV, with Google Chromecast?
Download the Chromecast App to your phone or tablet. Open the app, search for your Chromecast device and set the device up by telling it your router SSID (name) and password.
I believe you can do it with a PC by going to the Chromecast website.
Nov 30, 2016 | Belkin Computers & Internet
How do I turn off the guest account on my router for the internet.I have windows 8.1
Hi
You should be able to do this from a web interface using an internet browser, or from the software utility that came with the unit and needs to be installed on your PC from the CD-ROM. Both thes methods should work on Win8.1 as you are altering the router settings not the PC settings. I give below a link to the router manual which will take you through both procedures.
http://cache-www.belkin.com/support/dl/MAN_F9K1102_8820-00777_RevA02_N600.pdf
I think pages 6, 20, 21 will be most relevant to you.
Cheers
Nov 02, 2014 | Belkin N600 DB Wireless Dual Band N Router
I lost my belkin N600 DB Wireless N+Router Model:F9K1102v1 cd software,so i want to download it online by the net.
You don't need the CD to setup the router. I made a video showing how I did it to my F9K1003V1.
Feb 28, 2014 | Belkin Connect N150 Wireless N Router
Someone pressed the reset button on my belkin n600 db n+ router, and now I can't get it to work with my laptop! Help
It just clears any custom settings, and the laptop IP may still be cached (in memory).
From the laptop go to Start > Search (Run in XP) and type cmd ENTER. In the command prompt type ipconfig /release ENTER. Then type ipconfig /renew ENTER. This just refreshes your IP. Test it. Remember custom network and password are gone.
There is a paper tab underneath the unit with the default wireless name and password.
Use a network cable computer to access web interface. 192.168.2.1 to see that information as well. No user or password for the web page.
Oct 25, 2012 | Belkin (F5D7230-4) Router (587009)
Can't plug in router
just do the following:
1. There is a yellow wire in your modem which is connected into a computer take that out of a computer and insert it in a router in 1st socket.
2. Then insert the INSTALLATION CD into the computer and follow the instructions.
Jan 01, 2012 | Belkin N600 DB Wireless Dual Band N Router
Since I purchased a Belkin N600 my download speed is about 30k/bps. My ISP says it's the N600. Help!!!
If you are wirelessly connecting you need to use a wireless card that supports dual band.
and then changnig the settings on the wireless card helps.
if you are wired the issue is with the router settings.
Upgrade the firmware on the router
see belkins website on how to do this:
http://en-us-support.belkin.com/app/answers/detail/a_id/4497
Apr 07, 2011 | Belkin Play N600 Wireless Dual Band Router...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
572 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
