Question about Yamaha Full-Size Keyboard
I have a Yamaha Clavinova clp 360; it no longer turns on.
I recently transported my yamaha clavinova to my apartment. I was as careful as possible during moving, but damage may have occurred during the move, it was also laid on it's side during the drive. Once i was done moving it, I plugged it in, pressed the on button, and all of the lights came on and sound could be heard; essentially it was working just fine, so i turned it off and walked away. I came back about an hour later, pressed the on button, and the lights turned on for about 2 seconds and then it shut off. So i pressed the power button off and then back on again and the same thing happened- the lights came on and then turned off after a few seconds. After about 10 times of this happening, now no lights come on after pressing the power button. The two main fuses have been checked and look absolutely fine. I have the piano open and it does not look like any components are damaged. The on button works, so it is not as simple as that either. Please let me know if you have any ideas on what the problem could be. or if you know of any typical components that could break in a move, or the most problematic components on the piano after several years of use. Thanks!
  • Vincent Mcelroy
    Vincent Mcelroy May 20, 2014
    paul, inside of the clavinova behind where the power cord is there is a 125 volt 1.25 amp fuse,
Paul, inside of the Clavinpva at the rear where the power cable connects to the board. there is a 124 volt 1.25 amp fuse. the old type that is a glass cylinder with silver ends. it's an easy fix and will cost about $3.00 for a pack of four. You have to9 take out all of the screws on the bottom of the piano in order for the top to slide off, but you can do it in about 15 minutes!
Posted on May 20, 2014
  • BabakM Oct 29, 2016
    Thanks Vincent. My CLP-511 had a 250v/3A fuse. Had to unplug from the wall, remove the top cover (three screws in the back) and the electrical plug cover (two screws) to get to the fuse. Takes 5-10 minutes excluding the run to the neighborhood hardware store to buy the fuse ($4 for 2).
2 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: Yamaha clavinova won't play C natural in any octave
Hi ...
There are flexible cables that connect the keys to the main electronics. The connectors for those cables sometimes age poorly..
It is fixable. But dont "get taken" on a repair.
If it's just resoldering a few points,it shouldnt be more than $100.00
to fix
Posted on Jan 12, 2009
Does a Yamaha clavinova clp 760 have a fuse that may need changing
There are a number of fuses on the main power board ( by transformer ) the sizes differ depending on the country of use but are clearly marked on the board.
REMEMBER TO UNPLUG FROM THE MAINS BEFORE OPENING - if in doubt seek the advice of a qualified electrician
Mar 07, 2015 | Yamaha Music
HOW TO REPLACE CONTACT STRIP OF YAMAHA CLAVINOVA CVP 92 DIGITAL PIANO ?
Successful repair of my Yamaha Clavinova CLP 880
The principal to replace your contact strip will require one further step to that shown here where the customer has replaced the felts.
When you have the keybed out you will see the contact strip part 220. This is held in place behind the circuit boards. Remove boards, replace strip and reassemble.
It might be worth considering felts whilst you have the keyboard in bits as these wear out.
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=19108
Aug 09, 2014 | Yamaha Music
Yamaha Clavinova CLP-440
It sounds like you have a part overheating and failing, then cooling off and starting again. i would take it into the nearest Yamaha repair facility or contact your local authorized repair to come take a look before it goes out of warranty.
Mar 07, 2017 | Music
I have a Yamaha Clavinova CLP-50 Digital Electric Piano serial number 19071 and would like to find its age. Many thanks Phil
If you will turn the instrument upside down you will find a date of production somewhere. My CLP-50 has been built in 1985 for example, I discovered in 2006. (I have forgotten the exact location of this date.)
Jan 03, 2010 | Yamaha Music
Our Yamaha clavinova CLP-115 is buzzing, even with
Without power to the unit no sound should be generated. Make sure there are no other connections.
MAYBE you have a wall transformer behind it that is buzzing. MANY wall transformers develop buzz.
Another source is flourescent lights and even some of the low voltage halogens have noisy transformers in the base.
Nov 17, 2009 | Yamaha Music
Yamaha clavinova clp 200 - ear phone jack slid
The control panel hinges upwards and you have to move the keybed back a bit to get at the jack. All the screws on the bottom for the keybed. I'm not sure where the ones for the control panel are.
Oct 12, 2009 | Yamaha Music
Yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
Oct 05, 2009 | Yamaha Full-Size Keyboard
Keys stick on Clavinova CLP 360
A contact rubber for CVP-35, part number VS549800 will work, that's how I fixed my sensor problems on my CLP-360.
Jan 19, 2009 | Yamaha Full-Size Keyboard
Yamaha Clavinova CLP 260
hi...
Your L/R jacks in the back need to connect to the "line-in" connector on your sound card.
I think the jacks on the Clav are 1/4 inch. Go to Radio shack and ask for an adapter that will take two 1/4 inch plugs/cable and convert it to a 1/8 inch stereo plug.
The Midi connects From (keyboard) To (soundcard)
Cables are available at any music store
Jan 12, 2009 | Yamaha Full-Size Keyboard
Hi ...
to fix
Jan 04, 2009 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
711 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
