Question about JBL CS300.1 Subwoofer Mono Amp - 200W CS Series 300 Watts @ 2 ohms Car Audio Amplifier
JBL CS300.1 Car audio amp wont stay on.
My JBL amp is hooked up correctly but when I start the car sometimes the amp will come on and sometimes it wont. When it does it only stays on for a couple seconds, and i get no sound for those seconds its on. What is the problem?
5 Suggested Answers
tech48
  • 624 Answers
SOURCE: Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
Posted on Jun 16, 2008
  • 61 Answers
SOURCE: JBL CS60.2 Car Amp is fitted to new sterio but
The blue wire to your amp (remote signal wire) needs to be connected to the red power lead for your deck. Right now it sounds like you are connected to constant power on your signal wire.
Posted on Apr 04, 2009
etirbynnor
  • 655 Answers
SOURCE: JBL GTO 301.1ii protect mode
Hello roets81,
Check the voltage at the amp. It's possible that the voltage is either too high (above 16V) or too low (below 8.5V). Also make sure that the amp case is not grounded. If these check out OK, the most likely cause is that the amp itself is defective and requires service.
Hope this helps.
Posted on May 27, 2009
SOURCE: jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
http://documents.victorytechnologies.com//documents/product/2322.pdf
Posted on Nov 09, 2010
JBL GT5 A402 amplifier wont stay on
try isolating if the ground is the issue and ground it to something else using an extension wire and perhaps the hinge of the car door.
If that is it then find another permanent ground
Mar 15, 2013 | JBL Gt5-a402 Gt-series Class Ab 2-channel...
BP1200.1 Car Audio Amplifier: is that amp good for 2 12 inches subs kickers 600...
that will most definitely be the best amp you will own and the only amp you will ever need to purchase.
May 13, 2010 | JBL BP1200.1 Car Audio Amplifier
Jbl am in protect mode
if it goes in protect mode means ur amp is turn up to high or it is over heating so it protectn it from fryn ur amp try to adjust it down
Jul 12, 2009 | JBL BP1200.1 Car Audio Amplifier
Hello roets81,
Hope this helps.
May 27, 2009 | JBL GTO 301.1 Car Audio Amplifier
Jbl amp didnt work
broken amplifier, remove it and send it to repair before you get your car up in smoke, there is nothing you could do.
Apr 10, 2009 | JBL GTO1201.1 Car Audio Amplifier
Subwoofer Wont Work
If the connections are correct...?
then it doesn't sound like theres a problem with the amp.
make sure the amp is not to powerful for the sub?
eg: 1000w amp, 500w sub.
Sounds stupid but it happens.
make sure the gain / volume is not too high!
if your BMW has a totally sealed, metal boot area this doesn't help.
Dec 11, 2007 | Sony XM-2150GSX Car Audio Amplifier
Concept CC-2502 Car Audio Amplifier
The amps are probably going into protection mode. The wires are most likely not hooked up correctly. Make sure you have a good ground, good power source, and the remote wire is run correctly. Also make sure the speaker output wires aren't touching each other, and you have the correct ohm load for the amp. What kind of speakers/subs are hooked up and how are they wired?
Sep 20, 2007 | Concept CC-2502 Car Audio Amplifier
Car Audio & Video Logo
89 people viewed this question
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
