The Control Panel displays d5 and the panel is locked. Nothing will happen when I press any of the buttons
SOURCE: can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
SOURCE: GE Frontload Washer Adora series duet pair
you may or may not hear clicking as it tries to start.
See this link for troubleshooting it. and to open door.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
SOURCE: ge profile washer has a d5 code that is displayed machine
CHECK THE TIMER. I DON'T KNOW IF THAT IS WHAT IT IS, BUT IF IT IS YOUR TIMER, YOU NEED TO CALL A REPAIRMAN AND SEE IF HE CAN FIX IT FOR YA. HOW OLD IS YOUR WASHER?
RODNEY
SOURCE: control panel "locked" on ge advantium 120
You might have set the child lock. Look in the manual. It is on P.36 in my manual.
SOURCE: GE Single Ovwn control panel
Fix the probelm, don't replace it with another of the same problem. Try this, it's gonna work! First of all, turn off the circuit breaker. Don't replace anything. The insulation in the ribbon cable is poor. The conductors in the cable are crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. Turn the breaker back on. There, problem solved.
