Question about Tools & Hardware - Others
Change bit on Wizard
I'm having trouble changing the bit on my Wizard rotary tool. Does it twist to release the bit?
  • 132 Answers
SOURCE: how to change tool
There is a button on the side of the tool near the tip. (Make sue the tool is unplugged or the battery is out) Hold that button in while take the little wrench provided to loosen the collet. You'll see the nut just behind the collar which holds in your accessory.Turn counter clockwise. You may have to turn 1/2 to 3/4 turn for the button to engage the spindle lock.
Posted on Jun 27, 2009
rowdy45176
  • 2176 Answers
SOURCE: i have a rotary wizard and no instruction book.
If this is a Black and Decker you can go to Dewaltservicenet.com and find a manual there usually. If not there is a phone number that you can call and probably get one.
Posted on Sep 21, 2009
SOURCE: I borrowed a black and decker rotary tool (RT
slide the orange on/off switch all the way back then push in the black button the switch slides over. This will lock the shaft-then use small wrench provided w/ tool to turn the collet nut
Posted on Oct 07, 2009
  • 86 Answers
SOURCE: I don't know how to change the bit on my dremel
Push the pin on the side next to the tip and hold it while Your wrench is turning the hex shaped piece around the bit that is what is holding your bit in. this should help as i am a proud owner of a Dremel. Hope this helps . if you have any further questions write back.
Posted on May 06, 2010
SOURCE: black and decker wizard rotary tool spring
no replacement available - you are going to have to fabricate a replacement starting with the broken drive spring - usually one of the end tangs breaks off - cut off the other - take a piece of bar stock/drill rod that fits inside the spring - grind a flat at each end of bar to engage the motor and output shaft - install
Posted on Dec 10, 2010
How to change tools on black & decker wizard rotary tool with flex wand
Hold the lock in on the unit, loosen the collar on the end of the wand and change the bits.
Aug 13, 2014 | Tools & Hardware - Others
Trying to change drill bit on Craftsman Rotary Variable speed drill
Lock the spindle (small chrome button near the tool's nose or lever at the power switch). You'll probably need to rotate the spindle by hand as much as one full turn as you do this, to get the lock to drop into place.
With the spindle locked, use your supplied wrench to turn the collet nut counter-clockwise (as seen from the cutter end) about one full turn. The collet should now be plenty loose enough to release the cutter / wheel / drill.
Mar 26, 2014 | Craftsman Variable Speed Rotary Tool Kit
Dremel 3100 won't release the drill bit. Button at the top is pressed in and won't come out.
The button is only to keep the shaft from turning while you loosen the collet (the nut) with the little wrench. THEN the tool comes out.
Sep 25, 2012 | Dremel Variable - Speed Multipro Rotary...
I have been given a durabuilt rotary tool but have no manual or instructions on how to use, and I can't even figure out how to change bits... is there a free or inexpensive manual that I can obtain?
WEN Products has a rotary tool that is very nearly an exact duplicate of the Durabuilt rotary tool. I use the WEN manual at home for my Durabuilt rotary tool.
If you would like to see the WEN product page for their rotary tool, please visit this link: http://www.wenproducts.com/store/101-Piece-Rotary-Tool-Kit-2307
Here is a direct link to download the manual: http://www.wenproducts.com/store/index.php?route=product/download/download&download_id=62
Sep 05, 2011 | Garden
This hasn't been used in a long time and I'm trying to change the bit/head. Even with the Collet nut loosened, the bit that's in there will not budge. I even took the Collet nut right off to...
Is it possible to grip each part with a pliers and twist and pull at the same time to release the bit? Let some oil run into the collet before you do this.
May 12, 2011 | Craftsman 2.0 amp Rotary Tool Kit
Dremel will not turn on?
IF you don't release the bit lock, it won't run.
Aug 01, 2010 | Dremel 395 Variable Speed Multipro Rotary...
I have a Dewalt dw600 and the drill bit broke off, just the main cutting bit, and I cannot remove the bit- I try to unlock but it won't come off.
DW660 is suppose to be a tool free bit insertion and removal. However a wrench may be necessary. If you have loosened the the collet nut either with the collet grip or a wrench and the bit does not come out. Remove the collet nut completely from the tool. Remove the the collet with the bit in it. With a couple of plyers, one use to hold the broken bit the other to twist the collet. Sometimes when the bit is overtighten the collet locks on to the bit so to speak and the collet wont expand back out thus releasing the bit by doing the above it will expand back out and release the bit. Reinstall the collet and collet nut.
I hope this helps, thanks for using FIXYA. Good luck and have a great weekend. Jeff
Apr 16, 2010 | Dewalt cutout tool DW660
How to switch out bits on wizard rotary tool
1> UNPLUG THE TOOL to prevent any accidents
2>near the bit, there is a button. Push this button and manually rotate the chuck until it locks into place.
3>using the included wrench, turn the chuck counter clockwise until the bit is released.
4>reverse the process to install a new bit
5>make certain the chuck is tight so the bit doesn't come out during use
Oct 26, 2009 | Black & Decker Saws
How do i get the bit off my black and decker wizard?
Push down on the black button in front of the orange on-off switch and then twist off the bit.
Oct 22, 2009 | Black & Decker 2 Amp Rotary Tool
I have a rotary wizard and no instruction book. How do i change the tool
Jun 29, 2009 | Black & Decker 2 Amp Rotary Tool
Tools & Hardware - Others Logo
21 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
