Question about Rosetta Stone Computers & Internet
Error 9119, 9114 rosetta stone
This is the error i get while trying to load disc 2 only the other 4 loaded fine.
  • 3 Answers
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
Posted on Jan 16, 2014
I have the same problem when I try to install the language gives me error 9119 ...
I help please, I have win 7
Posted on Dec 05, 2013
4 Suggested Answers
laikexpert
  • 281 Answers
SOURCE: Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Posted on Jan 04, 2010
rockmeister
  • 2047 Answers
SOURCE: Off Ebay, I purchased Rosetta Stone for Mac,
When such problems occur the first thing to do is identify the meaning of the error message. The error message above has a follow up in the program which says click ok to continue. When you clicked ok what was the next thing that happened?
Also try restarting your unit and installing the program again.
Posted on Apr 14, 2011
xx3ryan3xx
SOURCE: Rosetta stone problem installing language discs
I just had the same problem. Rosetta Stone TOTALe French Level 1. I just ran it in Windows XP Service Pack 2 and it installed right away.
Posted on Aug 14, 2012
Rosetta stone 9114 on mac
You get Error 9114 on Rosetta Stone if you have a bad disc or secutity settings. Find the fix at Questions Rosetta Stone Community
Jul 02, 2014 | Rosetta Stone 3 Farsi Level 1 2_3 Set Full...
I have a Rosetta Stone V 3.4.5 and Win Xp. Rosetta Stone doesnt recognize the mic. What can I do to fix this error. The number of th error is 1117. My OS is Win Xp Waiting for help Alex
Create a security exception. 1. In ESET NOD32 (Smart Security 5), click Setup.
2. On the Setup screen, click Enter advanced setup... (bottom of screen).
3. On the Advanced setup screen, open Computer -> Antivirus and antispyware -> Exclusions.
4. Click Add , locate/select the Rosetta Stone Version 3 executable, then click OK. (In my case, the executable was in the C:\Program Files (x86)\Rosetta Stone Version 3 folder.)
5. Click OK on the Advanced setup screen.
Set the Rosetta Stone compatibility mode. 1. Right click the Rosetta Stone desktop icon or Start -> All programs -> Rosetta Stone.
2. Select Properties from the list.
3. Select the Compatibility tab.
4. Check the Run this program in compatibility mode box.
5. In the list below the check box, select the OS (in my case, Windows 7).
6. Click OK.
Sep 23, 2011 | Rosetta Stone Spanish (Latin American) -...
Hi, I'm using Rosetta Stone 3 online through a school license. I keep getting a 'loading next screen' box popping up, but it gets stuck at three quarters loaded, and refuses to go any further! Any ideas on...
Do you have the issue with other levels or languages as well? Maybe you can try removing and then adding the languages again, and see if that helps. As a last resort, you can also try reinstalling Rosetta Stone if this occurs with all languages and levels you own.
Mar 12, 2011 | Rosetta Stone Version 3 Swedish Level 1 2...
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
Apr 07, 2010 | Rosetta Stone Spanish (Latin American) -...
Error 2123 appears when loading rosetta stone
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
Feb 20, 2010 | Rosetta Stone Japanese Level 1 & 2 for...
There is an error with this application
Nov 23, 2009 | Rosetta Stone V3 Spanish (Latin America)...
or
Jun 16, 2009 | Rosetta Stone V3 Spanish (Latin America)...
Computers & Internet Logo
1,239 people viewed this question
Top Rosetta Stone Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Jax Planet
Jax Planet
IT GURUS OF ATLANTA
IT GURUS OF ATLANTA
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
