Question about Microsoft Xbox 360 Console
Can't get the disk tray to open
I need to retrieve the game disk before sending the machine in for repair. The two left lights flash upon turning the machine on and the tray is non-responsive. Is there a way to get the tray to open?
  • 296 Answers
Take your face plate off and see if there is a small pinhole around the dvd drive and put a paper clip in it and push. If not you could give it a little bit of a whack on top of the dvd drive, I know a few people that have done that and it worked.
Posted on Jan 18, 2009
How do I get the game out of the console?
Unfortunately, if your console is under warranty, retrieving the disk will destroy it. The only way to actually eject the disk will require disassembly of the entire console. What has happened is that the disk was caught on the upper lip of the disk drive's housing, and fell to the back of the tray when the tray finished ejecting completely. This is a rare issue, and the process of causing this may have already damaged your game disk beyond repair, especially if you tried to forcefully inject the tray. My advice would be to take it to a local electronics repair shop and consult them on whether or not they are willing to repair it for you. If you simply must do it yourself, be in full knowledge that you will be destroying any warranty you have left, and if you do something wrong, you may break part, or all, of your console in doing so. There are plenty of guides on the internet for disassembling your console as well, so the information is there if you wish to follow that road. Either way, best of luck.
Apr 24, 2014 | Microsoft Xbox 360 Console
Powers button keeps flashing
This means that your DVD-ROM drive in your console is so fried, that the console cannot even detect that it is there. You will need a new drive, and if you don't have a copy of the unit's DVD-KEY, you will also need to hack the console temporarily to retrieve said key, as without it the DVD drive will not accept game disks as anything more than video DVDs.
Nov 29, 2013 | Microsoft Xbox 360 Console
Xbox 360
Most likely your disk or dvd drive is dirty. Run the disk through a disk cleaner and run a dvd cleaning disk through your drive.
If that dos not work, try removeing disk, close drive, turn off console, unplug power supply, wait 10 or 20 seconds, then reconnect power supply and try again.
If that fails, assumeing other disks will read, your disk may have a major flaw. You can check with your local game store, they often have a machine that may restore your disk, (most places that I know of charge like 1 or 2 $).
Mar 10, 2010 | Microsoft Xbox 360 Console
I place disk in console and it says "open tray".
If your Xbox 360 will not play your games this is because of the sensors on the back of the drive overheating it is not normally the laser.
Luckily you can fix this yourself and get back to your games and to do this you need the proven Xbox 360 Repair guide.
Or you can send it in and they will fix it for you the repair will take about 4 weeks.
Jan 31, 2010 | Microsoft Xbox 360 Console
Tray won't open flashes centre green. Opened
The center of your Xbox 360 has malfunctioned due to overheating which has caused the tray to have various problems. The solution? Simple! Replace the hard drive or send it in to Microsoft!
Nov 26, 2009 | Microsoft Xbox 360 Console
Disc dive out of blown up xbox
If the tray does not open when you press the eject button, then manually open it to retrieve your game disk as below.
1. Unplug your Xbox console from the power source.
2. Find the manual release button, ususally located in a small pinhole to the left of the eject button under the disc tray.
3. Insert a straightened paper clip or other small tool in the hole at an angle to the left. Gently push the paper clip to try to press the manual release button and partially open the disc tray. This may take several tries. Typically, a thin paper clip works better than a thick paper clip.
After the disc tray partially opens, pull the tray with your fingers to fully open the tray.
******** If you insert the paperclip in the hole and find an obstacle, this indicates that your Xbox console's manual release button is located in a different area of the console.*******
Look under the "O" or the "B" in the word "XBOX" that appears on the tray. If this is the case, insert the paperclip under the "O" as outlined above. If you find an obstacle, insert the paperclip under the letter "B”. The manual release button is located in one of these three locations.
Aug 31, 2009 | Microsoft Xbox Console
PS2 disk tray keeps opening
try holding the disk drive after it closes for a few seconds and see if it stays closed or one of the drives gears could be stuck,loose,or broken.you might need to open it up.
Jul 05, 2007 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
32 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
