Question about Uniden DCT-7488-2HS Digital Phone
Uniden 2.4ghz digital house phone
I cant get my phone to use tone. it dials as if i were using some old phone system please help
    Novelist:
  • 201 Answers
There is a "Tone / Pulse" switch or program setting you want set to "Tone". It would be part of the base unit and not an option on the cordless handsets.
Posted on Jul 07, 2007
SOURCE:
How do I reconnect my corded Uniden phone with digital answering system?
Things to consider.
If using a VOIP system (via router) please consult your provider for the port(s) you should have open.
Some features are enabled on the system management page.
If you are using a tradition phone line, first consult your manual then your provider.
Hope this helps
May 30, 2014 | Uniden 5.8GHz Expandable Cordless Phone...
When telephone line is connected no dial tone,any number press ask by line,please check the number you dialled ,after some seconds the telephone line becomes disorder.
are you using a modem? do you have a fax machine? switch the fax off. if a modem is present the main phone must be connected to that modem and the additional phones place through out the house (using other phone jacks)
Jul 27, 2010 | Uniden 2.4 GHz Expandable Phone System...
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Uniden PowerMax 5.8 - system busy error comes up & no dial tone
Unplug the power supply to the base of the main handset, wait 10 seconds and plug back in.
Mar 27, 2009 | Uniden TRU546 Remanufactured Dual Handset...
I HAVE A UNIDEN DECT 6.0 PHONE THE HOUSE AND IT WITH NOT DIAL OUT OR LET INCOMING CALL COME IN PLEASE HELP ME WITH THIS PROBLEM ! MY NAME IS JULIUS C FREDERICK MY NUMBER IS 803-741-0511 EMAIL IS...
Dial Tone comes back even after I dial the phone!
Question:
Why does my phone allow me to dial a number, hear the numbers being dialed and then go back to a dial tone? Help me I want to call out!
Answer:
Sir the you are dialing on needs to have the other dial mode in operation. You have the ability to change dial mode on your phone. Instructions to change dial mode are usually at the beginning of the manual under install /set up the phone. If you are currently using pulse, please change the mode to tone. If using tone please change the mode to pulse. Doing this will allow you to call out.
answer found on www.uniden.com
Sep 07, 2008 | Uniden 5.8GHz Dual Cordless Phone
tengo el mismo problema sin manual lo q no se es como hacer funcionar al gemelo despues de cargarlo tu sabes? contesta aqui. gracias.
Mar 24, 2008 | Lands Phones
Can't make or recive calls
here is link to the instructions
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
first, test the actual socket using a good normal phone.
if no dial tone, get phone company to test the line.
if line ok, fully charge handset for 10 hours, if still faulty, follow the procedure to de-register and re-register your handset with the base unit.
Jan 17, 2008 | Uniden Cordless Phone
Lands Phones Logo
119 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
