Question about Motorola Mobility W490 Cellular Phone
Phone is wet please help!!!
It only got water in the battery when i took it off there was a lot of water in the back which had been there for about 5 hours. it has the red dot but the screen is not foggy. ive tried blow drying it and resetting it nothing works. when you turn it on it says verizon wireless for 10 seconds turns black for a sec then does this over and over. what can i do? I just dropped my phone in my bath tub, I took the battery and SIM card out, I was blow drying it on a low setting til I rerad this. I'll place it semi-near my space heater for a while.
  • dancechik21 Jan 18, 2009
    I left my phone in a bag of rice over night and the next morning I took it out and it worked completely fine
  • 80 Answers
If it is not ruined you could leave it in a jar of dry rice. This should take care of the moisure.
Posted on Jan 18, 2009
My phone got wet and upon repowering safe mode came on now i need help turning off safe mode
i had safe mode come on as well it was because i hit another button during start up i just restarted the phone and it went back to normal if your phone is still wet take out sim card and battery place phone in a bag of rice for 24-48hrs that will draw out the moisture from the phone
Jul 05, 2014 | Straight Talk LG L40G Cell Phone
Wet blackberry bold 9900 and flashlight wont turn off
Well first you went wrong by plugging it in, honestly your best bet now is to put it in a package of rice to soak up all the water and hopefully it works from there. Although I hope someone can give you some better advice.
Jul 12, 2012 | RIM BlackBerry Bold 9900 Cell Phone
Samsung Jet Cell Phone is "dead"
under warranty will not count on liquid damage if you take the battery out you will see a red dot that tells you water damage i have dried out some mobiles take out battery and sim leave on warm radiator couple of days then try again if still the same then it spares cost way too much to put right needs mother board ,and connectors hope this helps
Apr 30, 2010 | Samsung Jet S8000 Cell Phone
Got camera wet
If your device gets covered in water, act fast and rationally, and you may be able to save your device.
1. DO NOT TRY TO TURN IT ON
2. Pull out the battery.
3. Please your device and battery into a bowl of uncooked rice to absorb any moisture.
4. Please it in a warm, dry place where it can receive direct sunlight.
5. Be patient. It is recommended that you leave it in there for at least 48 hours.
6. After 48 hours, put the battery back in and power on.
Sep 25, 2009 | Sony Handycam DCR-TRV320 Digital Camcorder
Wet Phone with Download screen
it may sound funny but put the phone, battery and nething else that got in a bag of dry rice. it will soak up any water left in the phone. that may fix your problem.
Sep 13, 2009 | Samsung Propel A767 Cell Phone
LG PHONE STUCK ON EMERGENCY DOWNLOAD
I had the same problem!! This might help: 1. Take out the battery, SIM card, and memory card (if applicable). 2. Let the phone sit in the sun for a couple of days. 3. Put the SIM card back in the phone and plug the phone charger into the phone. 4. When prompted, insert the battery into the phone 5. When battery is fully charged, remove the charger and depress the call button simultaneously.
I tired this and the phone is now working!!! Also, I do not seem to have lost any of the features!
Good Luck!!!
Jan 27, 2009 | LG Vu CU920 Cellular Phone
Dropped in the toilet..any ideas on how to bring it back to life?
Hi there.... I have had many cell phones that have got wet and stopped working and every time I had to take out the battery and sim card, lay on side for at least 12 to 24 hours and they all came back to life. I don't think the freezer is the best idea.
That has always worked for me. Did you call customer/tech support for your carrier?
Dec 31, 2008 | Samsung Propel A767 Cell Phone
Try to let the phone dry out by itself, set it on the window sill let it dry out for a little while, a lot of times water still gets down (internally) inside the phone, so it looks dry on the outside but it's still wet on the inside of the internal components. Try to let it dry out for a couple hours in the sunlight, caution, though, don't let the screen sit with direct sunlight bearing down on it.
I would caution on using the blowdryer, too hot of a setting can damage the internal components, so use the lowest setting possible. you can also try a low suction vacuum cleaner, also...
Ensure you:
Immediately take the battery out, and leave it out, water and electrical components don't mix.
Take out the sim card and attempt to dry it, just be careful with it because it's sensitive.
Let it sit next to a low heat source for a couple of days, periodically checking up on it. But I would'nt try to power it back up until you are confident that all the water is gone and evaporated out of the phone, otherwise you could fry the internal circuits and damage your phone.
Nov 13, 2008 | Cell Phones
LED Problem
try clining it using brushteeth and a lilbit of medical alcohol
the n dry it witha hair dryer teh tell me what u got
plz do rate this post
Sep 24, 2008 | Nokia N73 Cellular Phone
Wet motorola l6
okay...you should purchase a new keyboard that should help.
Dec 18, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility W490 Cellular Phone Logo
88 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
