Question about La Crosse Technology WS9640UIT Weather Boy Wireless Temperature Station
Outside temp. comes & goes and replaced with (- - )
Have checked batteries , show 1.61 V on all. Have removed batteries , waited 15 min. replaced in sensor first, then inside unit , 4 times, with same results. When the sensor icon comes on the outside temp. is displayed for 5- 8 minutes and then returns to ( - - ), for 10 -15 min. and sensor icon comes on and we start all over. What do I do next ?
5 Suggested Answers
SOURCE: Outside Weather Not Displaying
Restart as if from new ie as if it is being taken out of the box
Posted on Jan 31, 2008
freetek
  • 5568 Answers
SOURCE: outside temp not measuring correctly
I keep the outside unit of our in/out set under a coffee can shaded under a bench; one could argue the aesthetics but shielding it from wind and sun is mandatory otherwise one can get record temps pretty often.
The outside units generally transmit to the receivers only every few minutes to keep battery consumption down so moving them won't necessary gie you an immediate change.
Posted on Jul 15, 2009
  • 127 Answers
SOURCE: outside temp. display
if it is wireless then check the sender unit
check the battery
severe cold weather can be hard on batteries
Posted on Jan 02, 2010
  • 1416 Answers
SOURCE: outside remote sensor, when i insert batteries,get
Hello.
The problem can be from two point of view.
1). from the battery capacity if not up to the voltage expected to be use.
2). And also if the battery sensor is not compatable with it.
However, what you need to do is to test run the system with another battery in other to be able to locate were the problem is from if from the battery or the the system it self.
you can also get back to me after the test.
Thanks.
Posted on Sep 12, 2011
Barolo AU9 weather station. I replaced batteries in the outside temp unit. how do I activate it to show outside temp on the main inside unit
  • Remove batteries from both units
  • Install batteries in outside transmitter and wait for it to initialize and begin sending data
  • Install batteries in inside receiver and observe temperature reading
Sep 22, 2017 | Measuring Tools & Sensors
Why is indoor display not showing outside temperatures?
If the condition comes and goes, the outside unit may be exposed to extreme temperatures or the batteries may be too weak. If the condition occurred after battery replacement, remove all batteries then reinstall the outside battery and wait for it to "initialize" and begin sending data. ReInstall the inside battery and you should see the outside temperature displayed.
Feb 13, 2016 | Measuring Tools & Sensors
I have a 1999 yamaha v star650 runs great reg maint. But I get 15 min rides then batt goes dead I charge it with a small amp charger/tender shows full charge, turn on the key I hear a few clicks then fires...
Do a hydro test on the battery, replace the battery if below 1200. Check the reftact thing ... bridge rectifier ... for shorts. And of course check the alternator for output.
Sep 09, 2013 | 2007 Yamaha V Star Custom
My ac on my vnl670 turns on and off after the outside temp goes above 85F
could be a bad thermostat control or temp sensor.My international car carrier did the same thing.It was called a thermostat control on it.Different manufacturers hav e different names for it.basicly it reads temperatures
Jun 04, 2012 | Volvo Cars & Trucks
Atwood 10 gallon H2O heater- replaced thermal couple and electrode spark and sensor but heater comes on with switch, heats water for 10 to 15 mins then burner goes out. Can hear a couple of switching...
I'd check that ECO and thermostat discs are making contact properly with tank.Just peel back foam cover on outside of tank that has ECO and THERM marked on it. If they are installed correctly, replace them.
Aug 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
Screen won't turn off. Goes white
Have you tried turning your phone off and removing the battery.
leave your phone off for like 15-20 mins.
then replace your battery and wait 15 seconds before you turn it back on it should help you.
May 29, 2009 | Motorola Mobility RAZR V3
Outside temp on skycam atomic clock
Try changing the battereis in the CLOCK. When the batteries in the clock start getting low, the clock does not pick up the outside transmitter.
Nov 10, 2008 | SkyScan 86742 Digital Atomic Wall Clock
La Crosse Technology WS9640UIT Weather Boy Wireless Temperature Station Logo
32 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
john milligan
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
