Daughter got the leapfrog leap pad 2 for christmas was doing great she wouldnt put it down. but now it wont hold a charge dont know why it was charger all night and when she got up to play on it as soon as she unpluged it the battery light flashed and shut off please help whats going on cause she can only play it when she has it pluged in to the outlet
SOURCE: Leapster 2 will shut off right after the "important" screen
Are you using it with a game? Will it stay on if NO game cartridge is in & are U able to access & play Pre-installed games?
If so, it may be the cartridge is DIRTY. I discovered this with our Leapster 2. What works for us is getting a Q-TIP & RUBBING ALCOHOL, you want to saturate Q-tip with the rubbing alcohol & clean the CARTRIDGE (NOT the Hand held ).
You want to clean the computer chip @ the bottom by inserting Alcohol soaked Q-tip on each side of contact strip (the part that inserts into the hand held) & with the dry end of Q-tip go over it again, for more cleaning & to wipe up any EXCESS Alcohol. REPEAT this process until Q-TIP comes back CLEAN.
I was really surprised @ ALL the BLACK grime that came off cartridge.
I hope this helps.
Good Luck.
-The Johnson Family :-)
SOURCE: LeapFrog Connect Application has encountered a problem
I would completely remove the software and reinstall it. I recently bought the Tag Jr after already having a regular Tag installed on my computer, and had to completely re-download everything. LeapFrog's website today also said that they were experiencing much higher than normal traffic, and some applications may not work as well or as fast.
SOURCE: mouse not working on Click Start - Leap Frog
I am still waiting to know what to do.Is there a substitute for this mouse?
