My Luxaire air conditioner not working error E3
blueextc3221
  • 15935 Answers
SOURCE: I have a wind chaser portable air conditioner
They make a few different 12,000btu models.
Click HERE for the manufacturer's web page to select and download your specific manual.
These error codes are not available in the manual.
Please contact them Monday through Friday, between 8:30 am - 4:30 pm PST,
Toll Free 1-800-405-2943 Inside the US
1-310-827-8615 Outside the US
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 28, 2009
SOURCE: I have an error code of E3 on my ducted air
i have an E3 error reading on my 12000 btu home airconditioner.Please let me know how to resolve this problem and get the aorcon up and running again .Thank you
Kind regards. Osman
Posted on Mar 22, 2010
  • 3 Answers
SOURCE: I have a Toyo Aircon
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Posted on Apr 18, 2010
hvac1960
  • 2133 Answers
SOURCE: i m geting E3
E-3 - Outdoor activation of high pressure switch
Posted on Jan 03, 2011
hvac1960
  • 2133 Answers
SOURCE: I have a Daytek air
E-3 means indoor motor mechanism locked or no power to motor.Check& rectify motor and PCB.
Posted on Jan 12, 2011
Error 3 luxaire heatpump
It's the compressor it's not comming on check the capassator in the outside unit it's 60 far rot it popped course the motor was struggling to start if the compressor it empty it burn out the cap
Aug 26, 2016 | Heating & Cooling
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
Once putting off fujiaire split ac its shows E3 Error
Try this: http://www.manualslib.com/
I Googled this: Fuji air conditioner E3 Error
One item seems to have the answer:
http://errorcodeairconditioning.blogspot.com/2010/10/fujitsu-air-conditioner-error-codes.html
"E3:00 Return air thermistor short circuit"
So more than likely you have a crossed wire issue. good luck.
I'd call ACND service man!
Mar 05, 2015 | Heating & Cooling
E3 error code
e3 error code comes when room not getting cool after 3 hours ac working, pls close all doors and windows and if possible try to run ac in an empty room for 1 hour , then check for fault,
Oct 13, 2013 | Kenwood KW85 Air Conditioner
I have E3 showing up on my Conia air conditioner an cannot find the booklet that came with to find out how to fix it ???
Please check one of this:
E3 Fault room sensor(s) (open or closed circuit)Code
E3
Error detail Remote control transmission error (transmitting error)
Inspected unit Remote control.
Dec 10, 2010 | Heating & Cooling
My sairon split system ac unit does nothing and comes up with e3 on the display
if split ac display shows e3 what is the solution for that problem
What is an E3 error message
E3 FROST PROBE OPEN: Normal operation is allowed. Replace probe.
E3 FROST PRObE OPEN: Normal operation is allowed. Ohm frost probe. Replace probe if ohm value not read. If ohm value is present replace board.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Fedders A6D24E7D Wall/Window Air...
I have an error code of E3 on my ducted air conditioner system. It is Starway - Does anyone know what the error means?
Kind regards. Osman
Mar 14, 2010 | Heating & Cooling
Error : E3 FAULT
i have problem ac indoor come on display e3 error problem kindly give me solution
Sep 16, 2008 | Kenwood KW85 Air Conditioner
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
