Question about Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony trinitron KV G21S2(i think)
Hi I have a Sont Trinitron... I have absolutely no knowledge about what type of tv it is. All i know it older than 10 years and i dunt even think it is a flat screen. I think the model is sony trinitron KV G21S2, about 15inches. Recently I think a fuse blew as I tried to turn the tv by pressing the main power button on the tv as it couldnt be switched on by remote or other means. As i pressed the main button I saw a small flash like explosion in the back. Now the tv cant turn on, and no light is emitted (near the main power button). What happened and is there any way of fixing it? Please reply back and comments will be greatly appreciated.
  • Andre1984 Feb 01, 2008
    I am having the same problem. When I switch the tv on through the button there was a flash, and it would turn on. However I know how to read a circuit diagram and its components very well. I had a quick look but of a preliminary inspection found no capacitors blown.
    The power supply seems to be pulling three amps and blowing the fuse, each and every time I put the tv on once I hve replace the fuse.
    Do you know a quick fix, any idea what it could be ? Or do you know were I could possibly find a circuit diagram, or service manual.
    Help please
    Thanx in advance
  • tom Apr 27, 2008
    I have a sony trintitron KV 27V55.
    It worked fine and then I came to turn it on and nothing . it's as if the switch is defective. I've tried from the front of the TV as well as the remote...no response to either one.
    It is plugged in...
    Is there a fuse on this model? If so , where.
    Suggestions?
    Thanks,
    Tom
    President:
  • 3,130 Answers
Id you have no TV repair experience, play it safe and take the set into an authorized Sony repair place to estimate the cost to repair. Yes I know it would be nice to repair, but how much do you know about component level printed circuit board repair? You will need to first get a service manual, know how to read a circuit diagram, thats a schematic, and know how every circuit works with each other to make the TV set operate. I do appriciate the fact you would like to repair this yourself, but there is no magic fix in most cases when it comes to electronics. There is circuit diagnosise involved. Best advice would be to call in a pro to assist you in these types of repairs. Good Luck
Posted on Jun 23, 2007
SOURCE:
Sont Trinitron comes on but turns off after about 30 seconds
Try to turn it off and on with the remote about 6 times. Do not use the power button on the tv
Mar 06, 2015 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron Wega KV-27FS100 picture on and off
i'd say your tv is unhappy.
unplug for 10 min..and see if that resets it.
May 31, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
WHAT IS THE MODEL NUMBER OF THE REMOTE FOR SONY TRINITRON 29 WEGA KV-SW29M50
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 09, 2014 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
No Display, no sound- not working, showing dead. But input Power is ok. Picture tube filamment not getting power. model sony KV-2192M3
Hello
Check the input fuse first. If it is blown, there will be some short inside the power regulator circuit. Usually Sony sets uses STR regulated power supply. You can see this STR, and Ic, screwed onto a heatsink. Replace it with a same type and number. Before replacing the STR, check the diodes used in that section for damage, mainlu zener diodes. They might get shorted along the blowing of the STR. Check that section throughly before resoldering the new STR.
If any further assistance you needs, get me through Fixya. Ok.
Nov 27, 2010 | Sony FD Trinitron WEGA KV-21CL10 21" TV
My sony trinitron turns off by itself and then the stand by light blinks five times then pauses for like 4 seconds then flashes 5 times and repeats
This is picture tube related problem and we call it incorrect white balance.
Adjust Screen Volts of picture tube and control knob wold be located on flyback transformer. If you have knowledge about tv and know that tv contains high voltage and you can take care of that then do it yourself or ask local tv repairman to fix it.
Thanks.
Jun 12, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My Sony WEGA Trinitron 36'' TV has red instead of green, how do I reset the picture or fix this?
try this reset in this see if it works
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
Mar 06, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron kv-36fv26 (2000) tv wont show picture
Trires unplug,replug about an hour later see if it reset it self.Not take to the shop the two power ICs help the power it dead.Need it replaced.
Jan 27, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
About Sony Trinitron KV-28LS36B
there are two possible defects in your circuit.
However, if the led blinks for about 10 times your tuner is defective 90%.
You will need a scope to check or you will need to take it in for service.
Oct 13, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony FD Trinitron WEGA KV-20FS120 20" TV Logo
498 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
